[GSoC 2020]: Doubts related to testing for EPICS7+RTEMS5 (pc386) built using recipe.
Mritunjay Sharma
mritunjaysharma394 at gmail.com
Wed Jul 29 23:11:50 UTC 2020
Hello all!
I tried to work on the testing part and here's what I did as per my
understanding:
I went inside the epics built by RSB recipe and ran "make runtests".
It gave results somewhat like this:
"Base.t ........ ok
Breaktable.t .. ok
DBD.t ......... ok
Device.t ...... ok
Driver.t ...... ok
Function.t .... ok
Menu.t ........ ok
Recfield.t .... ok
Recordtype.t .. ok
Registrar.t ... ok
Variable.t .... ok
All tests successful.
Files=11, Tests=293, 1 wallclock secs ( 0.05 usr 0.00 sys + 0.40 cusr
0.06 csys = 0.51 CPU)
Result: PASS"
I also downloaded rtems-testing directory and tried to run simulator
using the tutorial here:
https://devel.rtems.org/wiki/Developer/Simulators/QEMU
However, I was encountered with this error when I entered:
```./sim-scripts/pc386 -i
~/development/rtems/kernels-5/pc-386/i386-rtems5/c/pc386/testsuites/samples/hello.exe```
Error: ```qemu-system-i386: Initialization of device ide-hd failed: Block
node is read-only```.
It is very much possible that I am following a wrong approach for testing.
I really look forward to you all to help me out with it and
also share some resources which can help me guide on what exactly I have
to proceed with ahead.
Thanks
Mritunjay
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200730/8b1aa4f3/attachment.html>
