[PATCH 4/5] libfreebsd: Port OFW to RTEMS
Christian Mauderer oss at c-mauderer.de
Wed Jun 10 17:50:38 UTC 2020
On 10/06/2020 17:11, Niteesh G. S. wrote:
> On Sat, Jun 6, 2020 at 5:40 PM Christian Mauderer <oss at c-mauderer.de
> <mailto:oss at c-mauderer.de>> wrote:
>     On 04/06/2020 19:43, G S Niteesh Babu wrote:
>     > The following files have been ported to RTEMS
>     > 1) openfirm.h
>     > 2) openfirm.c
>     > 3) ofw_fdt.c
>     >  cpukit/libfreebsd/dev/ofw/ofw_fdt.c  | 117
>     >  cpukit/libfreebsd/dev/ofw/openfirm.c |  59 +++++++++++++-
>     >  cpukit/libfreebsd/dev/ofw/openfirm.h |  18 +++++
>     >  3 files changed, 191 insertions(+), 3 deletions(-)
>     > diff --git a/cpukit/libfreebsd/dev/ofw/ofw_fdt.c
>     b/cpukit/libfreebsd/dev/ofw/ofw_fdt.c
>     > index e4f72e8142..5341440789 100644
>     > --- a/cpukit/libfreebsd/dev/ofw/ofw_fdt.c
>     > +++ b/cpukit/libfreebsd/dev/ofw/ofw_fdt.c
>     > @@ -29,10 +29,13 @@
>     >   * SUCH DAMAGE.
>     > +#ifndef __rtems__
>     >  #include <sys/cdefs.h>
>     >  __FBSDID("$FreeBSD$");
>     > +#endif /* __rtems__ */
>     >  #include <sys/param.h>
>     > +#ifndef __rtems__
>     >  #include <sys/kernel.h>
>     >  #include <sys/malloc.h>
>     >  #include <sys/systm.h>
>     > @@ -45,9 +48,18 @@ __FBSDID("$FreeBSD$");
>     >  #include <dev/ofw/ofwvar.h>
>     >  #include <dev/ofw/openfirm.h>
>     >  #include <dev/ofw/ofw_bus_subr.h>
>     >  #include "ofw_if.h"
>     I'm not really happy about lines starting with "-" in the porting
>     commits. I think we should apply the same rules like in libbsd: Only add
>     stuff. Exception: The one at the end of the file is OK (where git tells
>     you "\ No newline at end of file"). You can't really avoid that.
> I fixed this.
>     > +#ifdef __rtems__
>     > +#include <rtems.h>
>     > +#include <rtems/sysinit.h>
>     > +#include <libfdt.h>
>     > +#include <assert.h>
>     > +#include "openfirm.h"
>     > +#ifndef __rtems__
>     >  #ifdef DEBUG
>     >  #define debugf(fmt, args...) do { printf("%s(): ", __func__);
>     >      printf(fmt,##args); } while (0)
>     > @@ -63,6 +75,7 @@ __FBSDID("$FreeBSD$");
>     >  #define FDT_MARVELL
>     >  #endif
>     >  #endif
>     >  static int ofw_fdt_init(ofw_t, void *);
>     >  static phandle_t ofw_fdt_peer(ofw_t, phandle_t);
>     > @@ -78,6 +91,7 @@ static ssize_t ofw_fdt_canon(ofw_t, const char
>     *, char *, size_t);
>     >  static phandle_t ofw_fdt_finddevice(ofw_t, const char *);
>     >  static ssize_t ofw_fdt_instance_to_path(ofw_t, ihandle_t, char *,
>     size_t);
>     >  static ssize_t ofw_fdt_package_to_path(ofw_t, phandle_t, char *,
>     size_t);
>     > +#ifndef __rtems__
>     >  static int ofw_fdt_interpret(ofw_t, const char *, int, cell_t *);
>     >  static ofw_method_t ofw_fdt_methods[] = {
>     > @@ -104,9 +118,11 @@ static ofw_def_t ofw_fdt = {
>     >       0
>     >  OFW_DEF(ofw_fdt);
>     >  static void *fdtp = NULL;
>     > +#ifndef __rtems__
>     >  static int
>     >  sysctl_handle_dtb(SYSCTL_HANDLER_ARGS)
>     > @@ -127,6 +143,24 @@ sysctl_register_fdt_oid(void *arg)
>     >           sysctl_handle_dtb, "", "Device Tree Blob");
>     >  SYSINIT(dtb_oid, SI_SUB_KMEM, SI_ORDER_ANY,
>     sysctl_register_fdt_oid, NULL);
>     > +#else /* __rtems__ */
>     > +const void* bsp_fdt_get(void);
>     > +static void
>     > +ofw_init(void)
>     > +     int rv;
>     > +     const void *fdt;
>     > +     fdt = bsp_fdt_get();
>     > +     rv = ofw_fdt_init(NULL, fdt);
>     > +     assert(rv == 0);
>     Is assert really the only error handling possible here? Asserts are
>     allways a bit difficult because they stop the entire system. In which
>     cases would it hit?
