[GSoC 2020]: Weekly thread: Preparing RSB recipies for EPICS
Thu Jul 23 23:04:50 UTC 2020
On Thu, Jul 23, 2020 at 3:26 PM Mritunjay Sharma
<mritunjaysharma394 at gmail.com> wrote:
> I have sent the Patches related to the RSB recipe of EPICS build
> and I will request Chris and other mentors to kindly review and suggest improvements.
> Also Chris, please can you help me how to ake it work across different BSPs / architectures?
> How to add some code to parameterize the EPICS configuration?
At this point you might want to write a separate email thread to
clearly describe the problem, your current solution, and request for
help. Sometimes these conversations in threads get a little bit
confusing.
I'm starting to wonder if the EPICS configuration can be handled by
script to manipulate the files (something like sed)
> Thanks
> Mritunjay
> On Wed, Jul 22, 2020 at 2:55 AM Gedare Bloom <gedare at rtems.org> wrote:
>> On Tue, Jul 21, 2020 at 2:16 PM Mritunjay Sharma
>> > I cancelled the earlier message because the log file size was very big
>> > and could not be posted in the devel list.
>> > [UPDATE]: Applying PATCH for RTEMS-pc386 support to EPICS and
>> > making other changes in code worked and EPICS7 was successfully built
>> > and installed using the RSB recipe.
>> > Tha changes that made it work:
>> > diff --git a/rtems/config/epics/epics-7-1.cfg b/rtems/config/epics/epics-7-1.cfg
>> > new file mode 100644
>> > index 00000000..ed1f768b
>> > --- /dev/null
>> > +++ b/rtems/config/epics/epics-7-1.cfg
>> > @@ -0,0 +1,28 @@
>> > +# EPICS 3afec267ab08568ea454789e562450b00feea5c0
>> > +%if %{release} == %{nil}
>> > + %define release 1
>> > +%endif
>> > +#%include %{_configdir}/rtems-bsp.cfg
>> > +# EPICS Version
>> > +%define epics_version 3afec267ab08568ea454789e562450b00feea5c0
>> > +#%hash sha512 epics-%{ntp_version}.tar.gz 8d76fc7e92b2ea6dd5031e6030a7aba4ff6fb3e19d3bc0153852509861be5d0960e70604814163caedb81f8315a451d78371f99634a50b55cfe1cbd2c69e3046
>> > +# Patch for RTEMS support.
>> > +%patch add epics -p1 file:///home/mritunjay/development/rtems/src/rsb_GSoC/rtems/patches/0001-Added-Support-for-RTEMS-pc386.patch
>> > +#%hash  sha512 rtems-ntp-4.2.6p5.diff 257223d207d0b77cde2b9d7add22e3b9d657b58998411d2e20d0b1adf36910be21f1277386c54c34f5d9616fccd29f721d007295708047ea7ae0270a00be25a0
>> > +# EPICS Build configuration
>> > +%include %{_configdir}/epics-7-1.cfg
>> > diff --git a/rtems/config/epics/epics-base.bset b/rtems/config/epics/epics-base.bset
>> > index 00000000..550daad0
>> > --- /dev/null
>> > +++ b/rtems/config/epics/epics-base.bset
>> > @@ -0,0 +1,26 @@
>> > +# Build set for EPICS
>> > +%define release 1
>> > +# RTEMS Version
>> > +%define rtems_version 5
>> > +# The RTEMS URL paths.
>> > +%include rtems-urls.bset
>> > +# The RTEMS Package defines
>> > +%include rtems-package.bset
>> > +# Build EPICS.
