[PATCH] Strict thread-stack isolation and thread-stack sharing.
Utkarsh Rai
utkarsh.rai60 at gmail.com
Fri Jul 31 17:12:27 UTC 2020
This patch provides thread-stack isolation and thread-stack sharing
mechanism for a POSIX thread.
- Thread stacks are isolated with read-only permission.
- We use mmap, shm_open for thread-stack sharing. For mechanism of
thread-stack sharing please refer to the related test.
.../realview-pbx-a9/mmu/bsp-set-mmu-attr.c | 77 +++++++++
bsps/shared/start/stackalloc.c | 19 ++-
.../libbsp/arm/realview-pbx-a9/Makefile.am | 3 +
c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am | 2 +-
cpukit/Makefile.am | 2 +
cpukit/headers.am | 3 +
cpukit/include/rtems/score/memoryprotection.h | 82 ++++++++++
cpukit/include/rtems/score/stackprotection.h | 151 ++++++++++++++++++
cpukit/include/rtems/score/thread.h | 8 +
cpukit/include/rtems/stackname.h | 71 ++++++++
cpukit/posix/src/mmap.c | 112 ++++++++++++-
cpukit/posix/src/shmwkspace.c | 24 +++
cpukit/rtems/src/stackname.c | 102 ++++++++++++
cpukit/score/cpu/arm/cpu.c | 2 +-
cpukit/score/cpu/arm/cpu_asm.S | 64 +++++++-
.../score/cpu/arm/include/rtems/score/cpu.h | 2 +-
cpukit/score/src/stackprotection.c | 108 +++++++++++++
cpukit/score/src/threadhandler.c | 6 +
cpukit/score/src/threadinitialize.c | 23 ++-
testsuites/psxtests/psx16/init.c | 2 +-
testsuites/samples/hello/init.c | 2 +-
.../samples/thread_stack_protection/init.c | 89 +++++++++++
.../thread_stack_protection.doc | 2 +
.../thread_stack_protection.scn | 19 +++
.../samples/thread_stack_sharing/init.c | 121 ++++++++++++++
25 files changed, 1078 insertions(+), 18 deletions(-)
create mode 100644 bsps/arm/realview-pbx-a9/mmu/bsp-set-mmu-attr.c
create mode 100644 cpukit/include/rtems/score/memoryprotection.h
create mode 100644 cpukit/include/rtems/score/stackprotection.h
create mode 100644 cpukit/include/rtems/stackname.h
create mode 100644 cpukit/rtems/src/stackname.c
create mode 100644 cpukit/score/src/stackprotection.c
create mode 100644 testsuites/samples/thread_stack_protection/init.c
create mode 100644 testsuites/samples/thread_stack_protection/thread_stack_protection.doc
create mode 100644 testsuites/samples/thread_stack_protection/thread_stack_protection.scn
create mode 100644 testsuites/samples/thread_stack_sharing/init.c
diff --git a/bsps/arm/realview-pbx-a9/mmu/bsp-set-mmu-attr.c b/bsps/arm/realview-pbx-a9/mmu/bsp-set-mmu-attr.c
new file mode 100644
index 0000000000..4924fbb973
--- /dev/null
+++ b/bsps/arm/realview-pbx-a9/mmu/bsp-set-mmu-attr.c
@@ -0,0 +1,77 @@
+#include <bsp/arm-cp15-start.h>
+#include <rtems/score/memoryprotection.h>
+#include <libcpu/arm-cp15.h>
+#include <rtems.h>
+static uint32_t translate_flags(uint32_t attr_flags)
+ uint32_t flags;
+ uint32_t memory_attribute;
+ * Access permission
+ memory_attribute = ( attr_flags & READ_WRITE ) | ( attr_flags & READ_ONLY ) |
+ ( attr_flags & NO_ACCESS );
+ switch (memory_attribute)
+ case READ_WRITE:
+ flags = ARMV7_MMU_READ_WRITE;
+ break;
+ case READ_ONLY:
+ flags = ARMV7_MMU_READ_ONLY;
+ break;
+ case NO_ACCESS:
+ default:
+ flags = 0;
+ break;
+ * Check for memory-cache operation
+ if( attr_flags & MEMORY_CACHED ) {
+ flags |= ARM_MMU_SECT_TEX_0 | ARM_MMU_SECT_C | ARM_MMU_SECT_B;
+ return flags;
+void _Memory_protection_Set_entries(uintptr_t begin, size_t size, uint32_t flags)
+ uintptr_t end;
+ rtems_interrupt_level irq_level;
+ uint32_t access_flags;
+ end = begin + size;
+ access_flags = translate_flags(flags);
+ * The ARM reference manual instructs to disable all the interrupts before
+ * setting up page table entries.
