[PATCH 2/5] libfreebsd: Added ofw_if.h
Christian Mauderer oss at c-mauderer.de
Sat Jun 6 11:50:35 UTC 2020
Some style comments:
On 04/06/2020 19:43, G S Niteesh Babu wrote:
> This file is the RTEMS implementation of ofw_if.h in FreeBSD. The
> ofw_if.h in FreeBSD is an autogenerated header file that maps the
> OF_function calls to their respective implementation. But in RTEMS
> this file maps the OF_functions directly to their FDT implementation.
>  cpukit/libfreebsd/dev/ofw/ofw_if.h | 63 ++++++++++++++++++++++++++++++
>  1 file changed, 63 insertions(+)
>  create mode 100644 cpukit/libfreebsd/dev/ofw/ofw_if.h
> diff --git a/cpukit/libfreebsd/dev/ofw/ofw_if.h b/cpukit/libfreebsd/dev/ofw/ofw_if.h
> new file mode 100644
> index 0000000000..7b9bcaa24a
> --- /dev/null
> +++ b/cpukit/libfreebsd/dev/ofw/ofw_if.h
> @@ -0,0 +1,63 @@
> +/* SPDX-License-Identifier: BSD-2-Clause
> + * @file
> + * @ingroup LIBFREEBSDOFW
> + * @brief Declaration of OFW functions.
> + * Copyright (C) <2020> Niteesh Babu <niteesh.gs at gmail.com>
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#ifndef _LIBFREEBSD_OFW_IF_H
> +#define _LIBFREEBSD_OFW_IF_H
> +#include <sys/types.h>
> +#include "openfirm.h"
> +typedef void*		ofw_t;
> +int OFW_INIT(ofw_t ofw_obj, void *cookie);
> +phandle_t OFW_PEER(ofw_t ofw_obj, phandle_t node);
> +phandle_t OFW_CHILD(ofw_t ofw_obj, phandle_t node);
> +phandle_t OFW_PARENT(ofw_t ofw_obj, phandle_t node);
> +phandle_t OFW_INSTANCE_TO_PACKAGE(ofw_t ofw_obj, ihandle_t instance);
> +ssize_t OFW_GETPROPLEN(ofw_t ofw_obj, phandle_t package, const char *propname);
> +ssize_t OFW_GETPROP(ofw_t ofw_obj, phandle_t package, const char *propname,
> +    void *buf, size_t buflen);
If we use FreeBSD Kernel style (which I would suggest for code that has
to do with FreeBSD) you should indent the second line one tab more. Means
ssize_t OFW_GETPROP(ofw_t ofw_obj, ...,
That is:
<1*tab><4*space>void *buf, size_t buflen);
Take a look at some FreeBSD headers for that. For example
rtems-libbsd/freebsd/sys/sys/rwlock.h.
> +int OFW_NEXTPROP(ofw_t ofw_obj, phandle_t package, const char *prev, char *buf,
> +    size_t size);
> +int OFW_SETPROP(ofw_t ofw_obj, phandle_t package, const char *propname,
> +    const void *buf, size_t len);
> +ssize_t OFW_CANON(ofw_t ofw_obj, const char *device, char *buf, size_t len);
> +phandle_t OFW_FINDDEVICE(ofw_t ofw_obj, const char *device);
> +ssize_t OFW_INSTANCE_TO_PATH(ofw_t ofw_obj, ihandle_t instance, char *buf,
> +    size_t len);
> +ssize_t OFW_PACKAGE_TO_PATH(ofw_t ofw_obj, phandle_t package, char *buf,
> +    size_t len);
> +#endif /* _LIBFREEBSD_OFW_IF_H */
