[PATCH RTEMS v2 5/6] libfreebsd: Port OFW to RTEMS
Vijay Kumar Banerjee vijay at rtems.org
Sat Jun 13 13:00:28 UTC 2020
On Thu, Jun 11, 2020 at 5:53 PM G S Niteesh Babu <niteesh.gs at gmail.com> wrote:
> The following files have been ported to RTEMS
> 1) openfirm.h
> 2) openfirm.c
> 3) ofw_fdt.c
>  cpukit/libfreebsd/dev/ofw/ofw_fdt.c  | 146 ++++++++++++++++++++++++++-
>  cpukit/libfreebsd/dev/ofw/openfirm.c |  58 ++++++++++-
>  cpukit/libfreebsd/dev/ofw/openfirm.h |  17 ++++
>  3 files changed, 219 insertions(+), 2 deletions(-)
> diff --git a/cpukit/libfreebsd/dev/ofw/ofw_fdt.c b/cpukit/libfreebsd/dev/ofw/ofw_fdt.c
> index e4f72e8142..aba170d67a 100644
> --- a/cpukit/libfreebsd/dev/ofw/ofw_fdt.c
> +++ b/cpukit/libfreebsd/dev/ofw/ofw_fdt.c
> @@ -30,9 +30,12 @@
>  #include <sys/cdefs.h>
> +#ifndef __rtems__
>  __FBSDID("$FreeBSD$");
> +#endif /* __rtems__ */
>  #include <sys/param.h>
> +#ifndef __rtems__
>  #include <sys/kernel.h>
>  #include <sys/malloc.h>
>  #include <sys/systm.h>
> @@ -45,9 +48,20 @@ __FBSDID("$FreeBSD$");
>  #include <dev/ofw/ofwvar.h>
>  #include <dev/ofw/openfirm.h>
>  #include <dev/ofw/ofw_bus_subr.h>
>  #include "ofw_if.h"
> +#ifdef __rtems__
> +#include <rtems.h>
> +#include <rtems/sysinit.h>
> +#include <bsp/fatal.h>
> +#include <libfdt.h>
> +#include <assert.h>
> +#include "openfirm.h"
> +#ifndef __rtems__
>  #ifdef DEBUG
>  #define debugf(fmt, args...) do { printf("%s(): ", __func__);  \
>      printf(fmt,##args); } while (0)
> @@ -63,6 +77,7 @@ __FBSDID("$FreeBSD$");
>  #define FDT_MARVELL
>  #endif
>  #endif
>  static int ofw_fdt_init(ofw_t, void *);
>  static phandle_t ofw_fdt_peer(ofw_t, phandle_t);
> @@ -78,6 +93,7 @@ static ssize_t ofw_fdt_canon(ofw_t, const char *, char *, size_t);
>  static phandle_t ofw_fdt_finddevice(ofw_t, const char *);
>  static ssize_t ofw_fdt_instance_to_path(ofw_t, ihandle_t, char *, size_t);
>  static ssize_t ofw_fdt_package_to_path(ofw_t, phandle_t, char *, size_t);
> +#ifndef __rtems__
>  static int ofw_fdt_interpret(ofw_t, const char *, int, cell_t *);
>  static ofw_method_t ofw_fdt_methods[] = {
> @@ -104,9 +120,11 @@ static ofw_def_t ofw_fdt = {
>         0
>  OFW_DEF(ofw_fdt);
>  static void *fdtp = NULL;
> +#ifndef __rtems__
>  static int
>  sysctl_handle_dtb(SYSCTL_HANDLER_ARGS)
> @@ -127,6 +145,27 @@ sysctl_register_fdt_oid(void *arg)
>             sysctl_handle_dtb, "", "Device Tree Blob");
>  SYSINIT(dtb_oid, SI_SUB_KMEM, SI_ORDER_ANY, sysctl_register_fdt_oid, NULL);
> +#else /* __rtems__ */
> +const void* bsp_fdt_get(void);
Why is it declared here? The function declaration is in fdt.h which is
included in the libfdt.h
> +static void
> +ofw_init(void)
> +       int rv;
> +       const void *fdt;
> +       fdt = bsp_fdt_get();
> +       rv = ofw_fdt_init(NULL, fdt);
> +       /* Fatal if invalid FDT is provided */
> +       if (rv != 0)
> +               bsp_fatal(LIBFREEBSD_FATAL_INVALID_FDT);
> +RTEMS_SYSINIT_ITEM(
> +       ofw_init,
> +       RTEMS_SYSINIT_BSP_START,
> +       RTEMS_SYSINIT_ORDER_FIRST
>  static int
>  ofw_fdt_init(ofw_t ofw, void *data)
> @@ -297,7 +336,11 @@ ofw_fdt_getprop(ofw_t ofw, phandle_t package, const char *propname, void *buf,
>         if (prop == NULL)
>                 return (-1);
> +#ifndef __rtems__
>         bcopy(prop, buf, min(len, buflen));
> +       memcpy(buf, prop, MIN(len, buflen));
>         return (len);
> @@ -407,6 +450,7 @@ ofw_fdt_package_to_path(ofw_t ofw, phandle_t package, char *buf, size_t len)