>> > +epics/epics-7-1.cfg
>> > \ No newline at end of file
>> > diff --git a/source-builder/config/epics-7-1.cfg b/source-builder/config/epics-7-1.cfg
>> > index ea25f284..b18f62bd 100644
>> > --- a/source-builder/config/epics-7-1.cfg
>> > +++ b/source-builder/config/epics-7-1.cfg
>> > @@ -31,6 +31,7 @@ URL:  https://epics.mpg.de/
>> >    source_dir_epics="epicsBaseOwnPlayground-%{epics_version}"
>> >    %source setup epics -q -n epicsBaseOwnPlayground-%{epics_version}
>> > +  %patch setup epics -p1
>> >    cd ${build_top}
>> > @@ -43,10 +44,7 @@ URL:  https://epics.mpg.de/
>> >    %{__make} PREFIX=%{_prefix}
>> > -  ./configure \
>> > -    --prefix=%{_prefix}
>> > -  %{__make} %{?_smp_mflags}
>> > +  #%{__make} %{?_smp_mflags}
>> >    cd ${build_top}
>> > The changes can also be looked here: https://github.com/RTEMS/rtems-source-builder/compare/master...mritunjaysharma394:epics-support?expand=1
>> > On Tue, Jul 21, 2020 at 10:23 PM Gedare Bloom <gedare at rtems.org> wrote:
>> >> On Tue, Jul 21, 2020 at 10:42 AM Mritunjay Sharma
>> >> > [UPDATE]: The error was actually a mismatch of names which was fixed with the following
>> >> > changes:
>> >> > index fe1fb458..ea25f284 100644
>> >> > @@ -10,7 +10,7 @@
>> >> > -Name:      epics-%{epics_version}-%{_host}-%{release}
>> >> > +Name:      epicsBaseOwnPlayground-%{epics_version}-%{_host}-%{release}
>> >> >  Summary:   EPICS v%{epics_version} for target %{_target} on host %{_host}
>> >> >  Version:   %{epics_version}
>> >> >  Release:   %{release}
>> >> > @@ -19,7 +19,8 @@ URL:  https://epics.mpg.de/
>> >> >  # Source
>> >> > -%source set epics --rsb-file=epics-%{epics_version}.zip https://github.com/hjunkes/epicsBaseOwnPlayground/archive/%{epics_version}.zip
>> >> > +%source set epics --rsb-file=epicsBaseOwnPlayground-%{epics_version}.tar.gz https://github.com/hjunkes/epicsBaseOwnPlayground/archive/%{epics_version}.tar.gz
>> >> >  # Prepare the source code.
>> >> > @@ -27,25 +28,20 @@ URL:  https://epics.mpg.de/
>> >> >  %prep
>> >> >    build_top=$(pwd)
>> >> > -  source_dir_epics="epics-%{epics_version}"
>> >> > +  source_dir_epics="epicsBaseOwnPlayground-%{epics_version}"
>> >> > -  %source setup epics -q -n epics-%{epics_version}
>> >> > +  %source setup epics -q -n epicsBaseOwnPlayground-%{epics_version}
>> >> We will eventually want this to work from the upstream EPICS.
>> > Yes, I think we need to discuss it with Heinz when he is available.
>> >> >    cd ${build_top}
>> >> >  %build
>> >> >    build_top=$(pwd)
>> >> > -  %{build_directory}
>> >> > -  mkdir -p ${build_dir}
>> >> > -  cd ${build_dir}
>> >> > +  cd ${source_dir_epics}
>> >> > -  %{host_build_flags}
>> >> > +  %{build_build_flags}
>> >> > -  #cd ${source_dir_epics}
>> >> > +  %{__make} PREFIX=%{_prefix}
>> >> >    ./configure \
>> >> >      --prefix=%{_prefix}
>> >> > After this, I ran the command
>> >> > `../source-builder/sb-builder --prefix=/home/mritunjay/development  --log=log_epics epics-7-1 --trace`
>> >> > again. The error that has come now was expected because the changes I made in epicsBaseOwnPlayground/configure file
>> >> > were done manually and here it has to be done through a script. The changes that I did manually were;
>> >> >> in epics-base/configure/CONFIG_SITE
>> >> >> set
>> >> >> CROSS_COMPILER_TARGET_ARCHS=
>> >> >    What I entered:
>> >> >    CROSS_COMPILER_TARGET_ARCHS=  RTEMS-pc386-qemu
>> >> >> e.g. RTEMS-pc386
>> >> >> or RTEMS-xilinx_zynq_a9_qemu
>> >> >> in epics-base/configure/os there must be a file for the target used,
>> >> >> e.g.
