libbsd fails to build on master for i386
Jeff Mayes Jeff.Mayes at OARcorp.com
Wed Jun 3 17:16:03 UTC 2020
Hi
On i386, the libbsd build (actually linking) fails on master branch.  FWIW, it succeeds on the FreeBSD branch.  Output below...
Thanks
Jeff
/home/mayes/dev/rtems/5/lib/gcc/i386-rtems5/7.5.0/../../../../i386-rtems5/bin/ld: ./libbsd.a(if_em.c.18.o):(.rodata.em_methods+0x2c): undefined reference to `iflib_device_suspend'
/home/mayes/dev/rtems/5/lib/gcc/i386-rtems5/7.5.0/../../../../i386-rtems5/bin/ld: ./libbsd.a(if_em.c.18.o):(.rodata.em_methods+0x34): undefined reference to `iflib_device_resume'
/home/mayes/dev/rtems/5/lib/gcc/i386-rtems5/7.5.0/../../../../i386-rtems5/bin/ld: ./libbsd.a(igb_txrx.c.18.o): in function `igb_isc_rxd_pkt_get':
/home/mayes/dev/rtems-libbsd/build/i386-rtems5-pc386-default/../../freebsd/sys/dev/e1000/igb_txrx.c:433: undefined reference to `iflib_get_ifp'
collect2: error: ld returned 1 exit status
Waf: Leaving directory `/home/mayes/dev/rtems-libbsd/build/i386-rtems5-pc386-default'
Build failed
-> task in 'arphole.exe' failed with exit status 1 (run with -v to display more information)
-> task in 'lagg01.exe' failed with exit status 1 (run with -v to display more information)
-> task in 'ping01.exe' failed with exit status 1 (run with -v to display more information)
-> task in 'evdev01.exe' failed with exit status 1 (run with -v to display more information)
-> task in 'pf01.exe' failed with exit status 1 (run with -v to display more information)
-> task in 'pf02.exe' failed with exit status 1 (run with -v to display more information)
-> task in 'dhcpcd02.exe' failed with exit status 1 (run with -v to display more information)
-> task in 'media01.exe' failed with exit status 1 (run with -v to display more information)
-> task in 'dhcpcd01.exe' failed with exit status 1 (run with -v to display more information)
-> task in 'nfs01.exe' failed with exit status 1 (run with -v to display more information)
-> task in 'foobarclient.exe' failed with exit status 1 (run with -v to display more information)
-> task in 'ppp01.exe' failed with exit status 1 (run with -v to display more information)
-> task in 'foobarserver.exe' failed with exit status 1 (run with -v to display more information)
-> task in 'ftpd01.exe' failed with exit status 1 (run with -v to display more information)
-> task in 'rcconf02.exe' failed with exit status 1 (run with -v to display more information)
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200603/e35f95b7/attachment.html>
