[PATCH rtems-libbsd 2/2] wscript: add uninstall command
Vijay Kumar Banerjee vijay at rtems.org
Thu Jul 30 10:20:06 UTC 2020
 wscript | 5 ++++-
 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/wscript b/wscript
index 3ca9478e..74fc1f48 100644
--- a/wscript
+++ b/wscript
@@ -151,7 +151,7 @@ def bsp_init(ctx, env, contexts):
     # Transform the commands to per build variant commands
     commands = []
     for cmd in waflib.Options.commands:
-        if cmd.startswith(('build', 'clean', 'install')):
+        if cmd.startswith(('build', 'clean', 'install', 'uninstall')):
             for builder in builders:
                 commands += [str(cmd + '-' + builder)]
         else:
@@ -226,6 +226,9 @@ def configure(conf):
     update_builders(conf, conf.env.BUILDSET)
     rtems.configure(conf, bsp_configure)
+def test(bld):
+    rtems.test_uninstall(bld)
 def build(bld):
     rtems.build(bld)
     builders[bld.libbsd_buildset_name].build(bld)
2.21.1