>> >> >> CONFIG.Common.RTEMS-xilinx_zynq_a9_qemu
>> >> >> or
>> >> >> CONFIG.Common.RTEMS-pc386
>> >> > Checked.  CONFIG.Common.RTEMS-pc386 was there
>> >> >> Then you have to set in configure/os/CONFIG_SITE.Common.RTEMS
>> >> >> where to find RTEMS:
>> >> >> # Where to find RTEMS
>> >> >> # APS:
>> >> >> #RTEMS_VERSION = 4.10.2
>> >> >> #RTEMS_BASE = /usr/local/vw/rtems/rtems-$(RTEMS_VERSION)
>> >> > In my system, I entered this:
>> >> > #FHI
>> >> > RTEMS_VERSION = 5
>> >> > RTEMS_BASE = /home/mritunjay/development/rtems/$(RTEMS_VERSION)
>> >> > I have a doubt on how to implement the above changes in the `source-builder/config/epics-7-1.cfg` to make it work.
>> >> > Do we have to write a patch? And what will be the best way to do it?
>> >> This is a good question. These configuration changes need to be
>> >> populated somehow based on the target being built. If this is only
>> >> doable by writing files directly, then we'll probably need a way to
>> >> apply patches for each different target. This seems unwieldy, so
>> >> further thought should be considered on how to configure EPICS based
>> >> on the RTEMS BSP build.
>> >> You can start with a manually-created patch file, but eventually we
>> >> need something that can be used across different BSPs / architectures.
>> > The manually-created patch file has worked.
>> > Now, what can be done to make it work across different BSPs / architectures?
>> > Will writing similar patches for each architecture should be our way?
>> > And I guess in the #FHI section as well we have to do something so that user
>> > can add the path interactively where the user's BSP are installed?
>> > Would you like to give any other feedback/suggestions?
>> I'd like to see if Chris has an idea. Adding patches for each
>> architecture/bsp is not preferred. It might be that we can pick up the
>> target (architecture, bsp) in the build script, and add some code to
>> parameterize the EPICS configuration. This file-based configuration is
>> a little bit clunky in EPICS.
>> > Thanks
>> > Mritunjay
>> >> > The latest error looks somewhat like this which is because I have to change the configurations in epics directory.
>> >> > The question is how to accomplish it through the script.
>> >> > ../../configure/os/CONFIG.Common.RTEMS:36: /Users/junkes/MVME6100/RTEMS/rtems-5/powerpc-rtems5/beatnik/Makefile.inc: No such file or directory
>> >> > Thanks
>> >> > Mritunjay
>> >> > On Tue, Jul 21, 2020 at 4:09 AM Mritunjay Sharma <mritunjaysharma394 at gmail.com> wrote:
>> >> >> Hello all,
>> >> >> I went through the https://docs.rtems.org/branches/master/user/rsb/index.html
>> >> >> and started writing a recipe for building EPICS 7.
>> >> >> The code is based on a very raw idea just now and
>> >> >> so was expected to give errors.
>> >> >> The code can be found here: https://github.com/mritunjaysharma394/rtems-source-builder/blob/epics-support/source-builder/config/epics-7-1.cfg
>> >> >> After this, just to check, what errors it might gave,
>> >> >> I ran the following command:
>> >> >> This gave me the following error:
>> >> >> `+ cd epics-3afec267ab08568ea454789e562450b00feea5c0
>> >> >> /home/mritunjay/development/rtems/src/rsb_GSoC/rtems/build/epics-3afec267ab08568ea454789e562450b00feea5c0-x86_64-linux-gnu-1/do-build: 90: cd: can't cd to epics-3afec267ab08568ea454789e562450b00feea5c0
>> >> >> shell cmd failed: /bin/sh -ex  /home/mritunjay/development/rtems/src/rsb_GSoC/rtems/build/epics-3afec267ab08568ea454789e562450b00feea5c0-x86_64-linux-gnu-1/do-build
>> >> >> error: building epics-3afec267ab08568ea454789e562450b00feea5c0-x86_64-linux-gnu-1`
>> >> >> I think there seems to be some problem with naming the directory.
>> >> >> I request you all to kindly help with the error as well as please check the code
>> >> >> to see if I am on the right path.
>> >> >> I am attaching the log and trace file as well.
>> >> >> Thanks,
>> >> >> Mritunjay
