[PATCH v2 2/2] break fenv.c file to function files
Eshan Dhawan
eshandhawan51 at gmail.com
Mon Jul 27 06:58:55 UTC 2020
> On 27-Jul-2020, at 12:00 PM, Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
> On 27/07/2020 08:11, Eshan Dhawan wrote:
>>>> diff --git a/newlib/libc/machine/arm/sys/fenv.h b/newlib/libc/machine/arm/sys/fenv.h
>>>> index 70bd57be4..8712b2f33 100644
>>>> --- a/newlib/libc/machine/arm/sys/fenv.h
>>>> +++ b/newlib/libc/machine/arm/sys/fenv.h
>>>> @@ -62,6 +62,14 @@ typedef int fexcept_t;
>>>> #define FE_DOWNWARD 0x00800000
>>>> #define FE_TOWARDZERO 0x00c00000
>>>> +#ifndef __SOFTFP__
>>>> +#define vmrs_fpscr(__r) __asm __volatile("vmrs %0, fpscr" : "=&r"(__r))
>>>> +#define vmsr_fpscr(__r) __asm __volatile("vmsr fpscr, %0" : : "r"(__r))
>>>> +#define _FPU_MASK_SHIFT 8
>>>> +#define _ROUND_MASK (FE_TONEAREST | FE_DOWNWARD | \
>>>> + FE_UPWARD | FE_TOWARDZERO)
>>>> +#endif
>>> I would still prefer to have this in an internal header file "newlib/libm/machine/arm/_fenv.h" which is included via #include "_fenv.h".
>>> If you really want to have it visible via <fenv.h>, then the vm*() should at least be renamed to _vmrs_fpscr() and _vmsr_fpscr().
>> I am not able to get you point could you provide a little detail
>> I understood that you are saying that create an alternative _fenv.h in machine/arm in libm.
>> But I am not able to understand why.
>> If the symbols are visible with fenv.h than does that cause any issues?
> Yes, this is a header file which is included in the C and POSIX standards. It should only provide the things covered in the standards. The general convention is to reserve all names starting with an underscore for the C library implementation and operating system use. For example:
> https://www.gnu.org/software/libc/manual/html_node/Reserved-Names.html
>> Or how does renaming them causes any change?
> It moves the names to the reserved name space.
I will add the changes and send a patch ASAP
