[PATCH 0/2] Add custom interrupt servers with tests
Sebastian Huber
Fri Jul 31 11:45:24 UTC 2020
This patch set is intended for the master branch. It adds two test
programs using the new build system as an example.
Sebastian Huber (2):
rtems: Add rtems_interrupt_server_build()
irqs01/smpirqs01: New tests
bsps/shared/irq/irq-server.c | 360 +++++++++++++------
cpukit/include/rtems/irq-extension.h | 124 ++++++-
spec/build/testsuites/libtests/grp.yml | 2 +
spec/build/testsuites/libtests/irqs01.yml | 19 +
spec/build/testsuites/smptests/grp.yml | 2 +
spec/build/testsuites/smptests/smpirqs01.yml | 20 ++
testsuites/libtests/irqs01/init.c | 294 +++++++++++++++
testsuites/libtests/irqs01/irqs01.doc | 16 +
testsuites/smptests/smpirqs01/init.c | 197 ++++++++++
testsuites/smptests/smpirqs01/smpirqs01.doc | 13 +
10 files changed, 918 insertions(+), 129 deletions(-)
create mode 100644 spec/build/testsuites/libtests/irqs01.yml
create mode 100644 spec/build/testsuites/smptests/smpirqs01.yml
create mode 100644 testsuites/libtests/irqs01/init.c
create mode 100644 testsuites/libtests/irqs01/irqs01.doc
create mode 100644 testsuites/smptests/smpirqs01/init.c
create mode 100644 testsuites/smptests/smpirqs01/smpirqs01.doc
2.26.2
