[GSoC 2020]: Doubts in building RSB Recipe for EPICS for multiple architectures
Mritunjay Sharma
mritunjaysharma394 at gmail.com
Sun Jul 26 18:17:15 UTC 2020
Hello everyone,
Meanwhile, I publish a couple of blogs of the learnings I made in this
phase, tonight,
I will request you all to kindly review the patches so that I can send the
next version of them.
Also kindly guide, so that the RSB recipe which works only on pc-386 can
also work for other BSP targets for EPICS7+RTEMS5
Thanks
Mritunjay
On Fri, Jul 24, 2020 at 7:20 PM Mritunjay Sharma <
mritunjaysharma394 at gmail.com> wrote:
> Hello all,
> To update you all, I have sent the first version of PATCHES that
> implement an RSB recipe for EPICS7 building with RTEMS5 for pc-386.
> While the build was successful for pc-386, I have doubts and need
> suggestions on how to make it work across different BSP targets.
> I will request Chris to show me the path and if possible then also review
> the patches.
> Gedare has suggested using sed but it will be really nice if I can get a
> a more clear idea on how to implement it.
> The existing changes in the file can be seen here:
> https://github.com/RTEMS/rtems-source-builder/compare/master...mritunjaysharma394:epics-support
> Thanks,
> Mritunjay
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200726/9ca1b054/attachment.html>