+ rtems_interrupt_disable(irq_level);
+ arm_cp15_set_translation_table_entries(begin, end, access_flags);
+ rtems_interrupt_enable(irq_level);
+void _Memory_protection_Unset_entries(uintptr_t begin, size_t size)
+ uintptr_t end;
+ access_flags = translate_flags(READ_ONLY);
\ No newline at end of file
diff --git a/bsps/shared/start/stackalloc.c b/bsps/shared/start/stackalloc.c
index f7cf7be0f1..777e57aac6 100644
--- a/bsps/shared/start/stackalloc.c
+++ b/bsps/shared/start/stackalloc.c
@@ -23,11 +23,15 @@
#include <bsp/stackalloc.h>
+#include <rtems/score/basedefs.h>
#include <rtems/score/heapimpl.h>
#include <bsp/linker-symbols.h>
+#define USE_THREAD_STACK_PROTECTION
static Heap_Control bsp_stack_heap;
void bsp_stack_allocate_init(size_t stack_space_size)
@@ -44,6 +48,15 @@ void *bsp_stack_allocate(size_t size)
void *stack = NULL;
+#if defined (USE_THREAD_STACK_PROTECTION)
+ * This is a temporary hack, we need to use _Heap_Allocate_aligned() but the heap
+ * intialization for bsp_stack_heap fails as bsp_section_stack_size is 0. See
+ * bsp_stack_allocate_init().
+ posix_memalign(&stack, 4096 , size);
+ _Memory_protection_Set_entries( stack, size, ( READ_ONLY | MEMORY_CACHED ) );
+#else
if (bsp_stack_heap.area_begin != 0) {
stack = _Heap_Allocate(&bsp_stack_heap, size);
@@ -51,15 +64,15 @@ void *bsp_stack_allocate(size_t size)
if (stack == NULL) {
stack = _Workspace_Allocate(size);
+#endif
return stack;
-void bsp_stack_free(void *stack)
+void bsp_stack_free(void *stack)
bool ok = _Heap_Free(&bsp_stack_heap, stack);
if (!ok) {
_Workspace_Free(stack);
diff --git a/c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am b/c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am
index d5549275be..24847c7b91 100644
--- a/c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am
+++ b/c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am
@@ -74,6 +74,9 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/clock/clock-a9mpcore.
librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/cache/cache-cp15.c
librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/shared/cache/cache-v7ar-disable-data.S
+#MMU
+librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/realview-pbx-a9/mmu/bsp-set-mmu-attr.c
# Start hooks
librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/realview-pbx-a9/start/bspstarthooks.c
diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am b/c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am
index cfd59475c2..34adebc503 100644
--- a/c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am
+++ b/c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am
@@ -85,4 +85,4 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/xilinx-zynq/start/bspstartmm
include $(srcdir)/../../../../../../bsps/shared/irq-sources.am
include $(srcdir)/../../../../../../bsps/shared/shared-sources.am
-include $(srcdir)/../../../../../../bsps/arm/xilinx-zynq/headers.am
+include $(srcdir)/../../../../../../bsps/arm/xilinx-zynq/headers.am
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index 51f38c84c7..3d50b884e2 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -779,6 +779,7 @@ librtemscpu_a_SOURCES += rtems/src/semrelease.c
librtemscpu_a_SOURCES += rtems/src/semsetpriority.c
librtemscpu_a_SOURCES += rtems/src/signalcatch.c
librtemscpu_a_SOURCES += rtems/src/signalsend.c
+librtemscpu_a_SOURCES += rtems/src/stackname.c
librtemscpu_a_SOURCES += rtems/src/status.c
librtemscpu_a_SOURCES += rtems/src/statustext.c
librtemscpu_a_SOURCES += rtems/src/statustoerrno.c
@@ -929,6 +930,7 @@ librtemscpu_a_SOURCES += score/src/schedulercbsgetserverid.c
librtemscpu_a_SOURCES += score/src/schedulercbssetparameters.c
librtemscpu_a_SOURCES += score/src/schedulercbsreleasejob.c
librtemscpu_a_SOURCES += score/src/schedulercbsunblock.c
+librtemscpu_a_SOURCES += score/src/stackprotection.c
librtemscpu_a_SOURCES += score/src/stackallocator.c
librtemscpu_a_SOURCES += score/src/pheapallocate.c
librtemscpu_a_SOURCES += score/src/pheapextend.c
diff --git a/cpukit/headers.am b/cpukit/headers.am
index fcf679f09d..57c90a665f 100644
--- a/cpukit/headers.am
+++ b/cpukit/headers.am
@@ -162,6 +162,7 @@ include_rtems_HEADERS += include/rtems/shellconfig.h
include_rtems_HEADERS += include/rtems/sparse-disk.h
include_rtems_HEADERS += include/rtems/spurious.h
include_rtems_HEADERS += include/rtems/stackchk.h
+include_rtems_HEADERS += include/rtems/stackname.h
include_rtems_HEADERS += include/rtems/status-checks.h
include_rtems_HEADERS += include/rtems/stdio-redirect.h
include_rtems_HEADERS += include/rtems/stringto.h
@@ -352,6 +353,7 @@ include_rtems_score_HEADERS += include/rtems/score/isr.h
include_rtems_score_HEADERS += include/rtems/score/isrlevel.h
include_rtems_score_HEADERS += include/rtems/score/isrlock.h
include_rtems_score_HEADERS += include/rtems/score/memory.h