> The assert is reached when the FDT is not valid. The check is done
> using fdt_check_header. Shutting the system would be the only way
> right?
It's in a low level driver function and if it fails, there is most
likely much else to do. So OK.
> I agree to assert is not the right way to quit. Can we quit with
> a proper error code like BSP_FATAL_INVALID_FDT or do we have
> something like that already?
I don't know of an existing one. Maybe add one. But maybe start a new
group in the bsp/fatal.h and make that a LIBFREEBSD_FATAL_INVALID_FDT.
I'm sure there will be other cases too sooner or later.
>     > +RTEMS_SYSINIT_ITEM(
>     > +     ofw_init,
>     > +     RTEMS_SYSINIT_BSP_START,
>     > +     RTEMS_SYSINIT_ORDER_FIRST
>     >  static int
>     >  ofw_fdt_init(ofw_t ofw, void *data)
>     > @@ -297,7 +331,11 @@ ofw_fdt_getprop(ofw_t ofw, phandle_t package,
>     const char *propname, void *buf,
>     >       if (prop == NULL)
>     >               return (-1);
>     > +#ifndef __rtems__
>     >       bcopy(prop, buf, min(len, buflen));
>     > +     memcpy(buf, prop, MIN(len, buflen));
>     >       return (len);
>     > @@ -407,6 +445,7 @@ ofw_fdt_package_to_path(ofw_t ofw, phandle_t
>     package, char *buf, size_t len)
>     >       return (-1);
>     > +#ifndef __rtems__
>     >  #if defined(FDT_MARVELL)
>     >  static int
>     >  ofw_fdt_fixup(ofw_t ofw)
>     > @@ -476,4 +515,78 @@ ofw_fdt_interpret(ofw_t ofw, const char *cmd,
>     int nret, cell_t *retvals)
>     >  #else
>     >       return (0);
>     >  #endif
>     > +#ifdef __rtems__
>     > +int OFW_INIT(ofw_t ofw_obj, void *cookie)
>     Again: Please use FreeBSD style. The return value should be on it's onw
>     line during the definition (not during declaration).
>     There should be one empty line if you have no local variables (I'm not
>     really consequent here too).
>     > +     return ofw_fdt_init(ofw_obj, cookie);
>     And brackets around everything that is returned.
> I fixed all.
>     > +phandle_t OFW_PEER(ofw_t ofw_obj, phandle_t node)
>     > +     return ofw_fdt_peer(ofw_obj, node);
>     > +phandle_t OFW_CHILD(ofw_t ofw_obj, phandle_t node)
>     > +     return ofw_fdt_child(ofw_obj, node);
>     > +phandle_t OFW_PARENT(ofw_t ofw_obj, phandle_t node)
>     > +     return ofw_fdt_parent(ofw_obj, node);
>     > +phandle_t OFW_INSTANCE_TO_PACKAGE(ofw_t ofw_obj, ihandle_t instance)
>     > +     return ofw_fdt_instance_to_package(ofw_obj, instance);
>     > +ssize_t OFW_GETPROPLEN(ofw_t ofw_obj, phandle_t package, const
>     char *propname)
>     > +     return ofw_fdt_getproplen(ofw_obj, package, propname);
>     > +ssize_t OFW_GETPROP(ofw_t ofw_obj, phandle_t package, const char
>     *propname,
>     > +    void *buf, size_t buflen
>     > +     return ofw_fdt_getprop(ofw_obj, package, propname, buf, buflen);
>     > +int OFW_NEXTPROP(ofw_t ofw_obj, phandle_t package, const char
>     *prev, char *buf,
>     > +    size_t size)
>     > +     return ofw_fdt_nextprop(ofw_obj, package, prev, buf, size);
>     > +int OFW_SETPROP(ofw_t ofw_obj, phandle_t package, const char
>     *propname,
>     > +    const void *buf, size_t len)
>     > +     return ofw_fdt_setprop(ofw_obj, package, propname, buf, len);
>     > +ssize_t OFW_CANON(ofw_t ofw_obj, const char *device, char *buf,
>     size_t len)
>     > +     return ofw_fdt_canon(ofw_obj, device, buf, len);
