[PATCH] fenv aarch64 support
Eshan dhawan eshandhawan51 at gmail.com
Sat Jun 6 02:19:05 UTC 2020
The implementation files are taken forn FreeBSD.
All the Auto-Generated files have been removed.
The Patch is tested against RSB but there is no BSP
for aarch64 so running testsuite is not possible.
Signed-off-by: Eshan dhawan <eshandhawan51 at gmail.com>
 newlib/libc/machine/aarch64/machine/fenv-fp.h | 156 ++++++++++++++++++
 newlib/libc/machine/aarch64/sys/fenv.h        | 120 ++++++++++++++
 newlib/libm/machine/aarch64/Makefile.am       |  14 +-
 newlib/libm/machine/aarch64/feclearexcept.c   |   7 +
 newlib/libm/machine/aarch64/fegetenv.c        |   7 +
 newlib/libm/machine/aarch64/fegetexceptflag.c |   7 +
 newlib/libm/machine/aarch64/fegetround.c      |   7 +
 newlib/libm/machine/aarch64/feholdexcept.c    |   7 +
 newlib/libm/machine/aarch64/fenv.c            |  57 +++++++
 newlib/libm/machine/aarch64/feraiseexcept.c   |   7 +
 newlib/libm/machine/aarch64/fesetenv.c        |   7 +
 newlib/libm/machine/aarch64/fesetexceptflag.c |   7 +
 newlib/libm/machine/aarch64/fesetround.c      |   7 +
 newlib/libm/machine/aarch64/fetestexcept.c    |   7 +
 newlib/libm/machine/aarch64/feupdateenv.c     |   7 +
 15 files changed, 423 insertions(+), 1 deletion(-)
 create mode 100644 newlib/libc/machine/aarch64/machine/fenv-fp.h
 create mode 100644 newlib/libc/machine/aarch64/sys/fenv.h
 create mode 100644 newlib/libm/machine/aarch64/feclearexcept.c
 create mode 100644 newlib/libm/machine/aarch64/fegetenv.c
 create mode 100644 newlib/libm/machine/aarch64/fegetexceptflag.c
 create mode 100644 newlib/libm/machine/aarch64/fegetround.c
 create mode 100644 newlib/libm/machine/aarch64/feholdexcept.c
 create mode 100644 newlib/libm/machine/aarch64/fenv.c
 create mode 100644 newlib/libm/machine/aarch64/feraiseexcept.c
 create mode 100644 newlib/libm/machine/aarch64/fesetenv.c
 create mode 100644 newlib/libm/machine/aarch64/fesetexceptflag.c
 create mode 100644 newlib/libm/machine/aarch64/fesetround.c
 create mode 100644 newlib/libm/machine/aarch64/fetestexcept.c
 create mode 100644 newlib/libm/machine/aarch64/feupdateenv.c
diff --git a/newlib/libc/machine/aarch64/machine/fenv-fp.h b/newlib/libc/machine/aarch64/machine/fenv-fp.h
new file mode 100644
index 000000000..d8ec3fc76
--- /dev/null
+++ b/newlib/libc/machine/aarch64/machine/fenv-fp.h
@@ -0,0 +1,156 @@
+ * Copyright (c) 2004-2005 David Schultz <das at FreeBSD.ORG>
+ * All rights reserved.
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * $FreeBSD$
+__fenv_static __inline int
+feclearexcept(int __excepts)
+	fexcept_t __r;
+	__mrs_fpsr(__r);
+	__r &= ~__excepts;
+	__msr_fpsr(__r);
+	return (0);
+__fenv_static inline int
+fegetexceptflag(fexcept_t *__flagp, int __excepts)
+	fexcept_t __r;
+	__mrs_fpsr(__r);
+	*__flagp = __r & __excepts;
+	return (0);
+fesetexceptflag(const fexcept_t *__flagp, int __excepts)
+	fexcept_t __r;
+	__mrs_fpsr(__r);
+	__r |= *__flagp & __excepts;
+	__msr_fpsr(__r);
+	return (0);
+feraiseexcept(int __excepts)
+	fexcept_t __r;
+	__mrs_fpsr(__r);
+	__r |= __excepts;
+	__msr_fpsr(__r);
+	return (0);
+fetestexcept(int __excepts)
+	fexcept_t __r;
+	__mrs_fpsr(__r);
+	return (__r & __excepts);
+fegetround(void)
+	fenv_t __r;
+	__mrs_fpcr(__r);
+	return ((__r >> _ROUND_SHIFT) & _ROUND_MASK);
+fesetround(int __round)
+	fenv_t __r;
+	if (__round & ~_ROUND_MASK)
+		return (-1);
+	__mrs_fpcr(__r);
+	__r &= ~(_ROUND_MASK << _ROUND_SHIFT);
+	__r |= __round << _ROUND_SHIFT;
+	__msr_fpcr(__r);