+include_rtems_score_HEADERS += include/rtems/score/memoryprotection.h
include_rtems_score_HEADERS += include/rtems/score/mpci.h
include_rtems_score_HEADERS += include/rtems/score/mpciimpl.h
include_rtems_score_HEADERS += include/rtems/score/mppkt.h
@@ -405,6 +407,7 @@ include_rtems_score_HEADERS += include/rtems/score/smplockstats.h
include_rtems_score_HEADERS += include/rtems/score/smplockticket.h
include_rtems_score_HEADERS += include/rtems/score/stack.h
include_rtems_score_HEADERS += include/rtems/score/stackimpl.h
+include_rtems_score_HEADERS += include/rtems/score/stackprotection.h
include_rtems_score_HEADERS += include/rtems/score/states.h
include_rtems_score_HEADERS += include/rtems/score/statesimpl.h
include_rtems_score_HEADERS += include/rtems/score/status.h
diff --git a/cpukit/include/rtems/score/memoryprotection.h b/cpukit/include/rtems/score/memoryprotection.h
index 0000000000..cc01f8ba9b
--- /dev/null
+++ b/cpukit/include/rtems/score/memoryprotection.h
@@ -0,0 +1,82 @@
+ * @file
+ * @ingroup RTEMSScoreMemoryprotection
+ * @brief This file provodes APIs for high-level memory protection
+ * Copyright (C) 2020 Utkarsh Rai
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifndef _RTEMS_SCORE_MEMORYPROTECTION_H
+#define _RTEMS_SCORE_MEMORYPROTECTION_H
+#ifdef __cplusplus
+extern "C" {
+#endif
+#define NO_ACCESS 0x00
+#define READ_ONLY 0x01
+#define READ_WRITE 0x02
+#define MEMORY_CACHED 0x04
+ * @brief Define the memory access permission for the specified memory region
+ * @param begin_addr Beginning of the memory region
+ * @param size Size of the memory region
+ * @param flag Memory access flag
+ uintptr_t begin_addr,
+ size_t size,
+ uint32_t flag
+ * @brief Unset the memory access permission for the specified memory region
+ * This operation implicitly sets the specified memory region with 'NO_ACCESS'
+ * flag.
+ * @param begin_addr Begining of the memory region
+ size_t size
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/cpukit/include/rtems/score/stackprotection.h b/cpukit/include/rtems/score/stackprotection.h
index 0000000000..60893da008
--- /dev/null
+++ b/cpukit/include/rtems/score/stackprotection.h
@@ -0,0 +1,151 @@
+ * @file
+ * @ingroup RTEMSScoreStackprotection
+ * @brief Stackprotection API
+ * This include file provides the API for the management of protected thread-
+ * stacks
+ * COPYRIGHT (c) 2020 Utkarsh Rai.
+ * are met:
+#ifndef _RTEMS_SCORE_STACKPROTECTION_H
+#define _RTEMS_SCORE_STACKPROTECTION_H
+#if defined ( ASM )
+ #include <rtems/asm.h>
+#else
+ #include <rtems/score/basedefs.h>
+ #include <rtems/score/chainimpl.h>
+ #include <rtems/score/memoryprotection.h>
+ #include <rtems/score/stack.h>
+#endif
+#ifdef __cplusplus
+extern "C" {
+#endif
+#if !defined ( ASM )
+ * The following defines the attributes of a protected stack
+typedef struct
+ /** The stack address */
+ uintptr_t stack_address;
+ /** This is the stack size */
+ size_t size;
+ /** The pointer to the page table base */
+ uintptr_t page_table_base;
+ /**Memory flag for the alllocated/shared stack */
+} Stackprotection_Attr;
+ * The following defines the control block of a shared stack
+typedef struct
+ /** This is the chain node for tracking shared stacks */
+ Chain_Node node;
+ /** This is the attribute of a shared stack*/
+ Stackprotection_Attr Base;
+} Stackprotection_Shared_stack;
+ * The following defines the control block of an allocated stack
+typedef struct
+ /** The attribute of an allocated stack*/
+ /** The pointer to the attributes of a stack shared with the stack
+ * in question
+ Stackprotection_Shared_stack *shared_stacks;
+ * Name of the thread-stack
+ char *name;
+ * The chain control for tracking the shared stacks with the thread-stack in
+ * question.
+ Chain_Control shared_stack_control;
+} Stackprotection_Stack;
+ * @brief Share the stack of a stack with the specified thread.
+ * @param shared_address The stack to be shared
+ * @param target_address The stack with which to share
+ * @param flags The memory-access flag of the shared stack address
+void _Stackprotection_Share_stack(
+ Stackprotection_Stack *shared_stack,
+ Stackprotection_Stack *target_stack,
+ size_t shared_stack_size,
+ uint32_t flag
+ * @brief Swap out the executing shared stack from the page table during
+ * context switch
+ * The current method of switching the protected stack is to mark the switched
+ * out stack as 'NO ACCESS'
+ * @param excuting_stack Control block of the executing stack
+void _Stackprotection_Context_switch(
+ Stackprotection_Stack *executing_stack,
+ Stackprotection_Stack *heir_stack
+ * @brief Swap the restored shared stacks in the page table during context
+ * restoration
+ * We set the entries of the restored stack and mark all the remainig stacks as
+ * 'NO-ACCESS'.
