Strong APA Scheduler : First Draft
Mon Jul 27 05:00:46 UTC 2020
On 26/07/2020 16:03, Gedare Bloom wrote:
> On Sat, Jul 25, 2020 at 11:21 AM Richi Dubey<richidubey at gmail.com>  wrote:
>> Dear Dr. Bloom,
>> Please find the pull request at the following link:https://github.com/RTEMS/rtems/pull/39.
> It would be great if you can create a GitHub Pull Request (PR) for
> your branch against your "master" branch in your fork.
> I'd prefer you not submit a PR to RTEMS repo, but rather, to your
> forked repo. We don't review PRs on RTEMS/github in general, so it is
> better to keep this review off the github mirror.
Yes, this would be nice.
>> Please note that I have tried to remove all the compilation errors but this still won't compile right now, because my implementation requires the use of percpu.h file, which (I'm assuming) is not currently linked with the source files related to Strong APA.
> That seems strange.
Which compiler error do you get? Maybe there is a cyclic dependency.