+	return (0);
+fegetenv(fenv_t *__envp)
+	fenv_t __r;
+	__mrs_fpcr(__r);
+	*__envp = __r & _ENABLE_MASK;
+	__mrs_fpsr(__r);
+	*__envp |= __r & (FE_ALL_EXCEPT | (_ROUND_MASK << _ROUND_SHIFT));
+	return (0);
+feholdexcept(fenv_t *__envp)
+	fenv_t __r;
+	__mrs_fpcr(__r);
+	__r &= ~(_ENABLE_MASK);
+	__msr_fpcr(__r);
+	__mrs_fpsr(__r);
+	__msr_fpsr(__r);
+	return (0);
+fesetenv(const fenv_t *__envp)
+	__msr_fpcr((*__envp) & _ENABLE_MASK);
+	__msr_fpsr((*__envp) & (FE_ALL_EXCEPT | (_ROUND_MASK << _ROUND_SHIFT)));
+	return (0);
+feupdateenv(const fenv_t *__envp)
+	fexcept_t __r;
+	__mrs_fpsr(__r);
+	fesetenv(__envp);
+	feraiseexcept(__r & FE_ALL_EXCEPT);
+	return (0);
diff --git a/newlib/libc/machine/aarch64/sys/fenv.h b/newlib/libc/machine/aarch64/sys/fenv.h
index 000000000..6b0879269
--- /dev/null
+++ b/newlib/libc/machine/aarch64/sys/fenv.h
@@ -0,0 +1,120 @@
+ * are met:
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef	_FENV_H_
+#define	_FENV_H_
+#include <sys/_types.h>
+#ifndef	__fenv_static
+#define	__fenv_static	static
+#endif
+typedef	__uint64_t	fenv_t;
+typedef	__uint64_t	fexcept_t;
+/* Exception flags */
+#define	FE_INVALID	0x00000001
+#define	FE_DIVBYZERO	0x00000002
+#define	FE_OVERFLOW	0x00000004
+#define	FE_UNDERFLOW	0x00000008
+#define	FE_INEXACT	0x00000010
+#define	FE_ALL_EXCEPT	(FE_DIVBYZERO | FE_INEXACT | \
+			 FE_INVALID | FE_OVERFLOW | FE_UNDERFLOW)
+ * Rounding modes
+ * We can't just use the hardware bit values here, because that would
+ * make FE_UPWARD and FE_DOWNWARD negative, which is not allowed.
+#define	FE_TONEAREST	0x0
+#define	FE_UPWARD	0x1
+#define	FE_DOWNWARD	0x2
+#define	FE_TOWARDZERO	0x3
+#define	_ROUND_MASK	(FE_TONEAREST | FE_DOWNWARD | \
+			 FE_UPWARD | FE_TOWARDZERO)
+#define	_ROUND_SHIFT	22
+/* Default floating-point environment */
+extern const fenv_t	*_fe_dfl_env;
+#define	FE_DFL_ENV	_fe_dfl_env
+/* We need to be able to map status flag positions to mask flag positions */
+#define _FPUSW_SHIFT	8
+#define	_ENABLE_MASK	(FE_ALL_EXCEPT << _FPUSW_SHIFT)
+#define	__mrs_fpcr(__r)	__asm __volatile("mrs %0, fpcr" : "=r" (__r))
+#define	__msr_fpcr(__r)	__asm __volatile("msr fpcr, %0" : : "r" (__r))
+#define	__mrs_fpsr(__r)	__asm __volatile("mrs %0, fpsr" : "=r" (__r))
+#define	__msr_fpsr(__r)	__asm __volatile("msr fpsr, %0" : : "r" (__r))
+#if __BSD_VISIBLE
+/* We currently provide no external definitions of the functions below. */
+static inline int
+feenableexcept(int __mask)
+	fenv_t __old_r, __new_r;
+	__mrs_fpcr(__old_r);
+	__new_r = __old_r | ((__mask & FE_ALL_EXCEPT) << _FPUSW_SHIFT);
+	__msr_fpcr(__new_r);
+	return ((__old_r >> _FPUSW_SHIFT) & FE_ALL_EXCEPT);
+static inline int
+fedisableexcept(int __mask)
+	__new_r = __old_r & ~((__mask & FE_ALL_EXCEPT) << _FPUSW_SHIFT);
+static inline int
+fegetexcept(void)
+	fenv_t __r;
+	__mrs_fpcr(__r);
+	return ((__r & _ENABLE_MASK) >> _FPUSW_SHIFT);
+#endif /* __BSD_VISIBLE */
+#endif	/* !_FENV_H_ */
diff --git a/newlib/libm/machine/aarch64/Makefile.am b/newlib/libm/machine/aarch64/Makefile.am
index 752f65dd1..1025bc420 100644
--- a/newlib/libm/machine/aarch64/Makefile.am
+++ b/newlib/libm/machine/aarch64/Makefile.am
@@ -35,7 +35,19 @@ LIB_SOURCES = \
 	sf_nearbyint.c \
 	sf_rint.c \
 	sf_round.c \
-	sf_trunc.c
+	sf_trunc.c \
+	fenv.c \
+	feclearexcept.c \
+	fegetenv.c \
+	fegetexceptflag.c \
+	fegetround.c \
+	feholdexcept.c \
+	feraiseexcept.c \
+	fesetenv.c \
+	fesetexceptflag.c \
+	fesetround.c \
+	fetestexcept.c \
+	feupdateenv.c
 noinst_LIBRARIES = lib.a
