[PATCH 4/5] libfreebsd: Port OFW to RTEMS
Christian Mauderer
oss at c-mauderer.de
Sat Jun 6 12:10:34 UTC 2020
On 04/06/2020 19:43, G S Niteesh Babu wrote:
> The following files have been ported to RTEMS
> 1) openfirm.h
> 2) openfirm.c
> 3) ofw_fdt.c
> cpukit/libfreebsd/dev/ofw/ofw_fdt.c | 117 ++++++++++++++++++++++++++-
> cpukit/libfreebsd/dev/ofw/openfirm.c | 59 +++++++++++++-
> cpukit/libfreebsd/dev/ofw/openfirm.h | 18 +++++
> 3 files changed, 191 insertions(+), 3 deletions(-)
> diff --git a/cpukit/libfreebsd/dev/ofw/ofw_fdt.c b/cpukit/libfreebsd/dev/ofw/ofw_fdt.c
> index e4f72e8142..5341440789 100644
> --- a/cpukit/libfreebsd/dev/ofw/ofw_fdt.c
> +++ b/cpukit/libfreebsd/dev/ofw/ofw_fdt.c
> @@ -29,10 +29,13 @@
> * SUCH DAMAGE.
> +#ifndef __rtems__
> #include <sys/cdefs.h>
> __FBSDID("$FreeBSD$");
> +#endif /* __rtems__ */
> #include <sys/param.h>
> +#ifndef __rtems__
> #include <sys/kernel.h>
> #include <sys/malloc.h>
> #include <sys/systm.h>
> @@ -45,9 +48,18 @@ __FBSDID("$FreeBSD$");
> #include <dev/ofw/ofwvar.h>
> #include <dev/ofw/openfirm.h>
> #include <dev/ofw/ofw_bus_subr.h>
> #include "ofw_if.h"
I'm not really happy about lines starting with "-" in the porting
commits. I think we should apply the same rules like in libbsd: Only add
stuff. Exception: The one at the end of the file is OK (where git tells
you "\ No newline at end of file"). You can't really avoid that.
> +#ifdef __rtems__
> +#include <rtems.h>
> +#include <rtems/sysinit.h>
> +#include <libfdt.h>
> +#include <assert.h>
> +#include "openfirm.h"
> +#ifndef __rtems__
> #ifdef DEBUG
> #define debugf(fmt, args...) do { printf("%s(): ", __func__); \
> printf(fmt,##args); } while (0)
> @@ -63,6 +75,7 @@ __FBSDID("$FreeBSD$");
> #define FDT_MARVELL
> #endif
> #endif
> static int ofw_fdt_init(ofw_t, void *);
> static phandle_t ofw_fdt_peer(ofw_t, phandle_t);
> @@ -78,6 +91,7 @@ static ssize_t ofw_fdt_canon(ofw_t, const char *, char *, size_t);
> static phandle_t ofw_fdt_finddevice(ofw_t, const char *);
> static ssize_t ofw_fdt_instance_to_path(ofw_t, ihandle_t, char *, size_t);
> static ssize_t ofw_fdt_package_to_path(ofw_t, phandle_t, char *, size_t);
> +#ifndef __rtems__
> static int ofw_fdt_interpret(ofw_t, const char *, int, cell_t *);
> static ofw_method_t ofw_fdt_methods[] = {
> @@ -104,9 +118,11 @@ static ofw_def_t ofw_fdt = {
> 0
> OFW_DEF(ofw_fdt);
> static void *fdtp = NULL;
> +#ifndef __rtems__
> static int
> sysctl_handle_dtb(SYSCTL_HANDLER_ARGS)
> @@ -127,6 +143,24 @@ sysctl_register_fdt_oid(void *arg)
> sysctl_handle_dtb, "", "Device Tree Blob");
> SYSINIT(dtb_oid, SI_SUB_KMEM, SI_ORDER_ANY, sysctl_register_fdt_oid, NULL);
> +#else /* __rtems__ */
> +const void* bsp_fdt_get(void);
> +static void
> +ofw_init(void)
> + int rv;
> + const void *fdt;
> + fdt = bsp_fdt_get();
> + rv = ofw_fdt_init(NULL, fdt);
> + assert(rv == 0);
Is assert really the only error handling possible here? Asserts are
allways a bit difficult because they stop the entire system. In which
cases would it hit?