>     > +phandle_t OFW_FINDDEVICE(ofw_t ofw_obj, const char *device)
>     > +     return ofw_fdt_finddevice(ofw_obj, device);
>     > +ssize_t OFW_INSTANCE_TO_PATH(ofw_t ofw_obj, ihandle_t instance,
>     char *buf,
>     > +    size_t len)
>     > +     return ofw_fdt_instance_to_path(ofw_obj, instance, buf, len);
>     > +ssize_t OFW_PACKAGE_TO_PATH(ofw_t ofw_obj, phandle_t package,
>     char *buf,
>     > +    size_t len)
>     > +     return ofw_fdt_package_to_path(ofw_obj, package, buf, len);
>     > diff --git a/cpukit/libfreebsd/dev/ofw/openfirm.c
>     b/cpukit/libfreebsd/dev/ofw/openfirm.c
>     > index 50ebf2cf16..646c006e18 100644
>     > --- a/cpukit/libfreebsd/dev/ofw/openfirm.c
>     > +++ b/cpukit/libfreebsd/dev/ofw/openfirm.c
>     > @@ -57,27 +57,39 @@
>     >   * ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
>     > +#ifndef __rtems__
>     Don't we have a sys/cdefs.h? Or is that from libbsd in my installation?
> It is not present in RTEMS but is present in newlib. What is this header
> used for? Do we really need it?
That header contains a lot of helper defines. Like variable attributes
and simmilar. I'm not sure why it was included in openfirm.c. But I
assume that the author of the file did include it for some reason. So if
we have it and the code compiles with the file: Why remove it. If it
makes problems but the code compiles without the file the #ifndef is OK.
>     >  #include "opt_platform.h"
>     > +#ifndef __rtems__
>     >  #include <sys/lock.h>
>     >  #include <sys/mutex.h>
>     >  #include <sys/queue.h>
>     >  #include <sys/endian.h>
>     > +#ifndef __rtems__
>     >  #include <machine/stdarg.h>
>     >  #include "ofw_if.h"
>     > +#ifdef __rtems__
>     Why do you need assert.h here?
> I missed it while cleaning.
>     > +#include "../../rtems-freebsd-helper.h"
>     > +#ifndef __rtems__
>     >  static void OF_putchar(int c, void *arg);
>     >  MALLOC_DEFINE(M_OFWPROP, "openfirm", "Open Firmware properties");
>     > @@ -85,7 +97,9 @@ MALLOC_DEFINE(M_OFWPROP, "openfirm", "Open
>     >  static ihandle_t stdout;
>     >  static ofw_def_t     *ofw_def_impl = NULL;
>     >  static ofw_t         ofw_obj;
>     > +#ifndef __rtems__
>     >  static struct ofw_kobj       ofw_kernel_obj;
>     >  static struct kobj_ops       ofw_kernel_kops;
>     > @@ -224,14 +238,18 @@ OF_install(char *name, int prio)
>     >       return (FALSE);
>     >  /* Initializer */
>     >  int
>     >  OF_init(void *cookie)
>     > +#ifndef __rtems__
>     >       phandle_t chosen;
>     >       int rv;
>     > +#ifndef __rtems__
>     >       if (ofw_def_impl == NULL)
>     >               return (-1);
>     > @@ -242,17 +260,21 @@ OF_init(void *cookie)
>     >       kobj_class_compile_static(ofw_def_impl, &ofw_kernel_kops);
>     >       kobj_init_static((kobj_t)ofw_obj, ofw_def_impl);
>     >       rv = OFW_INIT(ofw_obj, cookie);
>     > +#ifndef __rtems__
>     >       if ((chosen = OF_finddevice("/chosen")) != -1)
>     >               if (OF_getencprop(chosen, "stdout", &stdout,
>     >                   sizeof(stdout)) == -1)
>     >                       stdout = -1;
>     >       return (rv);
>     > +#ifndef __rtems__
>     >  static void
>     >  OF_putchar(int c, void *arg __unused)
>     > @@ -314,6 +336,7 @@ OF_interpret(const char *cmd, int nreturns, ...)
