[PATCH] eng: Add recommendations for attributes
Gedare Bloom
gedare at rtems.org
Fri Jul 24 17:40:48 UTC 2020
looks good, thanks
On Thu, Jul 23, 2020 at 11:11 PM Sebastian Huber
> Fix formatting.
> eng/coding-conventions.rst | 34 ++++++++++++++++++++++++++++++----
> 1 file changed, 30 insertions(+), 4 deletions(-)
> diff --git a/eng/coding-conventions.rst b/eng/coding-conventions.rst
> index 10034df..b85d8fc 100644
> --- a/eng/coding-conventions.rst
> +++ b/eng/coding-conventions.rst
> @@ -21,7 +21,7 @@ Source Documentation
> * Use Doxygen according to our `Doxygen Recommendations <https://devel.rtems.org/wiki/Developer/Coding/Doxygen>`_..
> * Start each file with a brief description followed by a license.
> See `Boilerplate File Header <https://devel.rtems.org/wiki/Developer/Coding/Boilerplate_File_Header>`_..
> -* Use /* */ comments.
> +* Use ``/* */`` comments.
> * Use comments wisely within function bodies, to explain
> or draw attention without being verbose.
> * Use English prose and strive for good grammar,
> @@ -48,54 +48,80 @@ Language and Compiler
> * Use C99.
> * Treat warnings as errors: eliminate them.
> * Favor C, but when assembly language is required use inline
> assembly if possible.
> * Do not use compiler extensions.
> -* Use the RTEMS_macros defined in score/basedefs.h for abstracting
> - compiler-specific features.
> +* Use the RTEMS macros defined in <rtems/score/basedefs.h> for abstracting
> + compiler-specific features. For using attributes see the
> + `GCC attribute syntax <https://gcc.gnu.org/onlinedocs/gcc/Attribute-Syntax.html#Attribute-Syntax>`_.
> + Prefer to place attributes in front of the declarator. Try to be in line
> + with
> + `C++11 attributes <https://en.cppreference.com/w/cpp/language/attributes>`_
> + and C11 keywords such as
> + `_Noreturn <https://en.cppreference.com/w/c/language/_Noreturn>`_.
> * Use NULL for the null pointer, and prefer to use explicit
> checks against NULL, e.g.,
> .. code-block:: c
> if ( ptr != NULL )
> instead of
> .. code-block:: c
> if ( !ptr )
> * Use explicit checks for bits in variables.
> * Example 1: Use
> .. code-block:: c
> if ( XBITS == (var & XBITS) )
> to check for a set of defined bits.
> * Example 2: Use
> .. code-block:: c
> if ( (var & X_FLAGS) != 0) )
> instead of
> .. code-block:: c
> if ( !!(var & X_FLAGS) )
> to check for at least 1 defined bit in a set.
> -* Use '(void) unused;' to mark unused parameters and set-but-unused
> +* Use ``(void) unused;`` to mark unused parameters and set-but-unused
> variables immediately after being set.
> * Do not put function prototypes in C source files, any global functions
> should have a prototype in a header file and any private function
> should be declared static.
> * Declare global variables in exactly one header file.
> Define global variables in at most one source file.
> Include the header file declaring the global variable as
> the first include file if possible to make sure that the
> compiler checks the declaration and definition and that
> the header file is self-contained.
> * Do not cast arguments to any printf() or printk() variant.
> Use <inttypes.h> PRI constants for the types supported there.
> Use <rtems/inttypes.h> for the other POSIX and RTEMS types that
> have PRI constants defined there. This increases the portability
> of the printf() format.
> * Do not use the register keyword. It is deprecated since C++14.
> Formatting
> 2.26.2
> devel mailing list
> devel at rtems.org
