[PATCH RTEMS 7/7] libtests/openfirmware: Added a testsuite for openfirmware
Gedare Bloom
gedare at rtems.org
Wed Jul 29 17:55:01 UTC 2020
On Wed, Jul 29, 2020 at 10:44 AM Christian Mauderer <oss at c-mauderer.de> wrote:
> On 29/07/2020 18:07, Gedare Bloom wrote:
> > On Wed, Jul 15, 2020 at 12:32 AM G S Niteesh Babu <niteesh.gs at gmail.com> wrote:
> >> spec/build/testsuites/libtests/grp.yml | 3 +
> >> .../testsuites/libtests/openfirmware01.yml | 20 +++
> >> testsuites/libtests/openfirmware01/init.c | 147 ++++++++++++++++++
> >> .../openfirmware01/openfirmware01.doc | 29 ++++
> >> .../openfirmware01/openfirmware01.scn | 2 +
> >> testsuites/libtests/openfirmware01/some.c | 52 +++++++
> >> testsuites/libtests/openfirmware01/some.dts | 54 +++++++
> >> testsuites/libtests/openfirmware01/some.h | 15 ++
> >> 8 files changed, 322 insertions(+)
> >> create mode 100644 spec/build/testsuites/libtests/openfirmware01.yml
> >> create mode 100644 testsuites/libtests/openfirmware01/init.c
> >> create mode 100644 testsuites/libtests/openfirmware01/openfirmware01.doc
> >> create mode 100644 testsuites/libtests/openfirmware01/openfirmware01.scn
> >> create mode 100644 testsuites/libtests/openfirmware01/some.c
> >> create mode 100644 testsuites/libtests/openfirmware01/some.dts
> >> create mode 100644 testsuites/libtests/openfirmware01/some.h
> >> diff --git a/spec/build/testsuites/libtests/grp.yml b/spec/build/testsuites/libtests/grp.yml
> >> index f1de6cd75f..56e84d2c89 100644
> >> --- a/spec/build/testsuites/libtests/grp.yml
> >> +++ b/spec/build/testsuites/libtests/grp.yml
> >> @@ -11,6 +11,7 @@ install: []
> >> ldflags:
> >> - -Wl,--wrap=printf
> >> - -Wl,--wrap=puts
> >> +- -Wl,--wrap=bsp_fdt_get
> >> links:
> >> - role: build-dependency
> >> uid: optbin2c
> >> @@ -312,6 +313,8 @@ links:
> >> uid: write
> >> uid: writev
> >> +- role: build-dependency
> >> + uid: openfirmware01
> >> type: build
> >> use-after:
> >> - rtemstest
> >> diff --git a/spec/build/testsuites/libtests/openfirmware01.yml b/spec/build/testsuites/libtests/openfirmware01.yml
> >> new file mode 100644
> >> index 0000000000..8feb69eb1e
> >> --- /dev/null
> >> +++ b/spec/build/testsuites/libtests/openfirmware01.yml
> >> @@ -0,0 +1,20 @@
> >> +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> >> +build-type: test-program
> >> +cflags: []
> >> +copyrights:
> >> +- Copyright (C) 2020 Niteesh G S
> >> +cppflags: []
> >> +cxxflags: []
> >> +enabled-by: true
> >> +features: c cprogram
> >> +includes: []
> >> +ldflags: []
> >> +links: []
> >> +source:
> >> +- testsuites/libtests/openfirmware01/init.c
> >> +- testsuites/libtests/openfirmware01/some.c
> >> +stlib: []
> >> +target: testsuites/libtests/openfirmware01.exe
> >> +type: build
> >> +use-after: []
> >> +use-before: []
> >> diff --git a/testsuites/libtests/openfirmware01/init.c b/testsuites/libtests/openfirmware01/init.c
> >> index 0000000000..fc38e6c513
> >> --- /dev/null
> >> +++ b/testsuites/libtests/openfirmware01/init.c
> >> @@ -0,0 +1,147 @@
> >> +/* SPDX-License-Identifier: BSD-2-Clause */
> >> + * Copyright (C) <2020> Niteesh G S <niteesh.gs at gmail.com>
> >> + * Redistribution and use in source and binary forms, with or without
> >> + * modification, are permitted provided that the following conditions
> >> + * are met:
> >> + * 1. Redistributions of source code must retain the above copyright
> >> + * notice, this list of conditions and the following disclaimer.
