[PATCH rtems_waf v2 2/2] rtems: Add function to test waf uninstall
Vijay Kumar Banerjee
vijay at rtems.org
Fri Jul 24 15:14:13 UTC 2020
rtems.py | 46 ++++++++++++++++++++++++++++++++++++++++++++++
1 file changed, 46 insertions(+)
diff --git a/rtems.py b/rtems.py
index 067a213..7ee3653 100644
--- a/rtems.py
+++ b/rtems.py
@@ -897,6 +897,52 @@ def _strip_cflags(cflags):
def _log_header(conf):
conf.to_log('-----------------------------------------')
+def _get_dir_hash(bld):
+ from waflib import ConfigSet, Options
+ import hashlib
+ env = ConfigSet.ConfigSet()
+ env.load(Options.lockfile)
+ prefix = env.options['prefix']
+ shahash = hashlib.sha1()
+ for root, dirs, files in os.walk(prefix):
+ for names in files:
+ filepath = os.path.join(root, names)
+ try:
+ f1 = open(filepath, 'rb')
+ except:
+ f1.close()
+ continue
+ while 1:
+ buf = f1.read(4096)
+ if not buf:
+ break
+ shahash.update(hashlib.sha1(buf).hexdigest())
+ f1.close()
+ return shahash.hexdigest()
+def test_uninstall(bld):
+ from os import sys
+ print('Test: uninstall')
+ initial_hash = _get_dir_hash(bld)
+ print('Preinstall hash: %s' % (initial_hash))
+ try:
+ subprocess.call(['waf', 'install'])
+ subprocess.call(['waf', 'uninstall'])
+ except:
+ subprocess.call(['./waf', 'install'])
+ subprocess.call(['./waf', 'uninstall'])
+ final_hash = _get_dir_hash(bld)
+ print('Post install hash: %s' % (final_hash))
+ if (initial_hash == final_hash):
+ print("Test successful")
+ else:
+ print("Test failed")
from waflib import Task
from waflib import TaskGen
from waflib import Utils
2.21.1
