Thread 2: Need help in understanding exisiting RTEMS code
Fri Jul 31 15:29:52 UTC 2020
On Fri, Jul 31, 2020 at 5:48 AM Richi Dubey <richidubey at gmail.com> wrote:
> Thank you for your answer. I learned ack today and it is coming pretty handy along with cscope.
Note that 'grep' is more reliable, but takes a bit more time to run.
'ack' filters the files that it checks, so it can miss things
sometimes.
> On Thu, Jul 30, 2020 at 9:32 PM Gedare Bloom <gedare at rtems.org> wrote:
>> On Thu, Jul 30, 2020 at 7:30 AM Richi Dubey <richidubey at gmail.com> wrote:
>> > I request someone to help me with my earlier question: https://lists.rtems.org/pipermail/devel/2020-July/060615.html since I may reuse this logic of variable-sized arrays.
>> I guess I'll answer here..
>> rtems$ ack Scheduler_EDF_SMP_Context
>> cpukit/score/src/scheduleredfsmp.c
>> 24:static inline Scheduler_EDF_SMP_Context *
>> 27:  return (Scheduler_EDF_SMP_Context *) _Scheduler_Get_context( scheduler );
>> 30:static inline Scheduler_EDF_SMP_Context *
>> 33:  return (Scheduler_EDF_SMP_Context *) context;
>> 63:  Scheduler_EDF_SMP_Context *self =
>> 100:  Scheduler_EDF_SMP_Context *self = _Scheduler_EDF_SMP_Get_self( context );
>> 121:  Scheduler_EDF_SMP_Context *self,
>> 143:  Scheduler_EDF_SMP_Context *self;
>> 192:  Scheduler_EDF_SMP_Context *self,
>> 201:  const Scheduler_EDF_SMP_Context *self,
>> 220:    Scheduler_EDF_SMP_Context *self;
>> 241:  Scheduler_EDF_SMP_Context     *self;
>> 284:  Scheduler_EDF_SMP_Context     *self;
>> 307:  Scheduler_EDF_SMP_Context     *self;
>> 370:  Scheduler_EDF_SMP_Context     *self;
>> 586:  Scheduler_EDF_SMP_Context *self;
>> cpukit/include/rtems/score/scheduleredfsmp.h
>> 106:} Scheduler_EDF_SMP_Context;
>> cpukit/include/rtems/scheduler.h
>> 133:      Scheduler_EDF_SMP_Context Base; \
>> That last one is part of an allocation.
>> > Thank you.
>> > On Sat, Jul 18, 2020 at 6:29 PM Richi Dubey <richidubey at gmail.com> wrote:
>> >> This information helps. Thank you.
>> >> On Fri, Jul 17, 2020 at 6:31 PM Sebastian Huber
>> >> <sebastian.huber at embedded-brains.de> wrote:
>> >> > On 17/07/2020 14:22, Richi Dubey wrote:
>> >> > > I found the line in the documentation: "Since the processor assignment
>> >> > > is independent of the thread priority the processor indices may move
>> >> > > from one state to the other."
>> >> > > This is true because the processor assignment is done by the scheduler
>> >> > > and it gets to choose whether to allocate the highest priority thread
>> >> > > or not. Right? So if it wants to allocate processor to the lowest
>> >> > > priority (max. priority number) thread, it can do so?
>> >> > Yes, the scheduler can use whatever criteria it wants to allocate a
>> >> > processor to the threads is manages.
>> >> > > How is the priority of a node different from the priority of its
>> >> > > thread? How do these two priorities relate to each other?
>> >> > A thread has not only one priority. It has at least one priority per
>> >> > scheduler instance. With the locking protocols it may also inherit
>> >> > priorities of other threads. A thread has a list of trees of trees of
>> >> > priorities.
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
