[PATCH 1/5] bsps/shared/freebsd: Import OFW files from FreeBSD.
Thu Jun 4 05:57:35 UTC 2020
On 4/6/20 3:22 pm, Sebastian Huber wrote:
> This approach avoids the need to actively register a device tree. This could
> simplify the low level startup a bit. The draw back is that it needs a special
> feature of the linker for the tests.
But we already use this feature and need it for the tests to link so does it
matter if it is used here?