 lib_a_SOURCES = $(LIB_SOURCES)
diff --git a/newlib/libm/machine/aarch64/feclearexcept.c b/newlib/libm/machine/aarch64/feclearexcept.c
index 000000000..8cbee7771
--- /dev/null
+++ b/newlib/libm/machine/aarch64/feclearexcept.c
@@ -0,0 +1,7 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * (c) Copyright 2019 Joel Sherrill <joel at rtems.org>
+#include "../../fenv/fenv_stub.c"
diff --git a/newlib/libm/machine/aarch64/fegetenv.c b/newlib/libm/machine/aarch64/fegetenv.c
--- /dev/null
+++ b/newlib/libm/machine/aarch64/fegetenv.c
@@ -0,0 +1,7 @@
diff --git a/newlib/libm/machine/aarch64/fegetexceptflag.c b/newlib/libm/machine/aarch64/fegetexceptflag.c
--- /dev/null
+++ b/newlib/libm/machine/aarch64/fegetexceptflag.c
@@ -0,0 +1,7 @@
diff --git a/newlib/libm/machine/aarch64/fegetround.c b/newlib/libm/machine/aarch64/fegetround.c
--- /dev/null
+++ b/newlib/libm/machine/aarch64/fegetround.c
@@ -0,0 +1,7 @@
diff --git a/newlib/libm/machine/aarch64/feholdexcept.c b/newlib/libm/machine/aarch64/feholdexcept.c
--- /dev/null
+++ b/newlib/libm/machine/aarch64/feholdexcept.c
@@ -0,0 +1,7 @@
diff --git a/newlib/libm/machine/aarch64/fenv.c b/newlib/libm/machine/aarch64/fenv.c
index 000000000..3ffe23441
--- /dev/null
+++ b/newlib/libm/machine/aarch64/fenv.c
@@ -0,0 +1,57 @@
+ * Copyright (c) 2004 David Schultz <das at FreeBSD.ORG>
+ * Copyright (c) 2013 Andrew Turner <andrew at FreeBSD.ORG>
+ * are met:
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#include <fenv.h>
+#include <machine/fenv-fp.h>
+ * Hopefully the system ID byte is immutable, so it's valid to use
+ * this as a default environment.
+#ifdef __GNUC_GNU_INLINE__
+#error "This file must be compiled with C99 'inline' semantics"
+#endif
+extern inline int feclearexcept(int __excepts);
+extern inline int fegetexceptflag(fexcept_t *__flagp, int __excepts);
+extern inline int fesetexceptflag(const fexcept_t *__flagp, int __excepts);
+extern inline int feraiseexcept(int __excepts);
+extern inline int fetestexcept(int __excepts);
+extern inline int fegetround(void);
+extern inline int fesetround(int __round);
+extern inline int fegetenv(fenv_t *__envp);
+extern inline int feholdexcept(fenv_t *__envp);
+extern inline int fesetenv(const fenv_t *__envp);
+extern inline int feupdateenv(const fenv_t *__envp);
+extern inline int feenableexcept(int __mask);
+extern inline int fedisableexcept(int __mask);
+extern inline int fegetexcept(void);
diff --git a/newlib/libm/machine/aarch64/feraiseexcept.c b/newlib/libm/machine/aarch64/feraiseexcept.c
--- /dev/null
+++ b/newlib/libm/machine/aarch64/feraiseexcept.c
@@ -0,0 +1,7 @@
diff --git a/newlib/libm/machine/aarch64/fesetenv.c b/newlib/libm/machine/aarch64/fesetenv.c
--- /dev/null
+++ b/newlib/libm/machine/aarch64/fesetenv.c
@@ -0,0 +1,7 @@
diff --git a/newlib/libm/machine/aarch64/fesetexceptflag.c b/newlib/libm/machine/aarch64/fesetexceptflag.c
--- /dev/null
+++ b/newlib/libm/machine/aarch64/fesetexceptflag.c
@@ -0,0 +1,7 @@
diff --git a/newlib/libm/machine/aarch64/fesetround.c b/newlib/libm/machine/aarch64/fesetround.c
--- /dev/null
+++ b/newlib/libm/machine/aarch64/fesetround.c
@@ -0,0 +1,7 @@
diff --git a/newlib/libm/machine/aarch64/fetestexcept.c b/newlib/libm/machine/aarch64/fetestexcept.c
--- /dev/null
+++ b/newlib/libm/machine/aarch64/fetestexcept.c
@@ -0,0 +1,7 @@
diff --git a/newlib/libm/machine/aarch64/feupdateenv.c b/newlib/libm/machine/aarch64/feupdateenv.c
--- /dev/null
+++ b/newlib/libm/machine/aarch64/feupdateenv.c
@@ -0,0 +1,7 @@
2.17.1