> +RTEMS_SYSINIT_ITEM(
> + ofw_init,
> + RTEMS_SYSINIT_BSP_START,
> + RTEMS_SYSINIT_ORDER_FIRST
> static int
> ofw_fdt_init(ofw_t ofw, void *data)
> @@ -297,7 +331,11 @@ ofw_fdt_getprop(ofw_t ofw, phandle_t package, const char *propname, void *buf,
> if (prop == NULL)
> return (-1);
> +#ifndef __rtems__
> bcopy(prop, buf, min(len, buflen));
> + memcpy(buf, prop, MIN(len, buflen));
> return (len);
> @@ -407,6 +445,7 @@ ofw_fdt_package_to_path(ofw_t ofw, phandle_t package, char *buf, size_t len)
> return (-1);
> +#ifndef __rtems__
> #if defined(FDT_MARVELL)
> static int
> ofw_fdt_fixup(ofw_t ofw)
> @@ -476,4 +515,78 @@ ofw_fdt_interpret(ofw_t ofw, const char *cmd, int nret, cell_t *retvals)
> #else
> return (0);
> #endif
> +#ifdef __rtems__
> +int OFW_INIT(ofw_t ofw_obj, void *cookie)
Again: Please use FreeBSD style. The return value should be on it's onw
line during the definition (not during declaration).
There should be one empty line if you have no local variables (I'm not
really consequent here too).
> + return ofw_fdt_init(ofw_obj, cookie);
And brackets around everything that is returned.
> +phandle_t OFW_PEER(ofw_t ofw_obj, phandle_t node)
> + return ofw_fdt_peer(ofw_obj, node);
> +phandle_t OFW_CHILD(ofw_t ofw_obj, phandle_t node)
> + return ofw_fdt_child(ofw_obj, node);
> +phandle_t OFW_PARENT(ofw_t ofw_obj, phandle_t node)
> + return ofw_fdt_parent(ofw_obj, node);
> +phandle_t OFW_INSTANCE_TO_PACKAGE(ofw_t ofw_obj, ihandle_t instance)
> + return ofw_fdt_instance_to_package(ofw_obj, instance);
> +ssize_t OFW_GETPROPLEN(ofw_t ofw_obj, phandle_t package, const char *propname)
> + return ofw_fdt_getproplen(ofw_obj, package, propname);
> +ssize_t OFW_GETPROP(ofw_t ofw_obj, phandle_t package, const char *propname,
> + void *buf, size_t buflen
> + return ofw_fdt_getprop(ofw_obj, package, propname, buf, buflen);
> +int OFW_NEXTPROP(ofw_t ofw_obj, phandle_t package, const char *prev, char *buf,
> + size_t size)
> + return ofw_fdt_nextprop(ofw_obj, package, prev, buf, size);
> +int OFW_SETPROP(ofw_t ofw_obj, phandle_t package, const char *propname,
> + const void *buf, size_t len)
> + return ofw_fdt_setprop(ofw_obj, package, propname, buf, len);
> +ssize_t OFW_CANON(ofw_t ofw_obj, const char *device, char *buf, size_t len)
> + return ofw_fdt_canon(ofw_obj, device, buf, len);
> +phandle_t OFW_FINDDEVICE(ofw_t ofw_obj, const char *device)
> + return ofw_fdt_finddevice(ofw_obj, device);
> +ssize_t OFW_INSTANCE_TO_PATH(ofw_t ofw_obj, ihandle_t instance, char *buf,
> + size_t len)
> + return ofw_fdt_instance_to_path(ofw_obj, instance, buf, len);
> +ssize_t OFW_PACKAGE_TO_PATH(ofw_t ofw_obj, phandle_t package, char *buf,
> + size_t len)
> + return ofw_fdt_package_to_path(ofw_obj, package, buf, len);
> diff --git a/cpukit/libfreebsd/dev/ofw/openfirm.c b/cpukit/libfreebsd/dev/ofw/openfirm.c
> index 50ebf2cf16..646c006e18 100644
> --- a/cpukit/libfreebsd/dev/ofw/openfirm.c
> +++ b/cpukit/libfreebsd/dev/ofw/openfirm.c
> @@ -57,27 +57,39 @@
> * ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
> +#ifndef __rtems__
Don't we have a sys/cdefs.h? Or is that from libbsd in my installation?
> #include "opt_platform.h"
> +#ifndef __rtems__
> #include <sys/lock.h>
> #include <sys/mutex.h>
> #include <sys/queue.h>
> #include <sys/endian.h>
> +#ifndef __rtems__
> #include <machine/stdarg.h>
> #include "ofw_if.h"
> +#ifdef __rtems__
Why do you need assert.h here?
