GSoC 2020: [rtems/rsb]: Error while adding ptp support. This time building for xilinx_zynq_a9_qemu
Mritunjay Sharma
mritunjaysharma394 at gmail.com
Sat Jun 13 21:37:31 UTC 2020
First of all Heinz, I would like to thank you for such a wonderful guide
which really helped me fix a lot of errors.
After following your advice, I made certain changes to make PTPd work,
few errors came again but I managed to remove them with the use of Google.
However, the recent most error has caught me in a fix and I am still trying
to figure it out where I went wrong.
https://github.com/mritunjaysharma394/rtems-source-builder/tree/master/source-builder
https://github.com/ptpd/ptpd/compare/master...mritunjaysharma394:master
The above two links will tell what changes I have made and the error that I
am receiving now is:
"configure: WARNING: unrecognized options: --disable-shared
configure: error: cannot find install-sh, install.sh, or shtool in
build-aux "../ptpd-master"/build-aux
shell cmd failed: /bin/sh -ex
/home/mritunjay/development/rtems/rsb/rtems/build/ptpd-master-arm-rtems5-1/do-build
error: building ptpd-master-arm-rtems5-1"
I have attached the trace log file and error report.
I tried to google and made few more changes in ptpd Makefile.am but it
didn't help.
It will be very kind of you all to help me figure out on how to tackle this
bug.
Thanks
Mritunjay
On Sun, Jun 7, 2020 at 10:19 AM junkes <junkes at fhi-berlin.mpg.de> wrote:
> This is an unusually long text for the mailing list. I tried to write a
> kind
> of tutorial using an example for a GSOC student. I'm looking forward to
> the
> comments from the pros and can write it down completely.
> Hello, Mritunjay
> if I understood it correctly, one idea of the rtems source builder is to
> make existing
> software packages usable for RTEMS. Most existing software packages do not
> work without
> changes in the RTEMS environment. You have already noticed this with ptpd
> The most common auto-tools and configure have trouble making the correct
> assumptions for the rtems environment. Here you have to intervene. This
> can
> be done with the builder-cfg files.
> This is a bit of hard work and you have to approach it with small steps.
> You also have to use not so clean tricks in different places. When you
> have
> achieved the integration you can/must then try to optimize it so that it
> becomes
> generally valid.
> That's my policy. Maybe the others here in the maillist have more ideas,
> also for me.
> I have now tried to implement what I mean using a similar example
> (openntp).
> Unfortunately, I haven't finished yet, but I hope to clear a few hurdles
> for you.
> I was doing some digging around and I came across this:
> https://github.com/openntpd-portable/openntpd-portable
> Here I was then confronted with the same problems as you with autoreconf
> etc. Here it
> didn't work, just run autoreconf twice and generate a tar-file for
> installation like
> I did with the ptpd from github.
> Then I found this:
> https://artfiles.org/openbsd/OpenNTPD/openntpd-6.2p3.tar.gz
> Now I have made a "standard" config file for rsb:
> # OpenNTPd 6.2p3 Version 1.
> # This configuration file configure's, make's and install's OpenNTPd.
> %if %{release} == %{nil}
> %define release 1
> %endif
> Summary: NTP is the Network Time Protocol.
> Version: %{openntpd_version}
> Release: %{release}
> URL: https://github.com/openntpd-portable
> # NTP Source
> %source set openntpd
> https://artfiles.org/openbsd/OpenNTPD/openntpd-%{openntpd_version}.tar.gz
> %hash sha512 openntpd-%{openntpd_version}.tar.gz
> 56a04bfd8b161b365607673ac80086ff53ae943938fa49bf52edbc541432eca30730a46a4af581fe26ce3bbceb144cb25982a38959b7a3f9304c727fe60f9
> f50
> # Prepare the source code.
> %prep
> build_top=$(pwd)
> source_dir_openntpd="openntpd-%{openntpd_version}"
> %source setup openntpd -q -n openntpd-%{openntpd_version}
> %patch setup openntpd -p1
> cd ${build_top}
> %build
> build_top=$(pwd)
> %{build_directory}
> mkdir -p ${build_dir}
> cd ${build_dir}
> %{host_build_flags}
> ../${source_dir_openntpd}/configure \
> --host=%{_host} \
> --prefix=%{_prefix} \
> --bindir=%{_bindir} \
> --exec_prefix=%{_exec_prefix} \
> --includedir=%{_includedir} \
> --libdir=%{_libdir} \
> --libexecdir=%{_libexecdir} \
> --mandir=%{_mandir} \
> --infodir=%{_infodir} \
> --datadir=%{_datadir} \
> --disable-shared \
> --enable-static \
> --with-gnu-ld \
> --disable-https-constraint
> %{__make} all
> cd ${build_top}
> %install
> build_top=$(pwd)
> %{__rmdir} $SB_BUILD_ROOT
> cd ${build_dir}
> %{__make} DESTDIR=$SB_BUILD_ROOT install
> cd ${build_top}
> Then I "executed" that.
