[PATCH] rtems/printer.h Fix build warnings -Wclass-memaccess
Thu Jul 30 15:22:12 UTC 2020
On 30/07/2020 15:59, Aschref Ben-Thabet wrote:
> From: Aschref Ben Thabet <aschref.ben-thabet at embedded-brains.de>
>   cpukit/include/rtems/printer.h | 2 +-
>   1 file changed, 1 insertion(+), 1 deletion(-)
> diff --git a/cpukit/include/rtems/printer.h b/cpukit/include/rtems/printer.h
> index dbd887221e..fc091ffda3 100644
> --- a/cpukit/include/rtems/printer.h
> +++ b/cpukit/include/rtems/printer.h
> @@ -130,7 +130,7 @@ static inline void rtems_printer_task_initialize(
>     rtems_printer_task_context *context
> -  memset( context, 0, sizeof( *context ) );
Could you please also add a comment which explains why this void * cast
is there, e.g.
/* Some C++ compiler think that the structure is complex enough to need
a proper constructor. Cast to void * to silence a warning. */
> +  memset( (void*) context, 0, sizeof( *context ) );
Spacing: (void *) context
>   static inline void rtems_printer_task_set_stack_size(
