[PATCH 3/5] libfreebsd: FreeBSD porting helper header
G S Niteesh Babu
niteesh.gs at gmail.com
Thu Jun 4 17:43:51 UTC 2020
This file serve the purpose as rtems-bsd-kernel-space.h in the
rtems-libbsd.
This file is intended to be included in every source file that
is to imported from FreeBSD. This is to reduce the number of
redefinitions for commonly used functions like malloc, free
and KASSERT.
cpukit/libfreebsd/rtems-freebsd-helper.h | 45 ++++++++++++++++++++++++
1 file changed, 45 insertions(+)
create mode 100644 cpukit/libfreebsd/rtems-freebsd-helper.h
diff --git a/cpukit/libfreebsd/rtems-freebsd-helper.h b/cpukit/libfreebsd/rtems-freebsd-helper.h
new file mode 100644
index 0000000000..1b9b7609f9
--- /dev/null
+++ b/cpukit/libfreebsd/rtems-freebsd-helper.h
@@ -0,0 +1,45 @@
+/* SPDX-License-Identifier: BSD-2-Clause
+ * @file
+ * @ingroup LIBFREEBSD
+ * @brief
+ * Copyright (C) <2020> Niteesh Babu <niteesh.gs at gmail.com>
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifndef _LIBFREEBSD_RTEMS_FREEBSD_HELPER_H
+#define _LIBFREEBSD_RTEMS_FREEBSD_HELPER_H
+#define _KERNEL 1
+#define KASSERT(cnd, msg) assert(cnd)
+#define malloc(size, type, flags) malloc(size)
+#define free(addr, type) free(addr)
+#endif /* _LIBFREEBSD_RTEMS_FREEBSD_HELPER_H */
\ No newline at end of file
2.17.1
