Help in figuring out score objects in RTEMS and ticket #3131
Utkarsh Rai utkarsh.rai60 at gmail.com
Thu Jun 11 00:34:33 UTC 2020
Hello,
For my GSoC project, user-configurable thread stack protection, I need to
track, allocate, and manipulate attributes of shared as well as protected
stacks. Dr.Gedare suggested that tracking them with score objects would be
a good idea. He also indicated a good place to start and understand
score objects would be through this ticket.
<https://devel.rtems.org/ticket/3131>
>From the information that I could find in docs, my understanding of score
objects is that they are a type of directive that
helps introduce modularity to RTEMS as various types of RTEMS objects like
message queues, semaphores, etc. can use the same set of directives for
allocation/deallocation and control of their object types.
Some of the examples of the implementation that I could find used
_Object_Iniitialize_information()
to initialize the object type, then _Object_Allocate()/Free()
allocate/de-allocate the object. Object_Id is used to control the object
type. My confusion is, how do we use object IDs to refer to and control the
allocated objects?
I also have some confusion in the above-mentioned ticket, it says-
'The mmap_h handler should construct a mapping object. A destructor is
currently missing. Maybe the mmap_h handler should use a flag to deal with
construction and destruction.'
 I am unclear as to how the mmap_h handler should precisely look like and
where should it be defined?
I would be grateful if you can provide some help in figuring this out.
Regards,
Utkarsh
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200611/1b945309/attachment-0001.html>
