libbsd fails to build on PowerPC
Jeff Mayes
Jeff.Mayes at OARcorp.com
Wed Jun 3 17:20:46 UTC 2020
Hi,
libbsd fails to build on PowerPC on both the master branch and the FreeBSD branch. Output below...
Thanks
Jeff
[1207/1970] Compiling rtemsbsd/rtems/rtems-bsd-rc-conf-net.c
[1208/1970] Compiling freebsd/sys/crypto/blowfish/bf_ecb.c
In file included from /home/mayes/dev/rtems-powerpc/powerpc-rtems5/psim/lib/include/bsp.h:59:0,
from ../../freebsd/sys/arm/ti/ti_cpuid.h:35,
from ../../freebsd/sys/arm/ti/ti_scm.c:74:
/home/mayes/dev/rtems-powerpc/powerpc-rtems5/psim/lib/include/libcpu/io.h:53:20: error: redefinition of 'eieio'
static inline void eieio(void)
In file included from ../../freebsd/sys/sys/systm.h:45:0,
from ../../freebsd/sys/arm/ti/ti_scm.c:56:
../../freebsd/sys/powerpc/include/machine/cpufunc.h:168:1: note: previous definition of 'eieio' was here
eieio(void)
Waf: Leaving directory `/home/mayes/dev/rtems-libbsd/build/powerpc-rtems5-psim-default'
Build failed
-> task in 'bsd' failed with exit status 1 (run with -v to display more information)
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200603/9ff13fab/attachment.html>