+ * @param Control block of the restored stack
+void _Stackprotection_Context_restore(
+#endif /* !defined ( ASM ) */
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/cpukit/include/rtems/score/thread.h b/cpukit/include/rtems/score/thread.h
index 2e7380f99a..728292123a 100644
--- a/cpukit/include/rtems/score/thread.h
+++ b/cpukit/include/rtems/score/thread.h
@@ -34,6 +34,7 @@
#include <rtems/score/priority.h>
#include <rtems/score/schedulernode.h>
+#include <rtems/score/stackprotection.h>
#include <rtems/score/states.h>
#include <rtems/score/threadq.h>
#include <rtems/score/timestamp.h>
@@ -85,6 +86,8 @@ extern "C" {
#define RTEMS_SCORE_THREAD_ENABLE_SCHEDULER_CALLOUT
#if defined(RTEMS_DEBUG)
#define RTEMS_SCORE_THREAD_ENABLE_RESOURCE_COUNT
#endif
@@ -835,6 +838,11 @@ struct _Thread_Control {
/** This field contains the context of this thread. */
Context_Control Registers;
+ /** This is the control block of the protected stack. */
+ Stackprotection_Stack the_stack;
+#endif
#if ( CPU_HARDWARE_FP == TRUE ) || ( CPU_SOFTWARE_FP == TRUE )
/** This field points to the floating point context for this thread.
* If NULL, the thread is integer only.
diff --git a/cpukit/include/rtems/stackname.h b/cpukit/include/rtems/stackname.h
index 0000000000..bd59c98ef1
--- /dev/null
+++ b/cpukit/include/rtems/stackname.h
@@ -0,0 +1,71 @@
+ * @file
+ * @brief Stack name API
+ * are met:
+#ifndef _RTEMS_STACKNAME_H
+#define _RTEMS_STACKNAME_H
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * @defgroup
+ * @ingroup
+ * @brief Get the name of the provided stack address.
+ * @param name The name of the given stack address.
+ * @retval NULL @a stack_name is not present in the chain.
+ * @retval address @a stack_address.
+void *rtems_stack_address_get( char* name );
+ * @param stack_address The address of the given stack.
+ * @retval NULL @a stack_address is not present in the chain.
+ * @retval name @a stack_address name.
+char *rtems_stack_name_get( uintptr_t stack_address );
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/cpukit/posix/src/mmap.c b/cpukit/posix/src/mmap.c
index 176c6e4fe8..99c3ea4414 100644
--- a/cpukit/posix/src/mmap.c
+++ b/cpukit/posix/src/mmap.c
@@ -28,7 +28,49 @@
#include <rtems/posix/mmanimpl.h>
#include <rtems/posix/shmimpl.h>
+#if defined(USE_THREAD_STACK_PROTECTION)
+ Stackprotection_Stack *target_stack;
+ Stackprotection_Stack *shared_stack;
+static uint32_t mmap_flag_translate(int prot)
+ int prot_read;
+ int prot_write;
+ int memory_flag;
+ prot_read = (prot_read & PROT_READ) == PROT_READ;
+ prot_write = (prot_write & PROT_WRITE) == PROT_WRITE;
+ if(prot_read){
+ memory_flag |= ( READ_ONLY| MEMORY_CACHED );
+ if(prot_write) {
+ memory_flag |= ( READ_WRITE | MEMORY_CACHED );
+ return memory_flag;
+static bool get_target_thread_visitor(Thread_Control *the_thread, void* arg)
+ if(the_thread->Start.Initial_stack.area == arg) {
+ target_stack = &the_thread->the_stack;
+ return true;
+static bool get_shared_thread_visitor(Thread_Control *the_thread, void* arg)
+ shared_stack = &the_thread->the_stack;
+ return true;
+#endif
* mmap chain of mappings.
@@ -50,7 +92,10 @@ void *mmap(
bool map_private;
bool is_shared_shm;
int err;
+ uint32_t memory_flags;
+ uintptr_t shared_stack_address;
+#endif
map_fixed = (flags & MAP_FIXED) == MAP_FIXED;
map_anonymous = (flags & MAP_ANON) == MAP_ANON;
map_shared = (flags & MAP_SHARED) == MAP_SHARED;
@@ -64,26 +109,47 @@ void *mmap(
errno = EINVAL;
return MAP_FAILED;
+ * We cannot share a part of the stack, hence, offset cannot be zer
+ if(off == 0) {
+ errno = EINVAL;
+ return MAP_FAILED;
+#endif
* We can provide read, write and execute because the memory in RTEMS does
- * not normally have protections but we cannot hide access to memory.