>         return (-1);
> +#ifndef __rtems__
>  #if defined(FDT_MARVELL)
>  static int
>  ofw_fdt_fixup(ofw_t ofw)
> @@ -476,4 +520,104 @@ ofw_fdt_interpret(ofw_t ofw, const char *cmd, int nret, cell_t *retvals)
>  #else
>         return (0);
>  #endif
> \ No newline at end of file
> +#ifdef __rtems__
> +int
> +OFW_INIT(ofw_t ofw_obj, void *cookie)
> +       return (ofw_fdt_init(ofw_obj, cookie));
> +phandle_t
> +OFW_PEER(ofw_t ofw_obj, phandle_t node)
> +       return (ofw_fdt_peer(ofw_obj, node));
> +phandle_t
> +OFW_CHILD(ofw_t ofw_obj, phandle_t node)
> +       return (ofw_fdt_child(ofw_obj, node));
> +phandle_t
> +OFW_PARENT(ofw_t ofw_obj, phandle_t node)
> +       return (ofw_fdt_parent(ofw_obj, node));
> +phandle_t
> +OFW_INSTANCE_TO_PACKAGE(ofw_t ofw_obj, ihandle_t instance)
> +       return (ofw_fdt_instance_to_package(ofw_obj, instance));
> +ssize_t
> +OFW_GETPROPLEN(ofw_t ofw_obj, phandle_t package, const char *propname)
> +       return (ofw_fdt_getproplen(ofw_obj, package, propname));
> +ssize_t
> +OFW_GETPROP(ofw_t ofw_obj, phandle_t package, const char *propname,
> +    void *buf, size_t buflen
> +       return (ofw_fdt_getprop(ofw_obj, package, propname, buf, buflen));
> +int
> +OFW_NEXTPROP(ofw_t ofw_obj, phandle_t package, const char *prev, char *buf,
> +    size_t size)
> +       return (ofw_fdt_nextprop(ofw_obj, package, prev, buf, size));
> +int
> +OFW_SETPROP(ofw_t ofw_obj, phandle_t package, const char *propname,
> +    const void *buf, size_t len)
> +       return (ofw_fdt_setprop(ofw_obj, package, propname, buf, len));
> +ssize_t
> +OFW_CANON(ofw_t ofw_obj, const char *device, char *buf, size_t len)
> +       return (ofw_fdt_canon(ofw_obj, device, buf, len));
> +phandle_t
> +OFW_FINDDEVICE(ofw_t ofw_obj, const char *device)
> +       return (ofw_fdt_finddevice(ofw_obj, device));
> +ssize_t
> +OFW_INSTANCE_TO_PATH(ofw_t ofw_obj, ihandle_t instance, char *buf,
> +    size_t len)
> +       return (ofw_fdt_instance_to_path(ofw_obj, instance, buf, len));
> +ssize_t
> +OFW_PACKAGE_TO_PATH(ofw_t ofw_obj, phandle_t package, char *buf,
> +    size_t len)
> +       return (ofw_fdt_package_to_path(ofw_obj, package, buf, len));
> diff --git a/cpukit/libfreebsd/dev/ofw/openfirm.c b/cpukit/libfreebsd/dev/ofw/openfirm.c
> index 50ebf2cf16..e7a67cfd34 100644
> --- a/cpukit/libfreebsd/dev/ofw/openfirm.c
> +++ b/cpukit/libfreebsd/dev/ofw/openfirm.c
> @@ -58,26 +58,37 @@
> +#ifndef __rtems__
>  #include "opt_platform.h"
> +#ifndef __rtems__
>  #include <sys/lock.h>
>  #include <sys/mutex.h>
>  #include <sys/queue.h>
>  #include <sys/endian.h>
> +#ifndef __rtems__
>  #include <machine/stdarg.h>
>  #include "ofw_if.h"
> +#ifdef __rtems__
> +#include "../../rtems-freebsd-helper.h"
Can we add the file rtems-freebsd-helper.h in somewhere like
libfreebsd/include and install this header file? This will avoid
future confusions with the number of dots required and we can have
something like <libfreebsd/rtems-freebsd-helper.h>
> +#ifndef __rtems__
>  static void OF_putchar(int c, void *arg);
>  MALLOC_DEFINE(M_OFWPROP, "openfirm", "Open Firmware properties");
> @@ -85,7 +96,9 @@ MALLOC_DEFINE(M_OFWPROP, "openfirm", "Open Firmware properties");
>  static ihandle_t stdout;
>  static ofw_def_t       *ofw_def_impl = NULL;
>  static ofw_t           ofw_obj;
> +#ifndef __rtems__
>  static struct ofw_kobj ofw_kernel_obj;
>  static struct kobj_ops ofw_kernel_kops;
> @@ -224,14 +237,18 @@ OF_install(char *name, int prio)
