[PATCH v1 0/9] Enable SMP for pc386 based bsps
Mon Jun 1 20:58:24 UTC 2020
Thank you for taking the time and energy to do this. It
Did your patch comments close https://devel.rtems.org/ticket/3335?
On Sun, May 31, 2020 at 9:23 AM Jan Sommer <jan.sommer at dlr.de> wrote:
> Hello,
> Here is a patch set which should enable SMP again for the pc386-based BSPs
> (mainly tested with pc686).
> So far I only tested it with qemu. Tests on real hardware are pending.
> To me it looks like there are no regressions for the standard non-SMP
> version of the BSP, but it is difficult to say for sure.
> Subsequent runs of the testsuite with a current master build already
> produce different numbers of failed/timeout/invalid tests.
> However, even with the patch set applied the amount of passed tests
> continues to range from 550-557 and the failed/timeout/invalid tests seem
> to be generally the same.
> Regarding smptests, the current status with qemu-4.2.0 and 4 cores looks
> like this:
> Passed:        55
> Failed:         1
> User Input:     0
> Expected Fail:  0
> Indeterminate:  0
> Benchmark:      0
> Timeout:        2
> Invalid:        1
> Wrong Version:  0
> Wrong Build:    0
> Wrong Tools:    0
> Total:         59
> Failures:
>  smpatomic01.exe
> Timeouts:
>  smpclock01.exe
>  smpopenmp01.exe
> Invalid:
>  smpfatal09.exe
> Some details on the missing tests:
> smpfatal09: This test actually does pass, but because the fatal error
> handler is executed before the console is initialized, no output is
> produced.
> smpclock01.exe: Here CPU0 disables its local interrupts and waits for a
> barrier release of CPU1. This means it doesn't handle timer interrupts
> anymore and doesn't send corresponding IPIs to other CPUs.
> At the same time CPU1 is waiting for a timer event before releasing the
> barrier. Any hints how to resolve this are very welcome.
> smpatomic01: This test seems very large and a bit complicated to me. I
> will have a look at it next, but any suggestions are welcome. It fails with
> this information:
> ] === atomic or/and test case ===
> ] worker 0 value: 1
> ] worker 1 value: 0
> ] atomic value: expected = 1, actual = 1
> ../../../../../../smp-refex-rtems/c/src/../../testsuites/smptests/smpatomic01/init.c:
> 404 n - s < LONG_MAX
> ] *** FATAL ***
> smpopenmp01: I don't know more about openmp then what is on wikipedia. It
> has currently a low priority for me.
> Some details regarding the patch set:
> - The first 3 commits are basically cleaning the original start16.S to be
> used for starting the application processors only and updating the general
> bring up infrastructure.
> - The next 2 commits are updating the low level context switch and isr
> handling in assembly. I used the ARM implementation as a template and tried
> to stay comparably close to it.
> - The last 4 commits are smaller changes made after debugging certain test
> cases.
> My next step would be to test the SMP functionality on HW. My goal would
> be to get the final revision published as part of the RTEMS5 release.
> If you would like to see any logs from a testsuite run with certain
> parameters, just tell me.
> Best regards,
>     Jan
> Jan Sommer (9):
>   bsp/pc386: Fix Makefile for building with SMP
>   bsp/pc386: Turn start16.S into a startAP.S
>   bsp/pc386: Update GDT to work for SMP
>   bsp/pc386: Update context switch and restore
>   bsp/pc386: Define interrupt stack frame for smp
>   bsps/pc386: Fix Clock_isr for SMP
>   bsps/pc386: Separate smp API functions. Makes smpfatal08 link
>   smpsignal01: Change state before sending the signal
>   bsp/pc386: Disable interrupt nesting for job handler
>  bsps/i386/include/bsp/smp-imps.h                   |   3 +
>  bsps/i386/pc386/clock/ckinit.c                     |   2 +-
>  bsps/i386/pc386/include/bsp.h                      |   7 +
>  bsps/i386/pc386/include/bsp/tblsizes.h             |   8 +-
>  bsps/i386/pc386/start/bspsmp.c                     |  43 ++++
>  bsps/i386/pc386/start/getcpuid.c                   |  22 --
>  bsps/i386/pc386/start/ldsegs.S                     |   4 +-
>  bsps/i386/pc386/start/smp-imps.c                   |  79 ++++---
>  bsps/i386/pc386/start/start16.S                    | 254
>  bsps/i386/pc386/start/startAP.S                    | 118 ++++++++++
>  bsps/i386/shared/irq/irq_asm.S                     | 102 +++++----
>  c/src/lib/libbsp/i386/pc386/Makefile.am            |   8 +-
>  cpukit/score/cpu/i386/cpu_asm.S                    |  74 ++++--
>  cpukit/score/cpu/i386/include/rtems/asm.h          |  26 +++
>  cpukit/score/cpu/i386/include/rtems/score/cpu.h    |  32 +--
>  .../score/cpu/i386/include/rtems/score/cpuimpl.h   |   2 +
>  testsuites/smptests/smpsignal01/init.c             |   2 +-
>  17 files changed, 382 insertions(+), 404 deletions(-)
>  create mode 100644 bsps/i386/pc386/start/bspsmp.c
>  delete mode 100644 bsps/i386/pc386/start/getcpuid.c
>  delete mode 100644 bsps/i386/pc386/start/start16.S
>  create mode 100644 bsps/i386/pc386/start/startAP.S
> 2.12.3
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200601/caf05d19/attachment.html>
