[PATCH rtems_waf 2/2] rtems: Add function to test waf uninstall
Chris Johns
chrisj at rtems.org
Fri Jul 24 04:52:41 UTC 2020
On 24/7/20 2:37 am, Vijay Kumar Banerjee wrote:
> rtems.py | 40 ++++++++++++++++++++++++++++++++++++++++
> 1 file changed, 40 insertions(+)
> diff --git a/rtems.py b/rtems.py
> index 067a213..ab6d03b 100644
> --- a/rtems.py
> +++ b/rtems.py
> @@ -303,6 +303,46 @@ def build(bld):
> if bld.env.LONG_COMMANDS == 'yes':
> long_command_line()
> +def get_dir_hash(bld):
> + from waflib import ConfigSet, Options
> + import hashlib
> + env = ConfigSet.ConfigSet()
> + env.load(Options.lockfile)
> + prefix = env.options['prefix']
> + shahash = hashlib.sha1()
> + for root, dirs, files in os.walk(prefix):
> + for names in files:
> + filepath = os.path.join(root, names)
> + try:
> + f1 = open(filepath, 'rb')
> + except:
> + f1.close()
> + continue
> + while 1:
> + buf = f1.read(4096)
> + if not buf:
> + break
> + shahash.update(hashlib.sha1(buf).hexdigest())
> + f1.close()
> + return shahash.hexdigest()
> +def test_uninstall(bld):
Please move to the end of the file.
> + print('TESTING WAF UNINSTALL\n')
I am not a fan of all caps...
print('Test: uninstall')
Also please do not embed `\n'. If you want another line feed please add the
extra print().
> + print('CALCULATING HASH BEFORE INSTALL')
What about ...
> + initial_hash = get_dir_hash(bld)
print('Preinstall hash: XXX') where XXX is the hash string?
> + subprocess.call(['./waf', 'install'])
> + subprocess.call(['./waf', 'uninstall'])
What happens if `waf` is in my $PATH and not in `./`?
> + print('CALCULATING HASH AFTER UNINSTALL')
> + final_hash = get_dir_hash(bld)
print('Postinstall hash: XXX') ?
> + if (initial_hash == final_hash):
> + print("TEST PASSED")
> + else:
> + print("TEST FAILED")
> def load_cpuopts(conf):
> options = ['RTEMS_DEBUG',
> 'RTEMS_MULTIPROCESSING',