>     >       return (status);
>     >   * Device tree functions
>     > @@ -324,8 +347,10 @@ phandle_t
>     >  OF_peer(phandle_t node)
>     > +#ifndef __rtems__
>     >               return (0);
>     >       return (OFW_PEER(ofw_obj, node));
>     > @@ -335,8 +360,10 @@ phandle_t
>     >  OF_child(phandle_t node)
>     > +#ifndef __rtems__
>     >               return (0);
>     >       return (OFW_CHILD(ofw_obj, node));
>     > @@ -346,8 +373,10 @@ phandle_t
>     >  OF_parent(phandle_t node)
>     > +#ifndef __rtems__
>     >               return (0);
>     >       return (OFW_PARENT(ofw_obj, node));
>     > @@ -357,8 +386,10 @@ phandle_t
>     >  OF_instance_to_package(ihandle_t instance)
>     > +#ifndef __rtems__
>     >               return (-1);
>     >       return (OFW_INSTANCE_TO_PACKAGE(ofw_obj, instance));
>     > @@ -368,8 +399,10 @@ ssize_t
>     >  OF_getproplen(phandle_t package, const char *propname)
>     > +#ifndef __rtems__
>     >               return (-1);
>     >       return (OFW_GETPROPLEN(ofw_obj, package, propname));
>     > @@ -387,8 +420,10 @@ ssize_t
>     >  OF_getprop(phandle_t package, const char *propname, void *buf,
>     size_t buflen)
>     > +#ifndef __rtems__
>     >               return (-1);
>     >       return (OFW_GETPROP(ofw_obj, package, propname, buf, buflen));
>     > @@ -532,8 +567,10 @@ int
>     >  OF_nextprop(phandle_t package, const char *previous, char *buf,
>     size_t size)
>     > +#ifndef __rtems__
>     >               return (-1);
>     >       return (OFW_NEXTPROP(ofw_obj, package, previous, buf, size));
>     > @@ -543,8 +580,10 @@ int
>     >  OF_setprop(phandle_t package, const char *propname, const void
>     *buf, size_t len)
>     > +#ifndef __rtems__
>     >               return (-1);
>     >       return (OFW_SETPROP(ofw_obj, package, propname, buf,len));
>     > @@ -554,8 +593,10 @@ ssize_t
>     >  OF_canon(const char *device, char *buf, size_t len)
>     > +#ifndef __rtems__
>     >               return (-1);
>     >       return (OFW_CANON(ofw_obj, device, buf, len));
>     > @@ -565,8 +606,10 @@ phandle_t
>     >  OF_finddevice(const char *device)
>     > +#ifndef __rtems__
>     >               return (-1);
>     >       return (OFW_FINDDEVICE(ofw_obj, device));
>     > @@ -576,8 +619,10 @@ ssize_t
>     >  OF_instance_to_path(ihandle_t instance, char *buf, size_t len)
>     > +#ifndef __rtems__
>     >               return (-1);
>     >       return (OFW_INSTANCE_TO_PATH(ofw_obj, instance, buf, len));
>     > @@ -587,8 +632,10 @@ ssize_t
>     >  OF_package_to_path(phandle_t package, char *buf, size_t len)
>     > +#ifndef __rtems__
>     >               return (-1);
>     >       return (OFW_PACKAGE_TO_PATH(ofw_obj, package, buf, len));
>     > @@ -626,14 +673,18 @@ OF_child_xref_phandle(phandle_t parent,
>     phandle_t xref)
>     >  phandle_t
>     >  OF_node_from_xref(phandle_t xref)
>     > +#ifndef __rtems__
>     >       struct xrefinfo *xi;
>     >       phandle_t node;
>     > +#ifndef __rtems__
>     >       if (xref_init_done) {
>     >               if ((xi = xrefinfo_find(xref, FIND_BY_XREF)) == NULL)
>     >                       return (xref);
>     >               return (xi->node);
>     >       if ((node = OF_child_xref_phandle(OF_peer(0), xref)) == -1)
>     >               return (xref);
>     > @@ -643,14 +694,18 @@ OF_node_from_xref(phandle_t xref)
>     >  phandle_t
>     >  OF_xref_from_node(phandle_t node)
>     > +#ifndef __rtems__
>     >       phandle_t xref;