+ * not normally have protections but we cannot hide access to memory. For
+ * thread-stack protection we can provide no-access option, but stacks are
+ * implicitly isolated and it makes no sense to specify no-access option for
+ * already isolated stacks.
if ( prot == PROT_NONE ) {
errno = ENOTSUP;
return MAP_FAILED;
+ * MAP_ANONYMOUS, MAP_PRIVATE and MAP_FIXED are not supported for thread-stack protection.
+ * We can only have MAP_SHARED.
+ if(map_anonymous || map_fixed || map_private || ~map_shared) {
+ errno = EINVAL;
+#else
* We can not normally provide restriction of write access. Reject any
* attempt to map without write permission, since we are not able to
* prevent a write from succeeding.
if ( PROT_WRITE != (prot & PROT_WRITE) ) {
errno = ENOTSUP;
return MAP_FAILED;
* Anonymous mappings must have file descriptor set to -1 and the offset
* set to 0. Shared mappings are not supported with Anonymous mappings at
@@ -93,7 +159,6 @@ void *mmap(
errno = EINVAL;
return MAP_FAILED;
* If MAP_ANON is declared without MAP_PRIVATE or MAP_SHARED,
* force MAP_PRIVATE
@@ -122,7 +187,7 @@ void *mmap(
/* Check for illegal addresses. Watch out for address wrap. */
if ( map_fixed ) {
- if ((uintptr_t)addr & PAGE_MASK) {
+ if ((uintptr_t)addr & PAGE_MASK) {
errno = EINVAL;
return MAP_FAILED;
@@ -185,7 +250,39 @@ void *mmap(
return MAP_FAILED;
+#endif
+#if defined ( USE_THREAD_STACK_PROTECTION )
+ memory_flags = mmap_flag_translate( prot );
+ * We need to open a shared memory object for sharing stack.
+ if ( S_ISREG( sb.st_mode ) || S_ISBLK( sb.st_mode ) ||
+ S_ISCHR( sb.st_mode ) || S_ISFIFO( sb.st_mode ) ||
+ S_ISSOCK( sb.st_mode ) ) {
+ errno = EINVAL;
+ err = (*iop->pathinfo.handlers->mmap_h)(
+ iop, &shared_stack_address, len, prot, off );
+ if(err != 0) {
+ * We obtain the thread stack attributes of the target thread and the sharing
+ * thread, based on their addresses.
+ rtems_task_iterate(get_target_thread_visitor, addr);
+ rtems_task_iterate(get_shared_thread_visitor, shared_stack_address);
+ * Share the stack address od the sharing thread with the target thread.
+ _Stackprotection_Share_stack(addr, shared_stack_address, len, memory_flags);
+#else
/* Create the mapping */
mapping = malloc( sizeof( mmap_mapping ));
if ( !mapping ) {
@@ -299,4 +396,5 @@ void *mmap(
mmap_mappings_lock_release( );
return mapping->addr;
+#endif
diff --git a/cpukit/posix/src/shmwkspace.c b/cpukit/posix/src/shmwkspace.c
index 4fa4ec4771..aa46f000c0 100644
--- a/cpukit/posix/src/shmwkspace.c
+++ b/cpukit/posix/src/shmwkspace.c
@@ -18,12 +18,35 @@
+#include <rtems/stackname.h>
int _POSIX_Shm_Object_create_from_workspace(
POSIX_Shm_Object *shm_obj,
size_t size
+ POSIX_Shm_Control *shm;
+ shm = RTEMS_CONTAINER_OF(shm_obj, POSIX_Shm_Control, shm_object);
+ /** We assign fixed pattern of naming for thread-stacks, and treat them
+ * accordingly.
+ if( strncmp(shm->Object.name.name_p, "/taskfs/", 8) == 0 ) {
+ shm_obj->handle = rtems_stack_address_get(shm->Object.name.name_p);
+ shm_obj->size = size;
+ } else {
+ shm_obj->handle = _Workspace_Allocate( size );
+ if ( shm_obj->handle == NULL ) {
+ return ENOMEM;
+ return 0;
+#else
return ENOMEM;
@@ -32,6 +55,7 @@ int _POSIX_Shm_Object_create_from_workspace(
memset( shm_obj->handle, 0, size );
return 0;
+#endif
int _POSIX_Shm_Object_delete_from_workspace( POSIX_Shm_Object *shm_obj )
diff --git a/cpukit/rtems/src/stackname.c b/cpukit/rtems/src/stackname.c
index 0000000000..d3d58bef53
--- /dev/null
+++ b/cpukit/rtems/src/stackname.c
@@ -0,0 +1,102 @@
+ * @file
+ * @ingroup
+ * @brief RTEMS Stack name
+ * are met:
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <string.h>
+#include <rtems/score/objectimpl.h>
+#include <rtems/score/thread.h>
+#define USE_THREAD_STACK_PRTOECTION
+ * Address of the required stack
+void *stack_address;
+ * Name of the required stack
+char *stack_name;
+static bool stack_address_get_visitor(Thread_Control *the_thread, void *arg)
+ char* name;
+ name = arg;
+ if(name != NULL) {
+ if ( strcmp(name, the_thread->the_stack.name) == 0 ) {
+ stack_address = the_thread->the_stack.Base.stack_address;