> +#include "../../rtems-freebsd-helper.h"
> +#ifndef __rtems__
> static void OF_putchar(int c, void *arg);
> MALLOC_DEFINE(M_OFWPROP, "openfirm", "Open Firmware properties");
> @@ -85,7 +97,9 @@ MALLOC_DEFINE(M_OFWPROP, "openfirm", "Open Firmware properties");
> static ihandle_t stdout;
> static ofw_def_t *ofw_def_impl = NULL;
> static ofw_t ofw_obj;
> +#ifndef __rtems__
> static struct ofw_kobj ofw_kernel_obj;
> static struct kobj_ops ofw_kernel_kops;
> @@ -224,14 +238,18 @@ OF_install(char *name, int prio)
> return (FALSE);
> /* Initializer */
> int
> OF_init(void *cookie)
> +#ifndef __rtems__
> phandle_t chosen;
> int rv;
> +#ifndef __rtems__
> if (ofw_def_impl == NULL)
> return (-1);
> @@ -242,17 +260,21 @@ OF_init(void *cookie)
> kobj_class_compile_static(ofw_def_impl, &ofw_kernel_kops);
> kobj_init_static((kobj_t)ofw_obj, ofw_def_impl);
> rv = OFW_INIT(ofw_obj, cookie);
> +#ifndef __rtems__
> if ((chosen = OF_finddevice("/chosen")) != -1)
> if (OF_getencprop(chosen, "stdout", &stdout,
> sizeof(stdout)) == -1)
> stdout = -1;
> return (rv);
> +#ifndef __rtems__
> static void
> OF_putchar(int c, void *arg __unused)
> @@ -314,6 +336,7 @@ OF_interpret(const char *cmd, int nreturns, ...)
> return (status);
> * Device tree functions
> @@ -324,8 +347,10 @@ phandle_t
> OF_peer(phandle_t node)
> +#ifndef __rtems__
> return (0);
> return (OFW_PEER(ofw_obj, node));
> @@ -335,8 +360,10 @@ phandle_t
> OF_child(phandle_t node)
> +#ifndef __rtems__
> return (0);
> return (OFW_CHILD(ofw_obj, node));
> @@ -346,8 +373,10 @@ phandle_t
> OF_parent(phandle_t node)
> +#ifndef __rtems__
> return (0);
> return (OFW_PARENT(ofw_obj, node));
> @@ -357,8 +386,10 @@ phandle_t
> OF_instance_to_package(ihandle_t instance)
> +#ifndef __rtems__
> return (-1);
> return (OFW_INSTANCE_TO_PACKAGE(ofw_obj, instance));
> @@ -368,8 +399,10 @@ ssize_t
> OF_getproplen(phandle_t package, const char *propname)
> +#ifndef __rtems__
> return (-1);
> return (OFW_GETPROPLEN(ofw_obj, package, propname));
> @@ -387,8 +420,10 @@ ssize_t
> OF_getprop(phandle_t package, const char *propname, void *buf, size_t buflen)
> +#ifndef __rtems__
> return (-1);
> return (OFW_GETPROP(ofw_obj, package, propname, buf, buflen));
> @@ -532,8 +567,10 @@ int
> OF_nextprop(phandle_t package, const char *previous, char *buf, size_t size)
> +#ifndef __rtems__
> return (-1);
> return (OFW_NEXTPROP(ofw_obj, package, previous, buf, size));
> @@ -543,8 +580,10 @@ int
> OF_setprop(phandle_t package, const char *propname, const void *buf, size_t len)
> +#ifndef __rtems__
> return (-1);
> return (OFW_SETPROP(ofw_obj, package, propname, buf,len));
> @@ -554,8 +593,10 @@ ssize_t
> OF_canon(const char *device, char *buf, size_t len)
> +#ifndef __rtems__
> return (-1);
> return (OFW_CANON(ofw_obj, device, buf, len));
> @@ -565,8 +606,10 @@ phandle_t
> OF_finddevice(const char *device)
> +#ifndef __rtems__
> return (-1);
> return (OFW_FINDDEVICE(ofw_obj, device));
> @@ -576,8 +619,10 @@ ssize_t
> OF_instance_to_path(ihandle_t instance, char *buf, size_t len)
> +#ifndef __rtems__
> return (-1);
> return (OFW_INSTANCE_TO_PATH(ofw_obj, instance, buf, len));
> @@ -587,8 +632,10 @@ ssize_t
> OF_package_to_path(phandle_t package, char *buf, size_t len)
> +#ifndef __rtems__
> return (-1);