>     > +#ifndef __rtems__
>     >               if ((xi = xrefinfo_find(node, FIND_BY_NODE)) == NULL)
>     >                       return (node);
>     >               return (xi->xref);
>     >       if (OF_getencprop(node, "phandle", &xref, sizeof(xref)) == -1 &&
>     >           OF_getencprop(node, "ibm,phandle", &xref, sizeof(xref))
>     == -1 &&
>     > @@ -659,6 +714,7 @@ OF_xref_from_node(phandle_t node)
>     >       return (xref);
>     > +#ifndef __rtems__
>     >  device_t
>     >  OF_device_from_xref(phandle_t xref)
>     > @@ -845,4 +901,5 @@ OF_exit()
>     >       for (;;)                        /* just in case */
>     > diff --git a/cpukit/libfreebsd/dev/ofw/openfirm.h
>     b/cpukit/libfreebsd/dev/ofw/openfirm.h
>     > index 74a7075367..00c0d4dd88 100644
>     > --- a/cpukit/libfreebsd/dev/ofw/openfirm.h
>     > +++ b/cpukit/libfreebsd/dev/ofw/openfirm.h
>     > @@ -63,7 +63,13 @@
>     >  #define _DEV_OPENFIRM_H_
>     >  #include <sys/types.h>
>     > +#ifndef __rtems__
>     >  #include <machine/_bus.h>
>     > +#include <rtems.h>
>     Maybe I missed it but for what do you need libfdt.h here?
> Again, missed it while cleaning.
>     >   * Prototypes for Open Firmware Interface Routines
>     > @@ -73,7 +79,12 @@ typedef uint32_t   ihandle_t;
>     >  typedef uint32_t     phandle_t;
>     >  typedef uint32_t     pcell_t;
>     > +#ifdef __rtems__
>     > +typedef uint32_t     cell_t;
>     >  #ifdef _KERNEL
>     > +#ifndef __rtems__
>     >  #include <machine/ofw_machdep.h>
>     > @@ -86,8 +97,10 @@ MALLOC_DECLARE(M_OFWPROP);
>     >  boolean_t    OF_install(char *name, int prio);
>     > +#endif /* __rtems__*/
>     >  int          OF_init(void *cookie);
>     > +#ifndef __rtems__
>     >   * Known Open Firmware interface names
>     > @@ -100,6 +113,7 @@ int               OF_init(void *cookie);
>     >  /* Generic functions */
>     >  int          OF_test(const char *name);
>     >  void         OF_printf(const char *fmt, ...);
>     >  /* Device tree functions */
>     >  phandle_t    OF_peer(phandle_t node);
>     > @@ -141,6 +155,7 @@ ssize_t           OF_package_to_path(phandle_t
>     node, char *buf, size_t len);
>     >  phandle_t    OF_node_from_xref(phandle_t xref);
>     >  phandle_t    OF_xref_from_node(phandle_t node);
>     > +#ifndef __rtems__
>     >   * When properties contain references to other nodes using xref
>     handles it is
>     >   * often necessary to use interfaces provided by the driver for
>     the referenced
>     > @@ -158,9 +173,11 @@ void             OF_close(ihandle_t instance);
>     >  ssize_t              OF_read(ihandle_t instance, void *buf,
>     size_t len);
>     >  ssize_t              OF_write(ihandle_t instance, const void
>     *buf, size_t len);
>     >  int          OF_seek(ihandle_t instance, uint64_t where);
>     >  phandle_t    OF_instance_to_package(ihandle_t instance);
>     >  ssize_t              OF_instance_to_path(ihandle_t instance, char
>     *buf, size_t len);
>     > +#ifndef __rtems__
>     >  int          OF_call_method(const char *method, ihandle_t instance,
>     >                   int nargs, int nreturns, ...);
>     > @@ -183,5 +200,6 @@ int               OF_interpret(const char
>     *cmd, int nreturns, ...);
>     >  int          OF_decode_addr(phandle_t dev, int regno,
>     bus_space_tag_t *ptag,
>     >                   bus_space_handle_t *phandle, bus_size_t *sz);
>     >  #endif /* _KERNEL */
>     >  #endif /* _DEV_OPENFIRM_H_ */
