[PATCH v1 0/9] Enable SMP for pc386 based bsps
Wed Jun 10 13:50:27 UTC 2020
On 31/05/2020 16:22, Jan Sommer wrote:
> Some details on the missing tests:
> smpfatal09: This test actually does pass, but because the fatal error handler is executed before the console is initialized, no output is produced.
> smpclock01.exe: Here CPU0 disables its local interrupts and waits for a barrier release of CPU1. This means it doesn't handle timer interrupts anymore and doesn't send corresponding IPIs to other CPUs.
> At the same time CPU1 is waiting for a timer event before releasing the barrier. Any hints how to resolve this are very welcome.
This could be a Qemu timing issue.
> smpatomic01: This test seems very large and a bit complicated to me. I will have a look at it next, but any suggestions are welcome. It fails with this information:
> ] === atomic or/and test case ===
> ] worker 0 value: 1
> ] worker 1 value: 0
> ] atomic value: expected = 1, actual = 1
> ] ../../../../../../smp-refex-rtems/c/src/../../testsuites/smptests/smpatomic01/init.c: 404 n - s < LONG_MAX
> ] *** FATAL ***
This looks like a bug in smpatomic01. We need a better test case for
atomic_thread_fence().
> smpopenmp01: I don't know more about openmp then what is on wikipedia. It has currently a low priority for me.
This test should not fail. Could be also a Qemu issue.