> [h1 at earth rtems (master *)]$ ../source-builder/sb-set-builder --log
> log.ntpd.txt --with-rtems-bsp=xilinx_zynq_a9_qemu --host=arm-rtems5
> --prefix /home/h1/GSOC/RTEMS/5.0.0-m20
> 03 net/ntpd
> RTEMS Source Builder - Set Builder, 5 (26e335ca159e modified)
> Build Set: net/ntpd
> config: net/openntpd-6.2p3-1.cfg
> package: openntpd-6.2p3-arm-rtems5-1
> building: openntpd-6.2p3-arm-rtems5-1
> error: building openntpd-6.2p3-arm-rtems5-1
> Build FAILED
> See error report: rsb-report-openntpd-6.2p3-arm-rtems5-1.txt
> Build Set: Time 0:00:16.036623
> Build FAILED
> Error! I looked at that one:
> [h1 at earth rtems (master *)]$ tail -20
> CC setproctitle.lo
> CC bsd-setresgid.lo
> CC bsd-setresuid.lo
> CCLD libcompat.la
> arm-rtems5-ar: `u' modifier ignored since `D' is the default (see `U')
> CCLD libcompatnoopt.la
> make[1]: Leaving directory
> '/home/h1/GSOC/RTEMS_DEV/rtems-source-builder/rtems/build/openntpd-6.2p3-arm-rtems5-1/build-cxc/compat'
> Making all in src
> make[1]: Entering directory
> '/home/h1/GSOC/RTEMS_DEV/rtems-source-builder/rtems/build/openntpd-6.2p3-arm-rtems5-1/build-cxc/src'
> CC ntpd-client.o
> arm-rtems5-gcc: fatal error:
> /home/h1/GSOC/RTEMS/5.0.0-m2003/arm-rtems5/xilinx_zynq_a9_qemu/lib/bsp_specs:
> attempt to rename spec 'endfile' to already defined spec 'old_endfi
> le'
> compilation terminated.
> Makefile:526: recipe for target 'ntpd-client.o' failed
> make[1]: *** [ntpd-client.o] Error 1
> Makefile:401: recipe for target 'all-recursive' failed
> make: *** [all-recursive] Error 1
> /home/h1/GSOC/RTEMS_DEV/rtems-source-builder/rtems/build/openntpd-6.2p3-arm-rtems5-1/do-build
> In build/openntpd-6.2p3-arm-rtems5-1/openntpd-6.2p3/src/Makefile.am I
> found that CFLAGS gets includes twice which leads to this error "attempt to
> rename..."
> ntpd_CFLAGS = $(CFLAGS)
> ntpd_CFLAGS += -DSYSCONFDIR=\"$(sysconfdir)\"
> ntpd_CFLAGS += -DLOCALSTATEDIR=\"$(localstatedir)\"
> Then I changed the cfg-file:
> %{host_build_flags}
> # src/Makefile.am includes CFLAGS twice?
> # this leads to : bsp_specs: attempt to rename spec 'endfile' to already
> defined spec 'old_endfile'
> sed -i 's/ntpd_CFLAGS = $(CFLAGS)/ntpd_CFLAGS = $(CFLAGS)/g'
> ../${source_dir_openntpd}/src/Makefile.am
> sed -i 's/ntpd_CFLAGS += -DSYSCONFDIR=/ntpd_CFLAGS = -DSYSCONFDIR=/g'
> --host=%{_host} \
> Now I've come a long way, but
> asnprintf
> CC ntpd-ntp.o
> CC ntpd-ntp_dns.o
> ../../openntpd-6.2p3/src/ntp_dns.c: In function 'ntp_dns':
> ../../openntpd-6.2p3/src/ntp_dns.c:58:6: warning: implicit declaration of
> function 'setpriority'; did you mean 'setprotoent'?
> [-Wimplicit-function-declaration]
> if (setpriority(PRIO_PROCESS, 0, 0) == -1)
> setprotoent
> ../../openntpd-6.2p3/src/ntp_dns.c:58:18: error: 'PRIO_PROCESS' undeclared
> (first use in this function); did you mean 'EINPROGRESS'?
> EINPROGRESS
> ../../openntpd-6.2p3/src/ntp_dns.c:58:18: note: each undeclared identifier
> is reported only once for each function it appears in
> Makefile:624: recipe for target 'ntpd-ntp_dns.o' failed
> make[1]: *** [ntpd-ntp_dns.o] Error 1
> Now a little bit of searching...
