[PATCH] bsp/fdt.h: Move bsp/fdt.h to cpukit
Gedare Bloom
gedare at rtems.org
Wed Jul 29 15:49:33 UTC 2020
On Thu, Jul 2, 2020 at 3:07 PM G S Niteesh Babu <niteesh.gs at gmail.com> wrote:
> This commit move the bsp/fdt.h header to cpukit/include/rtems.
> The reason for this is, with inclusion of libfreebsd there are
> cases where their is need for bsp_fdt_get(). And with this
> header under bsps directory it is not possible to include it
> under a cpukit directory.
> bsps/include/bsp/fdt.h | 86 +++++++++++++-------------------------
> cpukit/include/rtems/fdt.h | 69 ++++++++++++++++++++++++++++++
> 2 files changed, 99 insertions(+), 56 deletions(-)
> create mode 100644 cpukit/include/rtems/fdt.h
> diff --git a/bsps/include/bsp/fdt.h b/bsps/include/bsp/fdt.h
> index 4ed05b136c..4a7c3dfb24 100644
> --- a/bsps/include/bsp/fdt.h
> +++ b/bsps/include/bsp/fdt.h
> @@ -1,67 +1,41 @@
> - * Copyright (c) 2015, 2017 embedded brains GmbH. All rights reserved.
> - * embedded brains GmbH
> - * Dornierstr. 4
> - * 82178 Puchheim
> - * Germany
> - * <rtems at embedded-brains.de>
> - * The license and distribution terms for this file may be
> - * found in the file LICENSE in this distribution or at
> - * http://www.rtems.org/license/LICENSE.
> -#ifndef LIBBSP_SHARED_FDT_H
> -#define LIBBSP_SHARED_FDT_H
> -#include <bsp.h>
> -#ifdef __cplusplus
> -extern "C" {
> -#endif /* __cplusplus */
> - * BSPs that implement the FDT support functions must define
> - * BSP_FDT_IS_SUPPORTED.
> +/* SPDX-License-Identifier: BSD-2-Clause */
> - * @brief Copies the specified source FDT to a dedicated global data area.
> + * @file
> - * The source FDT is usually provided by a bootloader and may be located in a
> - * memory area that is used by the program. The low-level initialization
> - * should copy the FDT for later use.
> + * @ingroup RTEMSBSPsShared
> - * The copy can be accessed by bsp_fdt_get().
> - * @param[in] src The source FDT.
> -void bsp_fdt_copy(const void *src);
> - * @brief Returns the FDT of the BSP.
> - * @return The FDT of the BSP.
> + * Copyright (C) <2020>, Niteesh G S <niteesh.gs at gmail.com>
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + * notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + * notice, this list of conditions and the following disclaimer in the
> + * documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> -const void *bsp_fdt_get(void);
> - * @brief Maps the interrupt number of the FDT to the interrupt vector used by
> - * the interrupt management.
> - * This function is used by the libbsd to implement the OFW_BUS_MAP_INTR bus
> - * method.
> - * @param[in] intr The FDT interrupt number cells.
> - * @param[in] icells The FDT interrupt cell count.
> - * @return The interrupt vector of the FDT interrupt number.
> -uint32_t bsp_fdt_map_intr(const uint32_t *intr, size_t icells);
> +#ifndef LIBBSP_SHARED_FDT_H
> +#define LIBBSP_SHARED_FDT_H
> -#ifdef __cplusplus
> +#include <bsp.h>
> +#include <rtems/fdt.h>
> #endif /* LIBBSP_SHARED_FDT_H */
> diff --git a/cpukit/include/rtems/fdt.h b/cpukit/include/rtems/fdt.h
> new file mode 100644
> index 0000000000..149f7ff906
> --- /dev/null
> +++ b/cpukit/include/rtems/fdt.h
> @@ -0,0 +1,69 @@
> + * Copyright (c) 2015, 2017 embedded brains GmbH. All rights reserved.
> + * embedded brains GmbH
> + * Dornierstr. 4
> + * 82178 Puchheim
> + * Germany
> + * <rtems at embedded-brains.de>
> + * Modified by Niteesh G S <niteesh.gs at gmail.com>
> + * The license and distribution terms for this file may be
> + * found in the file LICENSE in this distribution or at
> + * http://www.rtems.org/license/LICENSE.
> +#ifndef RTEMS_FDT_H
> +#define RTEMS_FDT_H
> +#include <rtems.h>
> +#ifdef __cplusplus
> +extern "C" {
> +#endif /* __cplusplus */
> + * BSPs that implement the FDT support functions must define
> + * BSP_FDT_IS_SUPPORTED.
> + * @brief Copies the specified source FDT to a dedicated global data area.
> + * The source FDT is usually provided by a bootloader and may be located in a
> + * memory area that is used by the program. The low-level initialization
> + * should copy the FDT for later use.
> + * The copy can be accessed by bsp_fdt_get().
> + * @param[in] src The source FDT.
> +void bsp_fdt_copy(const void *src);
Are these intended to be used solely within the cpukit, or do you
expect applications may call these functions too?
I wonder if we need to introduce an API for this. The "bsp_*" naming
is a little bit unusual to have leak outside of bsps/
By making this part of the "include/rtems/" tree, we are essentially
making this a new public interface. I'd like to know how the interface
is intended to be used.
> + * @brief Returns the FDT of the BSP.
> + * @return The FDT of the BSP.
> +const void *bsp_fdt_get(void);
> + * @brief Maps the interrupt number of the FDT to the interrupt vector used by
> + * the interrupt management.
> + * This function is used by the libbsd to implement the OFW_BUS_MAP_INTR bus
> + * method.
> + * @param[in] intr The FDT interrupt number cells.
> + * @param[in] icells The FDT interrupt cell count.
> + * @return The interrupt vector of the FDT interrupt number.
> +uint32_t bsp_fdt_map_intr(const uint32_t *intr, size_t icells);
> +#ifdef __cplusplus
> +#endif /* RTEMS_FDT_H */
> 2.17.1
> devel mailing list
> devel at rtems.org