> >> + * 2. Redistributions in binary form must reproduce the above copyright
> >> + * notice, this list of conditions and the following disclaimer in the
> >> + * documentation and/or other materials provided with the distribution.
> >> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> >> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> >> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> >> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> >> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> >> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> >> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> >> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> >> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> >> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> >> + * POSSIBILITY OF SUCH DAMAGE.
> >> +#ifdef HAVE_CONFIG_H
> >> +#include "config.h"
> >> +#endif
> >> +#include <tmacros.h>
> >> +#include <stdio.h>
> >> +#include <stdlib.h>
> >> +#include <libfdt.h>
> >> +#include <sys/endian.h>
> >> +#include <dev/ofw/openfirm.h>
> >> +#include "some.h"
> >> +#define BUF_SIZE 100
> >> +const char rtems_test_name[] = "OpenFirmWare 01";
> >> +const void *__wrap_bsp_fdt_get(void);
> >> +const void *__real_bsp_fdt_get(void);
> >> + if (some_bin != NULL) {
> >> + return &some_bin[0];
> >> + return __real_bsp_fdt_get();
> >> +static void Init(rtems_task_argument arg)
> >> + int rv;
> >> + phandle_t d;
> >> + phandle_t l;
> >> + phandle_t t;
> >> + phandle_t root;
> >> + phandle_t temp;
> >> + uint32_t *arr;
> >> + char buf[BUF_SIZE];
> >> + char *bufp;
> >> + ssize_t buf_len;
> >> + TEST_BEGIN();
> >> + buf_len = sizeof(buf);
> >> + * Cannot use fdt_path_offset to compare because
> >> + * the OF interface uses the offset from the ftdp
> >> + * to the node as phandle.
> >> + root = OF_finddevice("/");
> >> + rtems_test_assert(root == 56);
> >> + root = OF_peer(0);
> >> + d = OF_child(root);
> >> + temp = OF_finddevice("/d");
> >> + rtems_test_assert(d == temp);
> >> + temp = OF_parent(d);
> >> + rtems_test_assert(root == temp);
> >> + rv = OF_getprop(d, "e", buf, buf_len);
> >> + rtems_test_assert(rv != -1);
> >> + rtems_test_assert(strcmp(buf, "f") == 0);
> >> + rv = OF_hasprop(d, "g");
> >> + rtems_test_assert(rv == 1);
> >> + rv = OF_getproplen(root, "model");
> >> + rtems_test_assert(rv == 2);
> >> + rv = OF_nextprop(d, "e", buf, buf_len);
> >> + rtems_test_assert(strcmp(buf, "g") == 0);
> >> + l = OF_finddevice("/m at 1248");
> >> + rv = OF_searchprop(l, "model", buf, buf_len);
> >> + rtems_test_assert(strcmp(buf, "c") == 0);
> >> + rv = OF_getprop_alloc(root, "compatible", (void **)&bufp);
> >> + rtems_test_assert(strcmp(bufp, "a,b") == 0);
> >> + OF_prop_free(bufp);
> >> + rv = OF_getprop_alloc_multi(l, "n", sizeof(*arr), (void **)&arr);
> >> + rtems_test_assert(arr[0] == htobe32(0xdeadbeef));
> >> + rtems_test_assert(arr[1] == htobe32(0x12345678));
> >> + rv = OF_getencprop_alloc_multi(l, "n", sizeof(*arr), (void **)&arr);
> >> + rtems_test_assert(arr[0] == 0xdeadbeef);
> >> + rtems_test_assert(arr[1] == 0x12345678);
> >> + t = OF_finddevice("/t");
> >> + rv = OF_nextprop(t, "u", buf, buf_len);
> >> + rtems_test_assert(rv == 0);
> > ok, so these are intended to be application-visible. The interface is
> > not standard though, as far as I know. So, I think we need to ensure
> > we provide an RTEMS-friendly namespace for this OF API, and make sure
> > the header files are properly arranged for visibility/layering.
> > Everything else seems fine to me in a quick glance.
> Hello Gedare,
> the interface is ported from FreeBSD. It's an internal one in FreeBSD
> but I think it is useful for application drivers too.
> What would you suggest regarding the namespace. I'm not a big fan of
> changing imported FreeBSD code.
Background: The problem we have to avoid is polluting the user
namespace. Software in kernel space, such as FreeBSD and other
monolithic kernels, don't have that problem.