> Adding "#include <rtems/bsd/sys/resource.h>" solves the problem.
> But the next one arises:
> CC ntpd-ntpd.o
> CC ntpd-parse.o
> parse.y: In function 'yyerror':
> parse.y:473:6: warning: implicit declaration of function 'vasprintf'; did
> you mean 'vasnprintf'? [-Wimplicit-function-declaration]
> parse.y: In function 'yylex':
> parse.y:686:22: warning: implicit declaration of function 'strtonum'; did
> you mean 'strtoul'? [-Wimplicit-function-declaration]
> CC ntpd-fake-sensors.o
> CC ntpd-server.o
> ../../openntpd-6.2p3/src/server.c: In function 'setup_listeners':
> ../../openntpd-6.2p3/src/server.c:65:21: error: 'struct if_data' has no
> member named 'ifi_rdomain'; did you mean 'ifi_addrlen'?
> rdomain = ifd->ifi_rdomain;
> ifi_addrlen
> Makefile:708: recipe for target 'ntpd-server.o' failed
> That looks a little more complicated. It uses an if_data structure that is
> probably only available in openbsd?
> But also here google helps ;-)
> Here I found a patch :
> https://github.com/freebsd/freebsd-ports/tree/master/net/openntpd/files
> [h1 at earth build-cxc (master *)]$ patch ../openntpd-6.2p3/src/server.c
> /tmp/openntp/openntpd-6.2p3/patch-src_server.c
> And it's gotten me this far:
> [h1 at earth build-cxc (master *)]$ make
> Making all in include
> '/home/h1/GSOC/RTEMS_DEV/rtems-source-builder/rtems/build/openntpd-6.2p3-arm-rtems5-1/build-cxc/include'
> make[1]: Nothing to be done for 'all'.
> Making all in compat
> Making all in src
> CC ntpd-server.o
> CC ntpd-util.o
> CCLD ntpd
> /home/h1/GSOC/RTEMS/5.0.0-m2003/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld:
> ntpd-ntp_dns.o: in function `ntp_dns':
> /home/h1/GSOC/RTEMS_DEV/rtems-source-builder/rtems/build/openntpd-6.2p3-arm-rtems5-1/build-cxc/src/../../openntpd-6.2p3/src/ntp_dns.c:59:
> undefined reference to `setpriority'
> ntpd-ntpd.o: in function `main':
> /home/h1/GSOC/RTEMS_DEV/rtems-source-builder/rtems/build/openntpd-6.2p3-arm-rtems5-1/build-cxc/src/../../openntpd-6.2p3/src/ntpd.c:243:
> uild-cxc/src/../../openntpd-6.2p3/src/ntpd.c:251: undefined reference to
> `daemon'
> uild-cxc/src/../../openntpd-6.2p3/src/ntpd.c:330: undefined reference to
> `daemon'
> ntpd-ntpd.o: in function `dispatch_imsg':
> /home/h1/GSOC/RTEMS_DEV/rtems-source-builder/rtems/build/openntpd-6.2p3-arm-rtems5-1/build-cxc/src/../../openntpd-6.2p3/src/ntpd.c:435:
> undefined reference to `daemon'
> ntpd-ntpd.o: in function `ntpd_adjtime':
> /home/h1/GSOC/RTEMS_DEV/rtems-source-builder/rtems/build/openntpd-6.2p3-arm-rtems5-1/build-cxc/src/../../openntpd-6.2p3/src/ntpd.c:487:
> undefined reference to `update_time_sy
> nc_status'
> ntpd-ntpd.o: in function `ntpd_adjfreq':
> /home/h1/GSOC/RTEMS_DEV/rtems-source-builder/rtems/build/openntpd-6.2p3-arm-rtems5-1/build-cxc/src/../../openntpd-6.2p3/src/ntpd.c:498:
> undefined reference to `adjfreq'
> uild-cxc/src/../../openntpd-6.2p3/src/ntpd.c:522: undefined reference to
> `adjfreq'
> ntpd-ntpd.o: in function `ntpd_settime':
> /home/h1/GSOC/RTEMS_DEV/rtems-source-builder/rtems/build/openntpd-6.2p3-arm-rtems5-1/build-cxc/src/../../openntpd-6.2p3/src/ntpd.c:542:
> undefined reference to `settimeofday'
> ntpd-ntpd.o: in function `readfreq':
> /home/h1/GSOC/RTEMS_DEV/rtems-source-builder/rtems/build/openntpd-6.2p3-arm-rtems5-1/build-cxc/src/../../openntpd-6.2p3/src/ntpd.c:565:
> uild-cxc/src/../../openntpd-6.2p3/src/ntpd.c:574: undefined reference to
> `adjfreq'
> collect2: error: ld returned 1 exit status
> Makefile:476: recipe for target 'ntpd' failed
> make[1]: *** [ntpd] Error 1
> This is where I am now. From now on, it's gonna be exciting. Now it's all
> about anchoring the daemon process in RTEMS.
