[GSoC 2020]: Doubts in building RSB Recipe for EPICS for multiple architectures
Joel Sherrill
joel at rtems.org
Sun Jul 26 23:46:53 UTC 2020
On Fri, Jul 24, 2020 at 8:51 AM Mritunjay Sharma <
mritunjaysharma394 at gmail.com> wrote:
> Hello all,
> To update you all, I have sent the first version of PATCHES that
> implement an RSB recipe for EPICS7 building with RTEMS5 for pc-386.
> While the build was successful for pc-386, I have doubts and need
> suggestions on how to make it work across different BSP targets.
> I will request Chris to show me the path and if possible then also review
> the patches.
I didn't see anything in the patches that look to be pc specific but admit
I could have
missed something. I would try another couple of BSPs known to work with
EPICS
using the same network stack you used for the PC. Options include:
+ powerpc and beatnik or a motorola_powerpc variant
+ arm zynq qemu
+ m68k uc5282
Which network stack did you build against?
> Gedare has suggested using sed but it will be really nice if I can get a
> a more clear idea on how to implement it.
> The existing changes in the file can be seen here:
> https://github.com/RTEMS/rtems-source-builder/compare/master...mritunjaysharma394:epics-support
> Thanks,
> Mritunjay
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200726/9509e237/attachment.html>