+ return true;
+#endif
+static bool stack_name_get_visitor(Thread_Control *the_thread, void *arg)
+ void* address;
+ address = arg;
+ if( address != NULL) {
+ if ( address == the_thread->the_stack.Base.stack_address ) {
+ stack_name = the_thread->the_stack.name;
+ return true;
+#endif
+ rtems_task_iterate( stack_name_set_visitor, name );
+#endif
+ return stack_address;
+void *rtems_stack_name_get ( void* address )
+ rtems_task_iterate( stack_name_set_visitor, address );
+#endif
+return stack_name;
diff --git a/cpukit/score/cpu/arm/cpu.c b/cpukit/score/cpu/arm/cpu.c
index 07b9588afd..58f2830087 100644
--- a/cpukit/score/cpu/arm/cpu.c
+++ b/cpukit/score/cpu/arm/cpu.c
@@ -170,4 +170,4 @@ void _CPU_Initialize( void )
/* Do nothing */
-#endif /* ARM_MULTILIB_ARCH_V4 */
+#endif /* ARM_MULTILIB_ARCH_V4 */
diff --git a/cpukit/score/cpu/arm/cpu_asm.S b/cpukit/score/cpu/arm/cpu_asm.S
index 66f8ba6032..21ae761c97 100644
--- a/cpukit/score/cpu/arm/cpu_asm.S
+++ b/cpukit/score/cpu/arm/cpu_asm.S
@@ -66,6 +66,47 @@ DEFINE_FUNCTION_ARM(_CPU_Context_switch)
str r3, [r0, #ARM_CONTEXT_CONTROL_ISR_DISPATCH_DISABLE]
+ * We make a function call to set the memory attributes of the heir
+ * stack and unset that of the executing stack (including shared stacks ).
+ * This will be a simple asm code when done by switching the translation
+ * table base.
+/* Save the registers modified during function call */
+ mov r8, r0
+ mov r9, r1
+ mov r10, r2
+/* Load the parameters for function call */
+ ldr r0, [r1, #112]
+ ldr r1, [r1, #116]
+ mov r2, #6
+ bl _Memory_protection_Set_entries
+/* Restore the saved registers */
+ mov r0, r8
+ mov r1, r9
+ mov r2, r10
+/* We load the stack-pointer of the heir thread pre-maturely, this is
+ * done as oherwise the *_unset_entries call will execute from the stack of the
+ * executing thread causing fatal exceptions.
+ ldr sp, [r1, #32]
+/* Load the parameters of the function call */
+ ldr r1, [r0, #116]
+ ldr r0, [r0, #112]
+ bl _Memory_protection_Unset_entries
+ * Restore the saved registers
+ mov r0, r8
+ mov r1, r9
+ mov r2, r10
+#endif
#ifdef RTEMS_SMP
* The executing thread no longer executes on this processor. Switch
@@ -95,6 +136,26 @@ DEFINE_FUNCTION_ARM(_CPU_Context_switch)
/* Start restoring context */
.L_restore:
+ cmp r1, r0
+ beq .L_memory_entries_set
+.L_memory_entries_set:
+ mov r8, r0
+ mov r9, r1
+ mov r10, r2
+ mov r2, #6
+ mov r0, r8
+ mov r1, r9
+ mov r2, r10
+#endif
#if !defined(RTEMS_SMP) && defined(ARM_MULTILIB_HAS_LOAD_STORE_EXCLUSIVE)
clrex
#endif
@@ -133,6 +194,7 @@ DEFINE_FUNCTION_ARM(_CPU_Context_switch)
DEFINE_FUNCTION_ARM(_CPU_Context_restore)
mov r1, r0
GET_SELF_CPU_CONTROL r2
b .L_restore
@@ -162,4 +224,4 @@ DEFINE_FUNCTION_ARM(_CPU_Context_restore)
b .L_check_is_executing
#endif
diff --git a/cpukit/score/cpu/arm/include/rtems/score/cpu.h b/cpukit/score/cpu/arm/include/rtems/score/cpu.h
index b7b48a3ac3..214540b291 100644
--- a/cpukit/score/cpu/arm/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/arm/include/rtems/score/cpu.h
@@ -669,4 +669,4 @@ typedef uintptr_t CPU_Uint32ptr;
-#endif /* _RTEMS_SCORE_CPU_H */
+#endif /* _RTEMS_SCORE_CPU_H */
diff --git a/cpukit/score/src/stackprotection.c b/cpukit/score/src/stackprotection.c
index 0000000000..8ac0db96da
--- /dev/null
+++ b/cpukit/score/src/stackprotection.c
@@ -0,0 +1,108 @@
+ * @file
+ * are met:
+#endif
+ Chain_Node *node;
+ Chain_Control *shared_node_control;
+ Stackprotection_Shared_stack *shared_stack;
+ shared_node_control = &executing_stack->shared_stack_control;
+ if( shared_node_control != NULL) {
+ node = _Chain_Get_first_unprotected( shared_node_control );
+ while( _Chain_Is_tail(shared_node_control, node) == false) {
+ shared_stack = RTEMS_CONTAINER_OF( node, Stackprotection_Shared_stack, node);
+ _Memory_protection_Unset_entries( shared_stack->Base.stack_address, shared_stack->Base.size );
+ _Stackprotection_Context_restore( heir_stack );
+ Chain_Node *node;
+ uint32_t flags;
+ shared_node_control = &heir_stack->shared_stack_control;
+ flags = shared_stack->Base.access_flags;
+ _Memory_protection_Set_entries( shared_stack->Base.stack_address, shared_stack->Base.size, flags );
