[PATCH rtems_rsb 1/4] Initial step to build EPICS
Mritunjay Sharma
mritunjaysharma394 at gmail.com
Thu Jul 23 21:17:17 UTC 2020
Signed-off-by: Mritunjay Sharma <mritunjaysharma394 at gmail.com>
source-builder/config/epics-7-1.cfg | 65 +++++++++++++++++++++++++++++
1 file changed, 65 insertions(+)
create mode 100644 source-builder/config/epics-7-1.cfg
diff --git a/source-builder/config/epics-7-1.cfg b/source-builder/config/epics-7-1.cfg
new file mode 100644
index 0000000..fe1fb45
--- /dev/null
+++ b/source-builder/config/epics-7-1.cfg
@@ -0,0 +1,65 @@
+# EPICS 7.x.x Version 1.
+# This configuration file configure's, make's and install's EPICS.
+%if %{release} == %{nil}
+%define release 1
+%endif
+%define epics_version 3afec267ab08568ea454789e562450b00feea5c0
+Name: epics-%{epics_version}-%{_host}-%{release}
+Summary: EPICS v%{epics_version} for target %{_target} on host %{_host}
+Version: %{epics_version}
+Release: %{release}
+URL: https://epics.mpg.de/
+# Source
+%source set epics --rsb-file=epics-%{epics_version}.zip https://github.com/hjunkes/epicsBaseOwnPlayground/archive/%{epics_version}.zip
+# Prepare the source code.
+%prep
+ build_top=$(pwd)
+ source_dir_epics="epics-%{epics_version}"
+ %source setup epics -q -n epics-%{epics_version}
+ cd ${build_top}
+%build
+ build_top=$(pwd)
+ %{build_directory}
+ mkdir -p ${build_dir}
+ cd ${build_dir}
+ %{host_build_flags}
+ #cd ${source_dir_epics}
+ ./configure \
+ --prefix=%{_prefix}
+ %{__make} %{?_smp_mflags}
+ cd ${build_top}
+%install
+ build_top=$(pwd)
+ rm -rf $SB_BUILD_ROOT
+ cd ${source_dir_epics}
+ %{__make} DESTDIR=$SB_BUILD_ROOT PREFIX=%{_prefix} install
+ cd ${build_top}
2.25.1
