GSoC 2020: [rtems/rsb]: Error while adding ptp support. This time building for xilinx_zynq_a9_qemu
Mritunjay Sharma mritunjaysharma394 at gmail.com
Thu Jun 4 13:58:42 UTC 2020
On Thu, Jun 4, 2020 at 10:39 AM Chris Johns <chrisj at rtems.org> wrote:
> On 4/6/20 2:31 pm, Gedare Bloom wrote:
> > On Wed, Jun 3, 2020 at 1:53 PM Mritunjay Sharma
> > <mritunjaysharma394 at gmail.com> wrote:
> >> Hello everyone,
> >> As suggested by Heinz, I started building for xilinx_zynq_a9_qemu
> >> with a little modification in ptp cfg file.
> >> The netinet is no longer a problem here but another problem has come as
> follows:
> >> ../../ptpd-2.3.1/src/dep/startup.c: In function 'ptpdStartup':
> Is this from sourceforge?
Earlier I used from debian, today I tried with Sourceforge, but same error
still :(
> How does the ptpd-2.3.1 source code relate to the github repo
> https://github.com/ptpd/ptpd ?
> I have been referencing the github repo.
Yes, that's the repo that we are working with.
Mritunjay
> >> ../../ptpd-2.3.1/src/dep/startup.c:948:29: error: 'CPU_LEVEL_WHICH'
> undeclared (first use in this function)
> >>        if(cpuset_setaffinity(CPU_LEVEL_WHICH, CPU_WHICH_PID,
> >> ../../ptpd-2.3.1/src/dep/startup.c:948:46: error: 'CPU_WHICH_PID'
> > These are from BSD. This probably needs to be compiled with libbsd
> > somehow? or picking up its header files...
> In the github version this code is conditional on sys/cpuset.h being
> present.
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200604/cdb89fa5/attachment.html>