+ uint32_t flag
+ Chain_Control *control;
+ void* shared_address;
+ control = &target_stack->shared_stack_control;
+ shared_address = shared_stack->Base.stack_address;
+ shared_stack->shared_stacks->Base.access_flags = flag;
+ shared_stack->shared_stacks->Base.size = shared_stack_size;
+ shared_stack->shared_stacks->Base.stack_address = shared_address;
+ if( control != NULL) {
+ _Chain_Append_unprotected( control, &shared_stack->shared_stacks->node);
+ _Memory_protection_Set_entries(shared_address, shared_stack_size, flag);
diff --git a/cpukit/score/src/threadhandler.c b/cpukit/score/src/threadhandler.c
index acbe186a53..ec873a6b5a 100644
--- a/cpukit/score/src/threadhandler.c
+++ b/cpukit/score/src/threadhandler.c
@@ -22,6 +22,7 @@
#include <rtems/score/interr.h>
#include <rtems/score/isrlevel.h>
#include <rtems/score/userextimpl.h>
@@ -90,6 +91,11 @@ void _Thread_Handler( void )
level = executing->Start.isr_level;
_ISR_Set_level( level );
+ * Restore the shared thread-stacks
+ _Stackprotection_Context_restore( &executing->the_stack );
* Initialize the floating point context because we do not come
* through _Thread_Dispatch on our first invocation. So the normal
diff --git a/cpukit/score/src/threadinitialize.c b/cpukit/score/src/threadinitialize.c
index 691f56388e..7220e3cb5e 100644
--- a/cpukit/score/src/threadinitialize.c
+++ b/cpukit/score/src/threadinitialize.c
@@ -21,11 +21,19 @@
#include <rtems/score/stackimpl.h>
#include <rtems/score/tls.h>
#include <rtems/config.h>
+ #define STR( s ) #s
+ #define STACK_ADDRESS_NAME( stack_address ) "/taskfs/"STR( stack_address )
+#endif
bool _Thread_Initialize(
Thread_Information *information,
@@ -84,7 +92,7 @@ bool _Thread_Initialize(
stack_area = config->stack_area;
stack_size = config->stack_size;
/* Allocate floating-point context in stack area */
if ( config->is_fp ) {
@@ -113,6 +121,15 @@ bool _Thread_Initialize(
stack_area,
stack_size
+ * Initialize the protected stack attributes.
+ the_thread->the_stack.Base.stack_address = stack_area;
+ the_thread->the_stack.Base.size = stack_size;
+ the_thread->the_stack.Base.access_flags = ( READ_WRITE | MEMORY_CACHED );
+ the_thread->the_stack.name = STACK_ADDRESS_NAME( stack_area );
* Get thread queue heads
@@ -122,6 +139,7 @@ bool _Thread_Initialize(
_Thread_queue_Heads_initialize( the_thread->Wait.spare_heads );
* General initialization
@@ -131,6 +149,7 @@ bool _Thread_Initialize(
the_thread->Start.is_preemptible = config->is_preemptible;
the_thread->Start.budget_algorithm = config->budget_algorithm;
the_thread->Start.budget_callout = config->budget_callout;
+#endif
_Thread_Timer_initialize( &the_thread->Timer, cpu );
@@ -280,4 +299,4 @@ failed:
_Stack_Free( the_thread->Start.allocated_stack );
return false;
diff --git a/testsuites/psxtests/psx16/init.c b/testsuites/psxtests/psx16/init.c
index 8e20e6d376..a53c82de32 100644
--- a/testsuites/psxtests/psx16/init.c
+++ b/testsuites/psxtests/psx16/init.c
@@ -83,4 +83,4 @@ void *POSIX_Init(void *argument)
#define CONFIGURE_INIT
#include <rtems/confdefs.h>
-/* end of file */
+/* end of file */
diff --git a/testsuites/samples/hello/init.c b/testsuites/samples/hello/init.c
index 34ded37c55..850722cbd4 100644
--- a/testsuites/samples/hello/init.c
+++ b/testsuites/samples/hello/init.c
@@ -41,4 +41,4 @@ static rtems_task Init(
#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
-#include <rtems/confdefs.h>
+#include <rtems/confdefs.h>
diff --git a/testsuites/samples/thread_stack_protection/init.c b/testsuites/samples/thread_stack_protection/init.c
index 0000000000..76c7c25228
--- /dev/null
+++ b/testsuites/samples/thread_stack_protection/init.c
@@ -0,0 +1,89 @@
+#endif
+#include <rtems.h>
+#include <tmacros.h>
+#include <pthread.h>
+const char rtems_test_name[] = " THREAD STACK PROTECTION ";
+void* Test_routine( void* arg )
+void *POSIX_Init( void *argument )
+ void *stack_addr1;
+ void *stack_addr2;
+ size_t stack_size1;
+ size_t stack_size2;
+ pthread_t id1;
+ pthread_t id2;
+ pthread_attr_t attr1;
+ pthread_attr_t attr2;
+ TEST_BEGIN();
+ * We set the stack size as 8Kb.
