[GSoC 2020]: Doubts in building RSB Recipe for EPICS for multiple architectures
Joel Sherrill
joel at rtems.org
Mon Jul 27 00:22:28 UTC 2020
On Sun, Jul 26, 2020, 7:06 PM Chris Johns <chrisj at rtems.org> wrote:
> On 27/7/20 9:46 am, Joel Sherrill wrote:
> > On Fri, Jul 24, 2020 at 8:51 AM Mritunjay Sharma <
> mritunjaysharma394 at gmail.com
> > <mailto:mritunjaysharma394 at gmail.com>> wrote:
> > Hello all,
> > To update you all, I have sent the first version of PATCHES that
> > implement an RSB recipe for EPICS7 building with RTEMS5 for pc-386.
> > While the build was successful for pc-386, I have doubts and need
> > suggestions on how to make it work across different BSP targets.
> > I will request Chris to show me the path and if possible then also
> review
> > the patches.
> > I didn't see anything in the patches that look to be pc specific but
> admit I
> > could have missed something.
> There is a patch to EPICS for the PC BSP that I cannot find posted online
> anywhere.
> > I would try another couple of BSPs known to work with EPICS
> > using the same network stack you used for the PC. Options include:
> > + powerpc and beatnik or a motorola_powerpc variant
> > + arm zynq qemu
> > + m68k uc5282
> > Which network stack did you build against?
> It currently is the legacy stack. Heinz has changes pending for RTEMS 5.
Then it should be repeatable for multiple powerpc and m68k bsps. That works
be the next step past clean up and documentation to me.
Then focus on some libbsd bsps.
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200726/66110d50/attachment.html>