I haven't studied the usage closely, I guess the pinmux is the main
thing, but I'd like to understand if the FreeBSD symbols need to be
exposed.
Would it be feasible to introduce an rtems-branded API for this stuff,
and provide a wrapper in libbsd for compatibility? Imagine something
like....
<rtems/dev/openfirmware.h>
rtems_openfirmware_finddevice(char *s);
freebsd-compat:
#define OF_finddevice rtems_openfirmware_finddevice
You could even then reuse other ofw interfaces, like:
linux-compat:
#define of_finddevice rtems_openfirmware_finddevice
Just for example.
This way, we only pollute the namespace if someone pulls in the bsd library.
If the FreeBSD symbols have to be available inside RTEMS to support
drivers without libbsd, then I would rather see the symbols converted
to macros that link to namespace-friendly functions instead.
Gedare
> Best regards
> Christian
> >> + TEST_END();
> >> + rtems_test_exit(0);
> >> +#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> >> +#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
> >> +#define CONFIGURE_MAXIMUM_TASKS 1
> >> +#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
> >> +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> >> +#include <rtems/confdefs.h>
> >> \ No newline at end of file
> >> diff --git a/testsuites/libtests/openfirmware01/openfirmware01.doc b/testsuites/libtests/openfirmware01/openfirmware01.doc
> >> index 0000000000..a9d2085798
> >> --- /dev/null
> >> +++ b/testsuites/libtests/openfirmware01/openfirmware01.doc
> >> @@ -0,0 +1,29 @@
> >> +This file describes the directives and concepts tested by this test set.
> >> +test set name: openfirmware01
> >> +directives:
> >> + - OF_peer
> >> + - OF_child
> >> + - OF_parent
> >> + - OF_getproplen
> >> + - OF_getprop
> >> + - OF_getencprop
> >> + - OF_hasprop
> >> + - OF_searchprop
> >> + - OF_searchencprop
> >> + - OF_getprop_alloc
> >> + - OF_getprop_alloc_multi
> >> + - OF_getencprop_alloc
> >> + - OF_getencprop_alloc_multi
> >> + - OF_prop_free
> >> + - OF_nextprop
> >> + - OF_setprop
> >> + - OF_canon
> >> + - OF_finddevice
> >> + - OF_package_to_path
> >> +concepts:
> >> + - Ensure that some openfimware functions work as expected.
> >> diff --git a/testsuites/libtests/openfirmware01/openfirmware01.scn b/testsuites/libtests/openfirmware01/openfirmware01.scn
> >> index 0000000000..38abbdfc45
> >> --- /dev/null
> >> +++ b/testsuites/libtests/openfirmware01/openfirmware01.scn
> >> @@ -0,0 +1,2 @@
> >> +*** BEGIN OF TEST OPENFIRMWARE 1 ***
> >> +*** END OF TEST OPENFIRMWARE 1 ***
> >> diff --git a/testsuites/libtests/openfirmware01/some.c b/testsuites/libtests/openfirmware01/some.c
> >> index 0000000000..5eed911204
> >> --- /dev/null
> >> +++ b/testsuites/libtests/openfirmware01/some.c
> >> @@ -0,0 +1,52 @@
> >> + * Declarations for C structure representing binary file some.bin
> >> + * WARNING: Automatically generated -- do not edit!
