Thread 2: Need help in understanding exisiting RTEMS code
Gedare Bloom
gedare at rtems.org
Thu Jul 30 16:02:34 UTC 2020
On Thu, Jul 30, 2020 at 7:30 AM Richi Dubey <richidubey at gmail.com> wrote:
> I request someone to help me with my earlier question: https://lists.rtems.org/pipermail/devel/2020-July/060615.html since I may reuse this logic of variable-sized arrays.
I guess I'll answer here..
rtems$ ack Scheduler_EDF_SMP_Context
cpukit/score/src/scheduleredfsmp.c
24:static inline Scheduler_EDF_SMP_Context *
27: return (Scheduler_EDF_SMP_Context *) _Scheduler_Get_context( scheduler );
30:static inline Scheduler_EDF_SMP_Context *
33: return (Scheduler_EDF_SMP_Context *) context;
63: Scheduler_EDF_SMP_Context *self =
100: Scheduler_EDF_SMP_Context *self = _Scheduler_EDF_SMP_Get_self( context );
121: Scheduler_EDF_SMP_Context *self,
143: Scheduler_EDF_SMP_Context *self;
192: Scheduler_EDF_SMP_Context *self,
201: const Scheduler_EDF_SMP_Context *self,
220: Scheduler_EDF_SMP_Context *self;
241: Scheduler_EDF_SMP_Context *self;
284: Scheduler_EDF_SMP_Context *self;
307: Scheduler_EDF_SMP_Context *self;
370: Scheduler_EDF_SMP_Context *self;
586: Scheduler_EDF_SMP_Context *self;
cpukit/include/rtems/score/scheduleredfsmp.h
106:} Scheduler_EDF_SMP_Context;
cpukit/include/rtems/scheduler.h
133: Scheduler_EDF_SMP_Context Base; \
That last one is part of an allocation.
> Thank you.
> On Sat, Jul 18, 2020 at 6:29 PM Richi Dubey <richidubey at gmail.com> wrote:
>> This information helps. Thank you.
>> On Fri, Jul 17, 2020 at 6:31 PM Sebastian Huber
>> <sebastian.huber at embedded-brains.de> wrote:
>> > On 17/07/2020 14:22, Richi Dubey wrote:
>> > > I found the line in the documentation: "Since the processor assignment
>> > > is independent of the thread priority the processor indices may move
>> > > from one state to the other."
>> > > This is true because the processor assignment is done by the scheduler
>> > > and it gets to choose whether to allocate the highest priority thread
>> > > or not. Right? So if it wants to allocate processor to the lowest
>> > > priority (max. priority number) thread, it can do so?
>> > Yes, the scheduler can use whatever criteria it wants to allocate a
>> > processor to the threads is manages.
>> > > How is the priority of a node different from the priority of its
>> > > thread? How do these two priorities relate to each other?
>> > A thread has not only one priority. It has at least one priority per
>> > scheduler instance. With the locking protocols it may also inherit
>> > priorities of other threads. A thread has a list of trees of trees of
>> > priorities.
> devel mailing list
> devel at rtems.org
