GSoC 2020: [rtems/rsb]: Error while adding ptp support. This time building for xilinx_zynq_a9_qemu
Mritunjay Sharma
mritunjaysharma394 at gmail.com
Thu Jun 4 18:29:40 UTC 2020
On Thu, Jun 4, 2020 at 11:07 PM Sebastian Huber <
> On 04/06/2020 16:22, Gedare Bloom wrote:
> >>> In the github version this code is conditional on sys/cpuset.h being
> present.
> > Well, we do have a sys/cpuset.h in newlib. It doesn't have these BSD
> > definitions though. Probably either:
> > 1. Add more stuff to sys/cpuset.h to make it support BSDisms. This
> > would mean adding cpuset_setaffinity support in rtems, I guess.
> > 2. Figure out how to disable the conditional code using the
> > cpuset_setaffinity function.
> The <sys/cpuset.h> is already as compatible as possible to glibc and
> FreeBSD. There is always room for improvement, however, in this area it
> will be difficult.
Please it would be kind of you all to guide on what is the best thing I can
do next. It is looking
a little difficult. If something similar has been done earlier, sharing it
can be a lot helpful to take a cue.
Mritunjay
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200604/e17905a5/attachment.html>