>         return (FALSE);
>  /* Initializer */
>  int
>  OF_init(void *cookie)
> +#ifndef __rtems__
>         phandle_t chosen;
>         int rv;
> +#ifndef __rtems__
>         if (ofw_def_impl == NULL)
>                 return (-1);
> @@ -242,17 +259,21 @@ OF_init(void *cookie)
>         kobj_class_compile_static(ofw_def_impl, &ofw_kernel_kops);
>         kobj_init_static((kobj_t)ofw_obj, ofw_def_impl);
>         rv = OFW_INIT(ofw_obj, cookie);
> +#ifndef __rtems__
>         if ((chosen = OF_finddevice("/chosen")) != -1)
>                 if (OF_getencprop(chosen, "stdout", &stdout,
>                     sizeof(stdout)) == -1)
>                         stdout = -1;
>         return (rv);
> +#ifndef __rtems__
>  static void
>  OF_putchar(int c, void *arg __unused)
> @@ -314,6 +335,7 @@ OF_interpret(const char *cmd, int nreturns, ...)
>         return (status);
>   * Device tree functions
> @@ -324,8 +346,10 @@ phandle_t
>  OF_peer(phandle_t node)
> +#ifndef __rtems__
>                 return (0);
>         return (OFW_PEER(ofw_obj, node));
> @@ -335,8 +359,10 @@ phandle_t
>  OF_child(phandle_t node)
> +#ifndef __rtems__
>                 return (0);
>         return (OFW_CHILD(ofw_obj, node));
> @@ -346,8 +372,10 @@ phandle_t
>  OF_parent(phandle_t node)
> +#ifndef __rtems__
>                 return (0);
>         return (OFW_PARENT(ofw_obj, node));
> @@ -357,8 +385,10 @@ phandle_t
>  OF_instance_to_package(ihandle_t instance)
> +#ifndef __rtems__
>                 return (-1);
>         return (OFW_INSTANCE_TO_PACKAGE(ofw_obj, instance));
> @@ -368,8 +398,10 @@ ssize_t
>  OF_getproplen(phandle_t package, const char *propname)
> +#ifndef __rtems__
>                 return (-1);
>         return (OFW_GETPROPLEN(ofw_obj, package, propname));
> @@ -387,8 +419,10 @@ ssize_t
>  OF_getprop(phandle_t package, const char *propname, void *buf, size_t buflen)
> +#ifndef __rtems__
>                 return (-1);
>         return (OFW_GETPROP(ofw_obj, package, propname, buf, buflen));
> @@ -532,8 +566,10 @@ int
>  OF_nextprop(phandle_t package, const char *previous, char *buf, size_t size)
> +#ifndef __rtems__
>                 return (-1);
>         return (OFW_NEXTPROP(ofw_obj, package, previous, buf, size));
> @@ -543,8 +579,10 @@ int
>  OF_setprop(phandle_t package, const char *propname, const void *buf, size_t len)
> +#ifndef __rtems__
>                 return (-1);
>         return (OFW_SETPROP(ofw_obj, package, propname, buf,len));
> @@ -554,8 +592,10 @@ ssize_t
>  OF_canon(const char *device, char *buf, size_t len)
> +#ifndef __rtems__
>                 return (-1);
>         return (OFW_CANON(ofw_obj, device, buf, len));
> @@ -565,8 +605,10 @@ phandle_t
>  OF_finddevice(const char *device)
> +#ifndef __rtems__
>                 return (-1);
>         return (OFW_FINDDEVICE(ofw_obj, device));
> @@ -576,8 +618,10 @@ ssize_t
>  OF_instance_to_path(ihandle_t instance, char *buf, size_t len)
> +#ifndef __rtems__
>                 return (-1);
>         return (OFW_INSTANCE_TO_PATH(ofw_obj, instance, buf, len));
> @@ -587,8 +631,10 @@ ssize_t
>  OF_package_to_path(phandle_t package, char *buf, size_t len)
> +#ifndef __rtems__
>                 return (-1);
>         return (OFW_PACKAGE_TO_PATH(ofw_obj, package, buf, len));
> @@ -626,14 +672,18 @@ OF_child_xref_phandle(phandle_t parent, phandle_t xref)
>  phandle_t
>  OF_node_from_xref(phandle_t xref)
> +#ifndef __rtems__
>         struct xrefinfo *xi;
>         phandle_t node;