+ stack_size1 = 8192;
+ stack_size2 = 8192;
+ * We allocate page-aligned memory of the stack from the application.
+ posix_memalign(&stack_addr1, sysconf( _SC_PAGESIZE ), stack_size1 );
+ posix_memalign(&stack_addr2, sysconf( _SC_PAGESIZE ), stack_size2 );
+ pthread_attr_init( &attr1 );
+ pthread_attr_init( &attr2 );
+ * We set the stack size and address of the thread from the application itself
+ pthread_attr_setstack( &attr1, stack_addr1, stack_size1 );
+ pthread_attr_setstack( &attr2, stack_addr2, stack_size2 );
+ pthread_create( &id1, &attr1, Test_routine, NULL );
+ pthread_create( &id2, &attr2, Test_routine, NULL );
+ * We set the memory attributes of the stack from the application.
+ _Memory_protection_Set_entries( stack_addr1, stack_size1, READ_ONLY | MEMORY_CACHED );
+ _Memory_protection_Set_entries( stack_addr2, stack_size2, READ_ONLY | MEMORY_CACHED );
+ pthread_join( id1, NULL );
+ * Write to the stack address of thread1 after it has been switched out.
+ memset( stack_addr1, 0, stack_size1 );
+ pthread_join( id2, NULL );
+ * Write to the stack address of thread2 after it has been switched out.
+ memset( stack_addr2, 0, stack_size2 );
+ TEST_END();
+ rtems_test_exit( 0 );
+/* configuration information */
+#define CONFIGURE_INIT
+#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_MAXIMUM_POSIX_THREADS 2
+#define CONFIGURE_POSIX_INIT_THREAD_TABLE
diff --git a/testsuites/samples/thread_stack_protection/thread_stack_protection.doc b/testsuites/samples/thread_stack_protection/thread_stack_protection.doc
index 0000000000..c5c9cdfa81
--- /dev/null
+++ b/testsuites/samples/thread_stack_protection/thread_stack_protection.doc
@@ -0,0 +1,2 @@
+This test sample demonstrates the thread stack protection functionality. We try
+to write to the stack of a switched-out thread.
diff --git a/testsuites/samples/thread_stack_protection/thread_stack_protection.scn b/testsuites/samples/thread_stack_protection/thread_stack_protection.scn
index 0000000000..ee69dbe627
--- /dev/null
+++ b/testsuites/samples/thread_stack_protection/thread_stack_protection.scn
@@ -0,0 +1,19 @@
+*** BEGIN OF TEST THREAD STACK PROTECTION ***
+*** TEST VERSION: 5.0.0.a3b39c9e567f3f1ef5ab01de78b113e61b11853b-modified
+*** TEST STATE: EXPECTED_PASS
+*** TEST BUILD: RTEMS_NETWORKING RTEMS_POSIX_API
+*** TEST TOOLS: 7.5.0 20191114 (RTEMS 5, RSB 5 (3bd11fd4898b), Newlib 7947581)
+Creating thread1
+Creating thread2
+Joining thread1
+Internal Exception Occured
diff --git a/testsuites/samples/thread_stack_sharing/init.c b/testsuites/samples/thread_stack_sharing/init.c
index 0000000000..4ed9592c8e
--- /dev/null
+++ b/testsuites/samples/thread_stack_sharing/init.c
@@ -0,0 +1,121 @@
+#endif
+#include <rtems.h>
+#include <mman.h>
+#include <sys/fcntl.h>
+const char rtems_test_name[] = " THREAD STACK SHARING ";
+ void* addr;
+ pthread_t id1;
+ pthread_t id2;
+ int fd;
+ char* name;
+ TEST_BEGIN();
+ * Obtain the name of the stack-address to be shared for allocating a shared
+ * memory object.
+ name = rtems_stack_name_get( stack_addr1 );
+ * Create a shared memory object of the stack we want to share with
+ * appropraite permissions. We share the stack with read and write permission
+ fd = shm_open( name, O_CREAT | O_RDWR, S_IRUSR | S_IWUSR );
+ * Truncate the size of the file to the size of the stack.
+ ftruncate( fd, stack_size1 );
+ * For sharing the stack we specify the address of the
+ * thread-stack we want to share with, the size of the shared stack,
+ * protection and access flags, file descriptor of the shared memory objcet
+ addr = mmap( stack_addr2, stack_size1, PROT_READ | PROT_WRITE, O_RDWR, fd, 0 );
+ rtems_test_assert( addr != NULL );
+ TEST_END();
2.17.1