> return (OFW_PACKAGE_TO_PATH(ofw_obj, package, buf, len));
> @@ -626,14 +673,18 @@ OF_child_xref_phandle(phandle_t parent, phandle_t xref)
> phandle_t
> OF_node_from_xref(phandle_t xref)
> +#ifndef __rtems__
> struct xrefinfo *xi;
> phandle_t node;
> +#ifndef __rtems__
> if (xref_init_done) {
> if ((xi = xrefinfo_find(xref, FIND_BY_XREF)) == NULL)
> return (xref);
> return (xi->node);
> if ((node = OF_child_xref_phandle(OF_peer(0), xref)) == -1)
> return (xref);
> @@ -643,14 +694,18 @@ OF_node_from_xref(phandle_t xref)
> phandle_t
> OF_xref_from_node(phandle_t node)
> +#ifndef __rtems__
> phandle_t xref;
> +#ifndef __rtems__
> if ((xi = xrefinfo_find(node, FIND_BY_NODE)) == NULL)
> return (node);
> return (xi->xref);
> if (OF_getencprop(node, "phandle", &xref, sizeof(xref)) == -1 &&
> OF_getencprop(node, "ibm,phandle", &xref, sizeof(xref)) == -1 &&
> @@ -659,6 +714,7 @@ OF_xref_from_node(phandle_t node)
> return (xref);
> +#ifndef __rtems__
> device_t
> OF_device_from_xref(phandle_t xref)
> @@ -845,4 +901,5 @@ OF_exit()
> for (;;) /* just in case */
> diff --git a/cpukit/libfreebsd/dev/ofw/openfirm.h b/cpukit/libfreebsd/dev/ofw/openfirm.h
> index 74a7075367..00c0d4dd88 100644
> --- a/cpukit/libfreebsd/dev/ofw/openfirm.h
> +++ b/cpukit/libfreebsd/dev/ofw/openfirm.h
> @@ -63,7 +63,13 @@
> #define _DEV_OPENFIRM_H_
> #include <sys/types.h>
> +#ifndef __rtems__
> #include <machine/_bus.h>
> +#include <rtems.h>
Maybe I missed it but for what do you need libfdt.h here?
> * Prototypes for Open Firmware Interface Routines
> @@ -73,7 +79,12 @@ typedef uint32_t ihandle_t;
> typedef uint32_t phandle_t;
> typedef uint32_t pcell_t;
> +#ifdef __rtems__
> +typedef uint32_t cell_t;
> #ifdef _KERNEL
> +#ifndef __rtems__
> #include <machine/ofw_machdep.h>
> @@ -86,8 +97,10 @@ MALLOC_DECLARE(M_OFWPROP);
> boolean_t OF_install(char *name, int prio);
> +#endif /* __rtems__*/
> int OF_init(void *cookie);
> +#ifndef __rtems__
> * Known Open Firmware interface names
> @@ -100,6 +113,7 @@ int OF_init(void *cookie);
> /* Generic functions */
> int OF_test(const char *name);
> void OF_printf(const char *fmt, ...);
> /* Device tree functions */
> phandle_t OF_peer(phandle_t node);
> @@ -141,6 +155,7 @@ ssize_t OF_package_to_path(phandle_t node, char *buf, size_t len);
> phandle_t OF_node_from_xref(phandle_t xref);
> phandle_t OF_xref_from_node(phandle_t node);
> +#ifndef __rtems__
> * When properties contain references to other nodes using xref handles it is
> * often necessary to use interfaces provided by the driver for the referenced
> @@ -158,9 +173,11 @@ void OF_close(ihandle_t instance);
> ssize_t OF_read(ihandle_t instance, void *buf, size_t len);
> ssize_t OF_write(ihandle_t instance, const void *buf, size_t len);
> int OF_seek(ihandle_t instance, uint64_t where);
> phandle_t OF_instance_to_package(ihandle_t instance);
> ssize_t OF_instance_to_path(ihandle_t instance, char *buf, size_t len);
> +#ifndef __rtems__
> int OF_call_method(const char *method, ihandle_t instance,
> int nargs, int nreturns, ...);
> @@ -183,5 +200,6 @@ int OF_interpret(const char *cmd, int nreturns, ...);
> int OF_decode_addr(phandle_t dev, int regno, bus_space_tag_t *ptag,
> bus_space_handle_t *phandle, bus_size_t *sz);
> #endif /* _KERNEL */
> #endif /* _DEV_OPENFIRM_H_ */