> +#ifndef __rtems__
>         if (xref_init_done) {
>                 if ((xi = xrefinfo_find(xref, FIND_BY_XREF)) == NULL)
>                         return (xref);
>                 return (xi->node);
>         if ((node = OF_child_xref_phandle(OF_peer(0), xref)) == -1)
>                 return (xref);
> @@ -643,14 +693,18 @@ OF_node_from_xref(phandle_t xref)
>  phandle_t
>  OF_xref_from_node(phandle_t node)
> +#ifndef __rtems__
>         phandle_t xref;
> +#ifndef __rtems__
>                 if ((xi = xrefinfo_find(node, FIND_BY_NODE)) == NULL)
>                         return (node);
>                 return (xi->xref);
>         if (OF_getencprop(node, "phandle", &xref, sizeof(xref)) == -1 &&
>             OF_getencprop(node, "ibm,phandle", &xref, sizeof(xref)) == -1 &&
> @@ -659,6 +713,7 @@ OF_xref_from_node(phandle_t node)
>         return (xref);
> +#ifndef __rtems__
>  device_t
>  OF_device_from_xref(phandle_t xref)
> @@ -845,4 +900,5 @@ OF_exit()
>         for (;;)                        /* just in case */
> diff --git a/cpukit/libfreebsd/dev/ofw/openfirm.h b/cpukit/libfreebsd/dev/ofw/openfirm.h
> index 74a7075367..b4f6bf292a 100644
> --- a/cpukit/libfreebsd/dev/ofw/openfirm.h
> +++ b/cpukit/libfreebsd/dev/ofw/openfirm.h
> @@ -63,7 +63,12 @@
>  #define _DEV_OPENFIRM_H_
>  #include <sys/types.h>
> +#ifndef __rtems__
>  #include <machine/_bus.h>
> +#include <rtems.h>
>   * Prototypes for Open Firmware Interface Routines
> @@ -73,7 +78,12 @@ typedef uint32_t     ihandle_t;
>  typedef uint32_t       phandle_t;
>  typedef uint32_t       pcell_t;
> +#ifdef __rtems__
> +typedef uint32_t       cell_t;
>  #ifdef _KERNEL
> +#ifndef __rtems__
>  #include <machine/ofw_machdep.h>
> @@ -86,8 +96,10 @@ MALLOC_DECLARE(M_OFWPROP);
>  boolean_t      OF_install(char *name, int prio);
> +#endif /* __rtems__*/
>  int            OF_init(void *cookie);
> +#ifndef __rtems__
>   * Known Open Firmware interface names
> @@ -100,6 +112,7 @@ int         OF_init(void *cookie);
>  /* Generic functions */
>  int            OF_test(const char *name);
>  void           OF_printf(const char *fmt, ...);
>  /* Device tree functions */
>  phandle_t      OF_peer(phandle_t node);
> @@ -141,6 +154,7 @@ ssize_t             OF_package_to_path(phandle_t node, char *buf, size_t len);
>  phandle_t      OF_node_from_xref(phandle_t xref);
>  phandle_t      OF_xref_from_node(phandle_t node);
> +#ifndef __rtems__
>   * When properties contain references to other nodes using xref handles it is
>   * often necessary to use interfaces provided by the driver for the referenced
> @@ -158,9 +172,11 @@ void               OF_close(ihandle_t instance);
>  ssize_t                OF_read(ihandle_t instance, void *buf, size_t len);
>  ssize_t                OF_write(ihandle_t instance, const void *buf, size_t len);
>  int            OF_seek(ihandle_t instance, uint64_t where);
>  phandle_t      OF_instance_to_package(ihandle_t instance);
>  ssize_t                OF_instance_to_path(ihandle_t instance, char *buf, size_t len);
> +#ifndef __rtems__
>  int            OF_call_method(const char *method, ihandle_t instance,
>                     int nargs, int nreturns, ...);
> @@ -183,5 +199,6 @@ int         OF_interpret(const char *cmd, int nreturns, ...);
>  int            OF_decode_addr(phandle_t dev, int regno, bus_space_tag_t *ptag,
>                     bus_space_handle_t *phandle, bus_size_t *sz);
>  #endif /* _KERNEL */
>  #endif /* _DEV_OPENFIRM_H_ */
> 2.17.1