> >> +#include <sys/types.h>
> >> +const unsigned char some_bin[] = {
> >> + 0xd0, 0x0d, 0xfe, 0xed, 0x00, 0x00, 0x01, 0xd8, 0x00, 0x00, 0x00, 0x38,
> >> + 0x00, 0x00, 0x01, 0x90, 0x00, 0x00, 0x00, 0x28, 0x00, 0x00, 0x00, 0x11,
> >> + 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x48,
> >> + 0x00, 0x00, 0x01, 0x58, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
> >> + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
> >> + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
> >> + 0x00, 0x00, 0x00, 0x00, 0x61, 0x2c, 0x62, 0x00, 0x00, 0x00, 0x00, 0x03,
> >> + 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x0b, 0x00, 0x00, 0x00, 0x01,
> >> + 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x1a,
> >> + 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x02,
> >> + 0x00, 0x00, 0x00, 0x26, 0x63, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
> >> + 0x64, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x02,
> >> + 0x00, 0x00, 0x00, 0x09, 0x66, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
> >> + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x2c, 0x00, 0x00, 0x00, 0x01,
> >> + 0x68, 0x40, 0x30, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
> >> + 0x68, 0x40, 0x31, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
> >> + 0x00, 0x00, 0x00, 0x2e, 0x00, 0x00, 0x00, 0x7b, 0x00, 0x00, 0x00, 0x02,
> >> + 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x61, 0x6c, 0x69, 0x61,
> >> + 0x73, 0x65, 0x73, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x08,
> >> + 0x00, 0x00, 0x00, 0x30, 0x2f, 0x6d, 0x40, 0x31, 0x32, 0x34, 0x38, 0x00,
> >> + 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x6d, 0x40, 0x31, 0x32,
> >> + 0x34, 0x38, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x08,
> >> + 0x00, 0x00, 0x00, 0x32, 0xde, 0xad, 0xbe, 0xef, 0x12, 0x34, 0x56, 0x78,
> >> + 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x34,
> >> + 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
> >> + 0x00, 0x00, 0x00, 0x3a, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x01,
> >> + 0x6f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00,
> >> + 0x00, 0x00, 0x00, 0x42, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
> >> + 0x71, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x02,
> >> + 0x00, 0x00, 0x00, 0x44, 0x73, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02,
> >> + 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x74, 0x00, 0x00, 0x00,
> >> + 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x46,
> >> + 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x02,
> >> + 0x00, 0x00, 0x00, 0x09, 0x63, 0x6f, 0x6d, 0x70, 0x61, 0x74, 0x69, 0x62,
> >> + 0x6c, 0x65, 0x00, 0x23, 0x61, 0x64, 0x64, 0x72, 0x65, 0x73, 0x73, 0x2d,
> >> + 0x63, 0x65, 0x6c, 0x6c, 0x73, 0x00, 0x23, 0x73, 0x69, 0x7a, 0x65, 0x2d,
> >> + 0x63, 0x65, 0x6c, 0x6c, 0x73, 0x00, 0x6d, 0x6f, 0x64, 0x65, 0x6c, 0x00,
> >> + 0x67, 0x00, 0x77, 0x00, 0x6b, 0x00, 0x6e, 0x00, 0x6c, 0x69, 0x6e, 0x75,
> >> + 0x78, 0x2c, 0x70, 0x68, 0x61, 0x6e, 0x64, 0x6c, 0x65, 0x00, 0x70, 0x00,
> >> + 0x72, 0x00, 0x75, 0x00,
> >> +const size_t some_bin_size = sizeof(some_bin);
> >> diff --git a/testsuites/libtests/openfirmware01/some.dts b/testsuites/libtests/openfirmware01/some.dts
> >> index 0000000000..ac15825b17
> >> --- /dev/null
> >> +++ b/testsuites/libtests/openfirmware01/some.dts
> >> @@ -0,0 +1,54 @@
> >> + * Copyright (c) 2015 embedded brains GmbH. All rights reserved.
> >> + * embedded brains GmbH
> >> + * Dornierstr. 4
> >> + * 82178 Puchheim
> >> + * Germany
> >> + * <rtems at embedded-brains.de>
> >> + * The license and distribution terms for this file may be
> >> + * found in the file LICENSE in this distribution or at
> >> + * http://www.rtems.org/license/LICENSE.
> >> +/dts-v1/;
> >> + compatible = "a,b";
> >> + #address-cells = <1>;
> >> + #size-cells = <2>;
> >> + model = "c";
> >> + d {
> >> + e = "f";
> >> + g;
> >> + h at 0 {
> >> + h at 1 {
> >> + w = <123>;
> >> + aliases {
> >> + k = "/m at 1248";
> >> + l: m at 1248 {
> >> + n = <0xdeadbeef 0x12345678>;
> >> + o {
> >> + p;
> >> + q {
> >> + r = "s";
> >> + t {
> >> + u = <&l>;
> >> diff --git a/testsuites/libtests/openfirmware01/some.h b/testsuites/libtests/openfirmware01/some.h
> >> index 0000000000..e2e0135e68
> >> --- /dev/null
> >> +++ b/testsuites/libtests/openfirmware01/some.h
> >> @@ -0,0 +1,15 @@
> >> + * Extern declarations for C structure representing binary file some.bin
> >> +#ifndef __some_h
> >> +#define __some_h
> >> +extern const unsigned char some_bin[];
> >> +extern const size_t some_bin_size;
> >> +#endif
> >> 2.17.1
> > devel mailing list
> > devel at rtems.org