> But that is nice work now. I still have to do it.
> But I wanted to show you this step-by-step so you can get over the first
> hurdles.
> I hope this helps you and it was not too long.
> Heinz
> On 2020-06-06 01:31, Mritunjay Sharma wrote:
> Thank you so much Heinz for such a detailed response.
> It really helped me a lot.
> As advised by you and Heinz, I changed the source to
> https://github.com/mritunjaysharma394/ptpd/archive/master.zip
> with suggested changes. However, I have encountered few bugs again related
> to autoreconf.
> It looks somewhat like this:
> + autoreconf -i -v
> autoreconf: Entering directory `.'
> autoreconf: configure.ac: not using Gettext
> autoreconf: running: aclocal -I m4
> autoreconf: configure.ac: tracing
> autoreconf: configure.ac: creating directory build-aux
> autoreconf: configure.ac: not using Libtool
> autoreconf: running: /home/mritunjay/development/rtems/5/bin/autoconf
> configure.ac:28: error: possibly undefined macro: AC_PROG_LIBTOOL
> If this token and others are legitimate, please use m4_pattern_allow.
> See the Autoconf documentation.
> autoreconf: /home/mritunjay/development/rtems/5/bin/autoconf failed with
> exit status: 1
> I have attached the error report as well and changes in cfg files can be
> found here:
> https://github.com/mritunjaysharma394/rtems-source-builder/commit/6b6bb2b3bd778ebe56e9a1bf3aec1747b078fd39
> Thanks,
> Mritunjay
> On Fri, Jun 5, 2020 at 2:53 AM Gedare Bloom <gedare at rtems.org> wrote:
> On Thu, Jun 4, 2020 at 1:38 PM junkes <junkes at fhi-berlin.mpg.de> wrote:
> > Hallo Mritunjay,
> > You can't just take the github ptpd sources and make them work in RTEMS.
> You have to make some configuration
> > and sources changes before you can build the with the rsb.
> > Some things like the sys/cpuset.h seems not to be fully compatible yet
> and so the configure simply makes
> > "wrong" decisions. E.g. defines HAVE_SYS_CPUSET_H = 1 as sys/cpuset.h
> exists.I played a little bit with it and reset
> > the definition in ptpd-master/src/ptpd.h (quick and dirty) and could
> reduce the error messages because there is a query for
> > this variable in the code (src/dep/sys.c):
> > in ptpd.h after the include of the created configs :
> > #ifdef HAVE_CONFIG_H
> > # include <config.h>
> > #endif /* HAVE_CONFIG_H */
> > #undef HAVE_NTP_GETTIME
> > #undef HAVE_SYS_CPUSET_H
> > #ifdef linux
> > in src/dep/sys.c
> > #ifdef HAVE_SYS_CPUSET_H
> > cpuset_t mask;
> > CPU_ZERO(&mask);
> > if(cpu >= 0) {
> > CPU_SET(cpu,&mask);
> > } else {
> > int i;
> > for(i = 0; i < CPU_SETSIZE; i++) {
> > CPU_SET(i, &mask);
> > return(cpuset_setaffinity(CPU_LEVEL_WHICH, CPU_WHICH_PID,
> > -1, sizeof(mask), &mask));
> > #endif /* HAVE_SYS_CPUSET_H */
> > In src/dep/constants_dep.h one can find:
> > * platform dependent */
> > #if !defined(linux) && !defined(__NetBSD__) && !defined(__FreeBSD__) && \
> > !defined(__APPLE__) && !defined(__OpenBSD__) && !defined(__sun) &&
> !defined(__QNXNTO__)
> > #error PTPD hasn't been ported to this OS - should be possible \
> > if it's POSIX compatible, if you succeed, report it to
> ptpd-devel at sourceforge.net
> > #endif
> > here I added "&& !defined(__rtems__)
> > and here:
> > #if defined(__NetBSD__) || defined(__FreeBSD__) || defined(__APPLE__) ||
> defined(__OpenBSD__) || defined(__sun) || defined(__QNXNTO__) ||
> defined(__rtems__)
> > # include <sys/types.h>
> > # include <sys/socket.h>
> > #ifdef HAVE_SYS_SOCKIO_H
> > #include <sys/sockio.h>
> > #endif /* HAVE_SYS_SOCKIO_H */
> > # include <netinet/in.h>
> > # include <net/if.h>
> > # include <net/if_dl.h>
> > # include <net/if_types.h>
> > #ifdef HAVE_NET_IF_ETHER_H
> > # include <net/if_ether.h>
> > and so on... You'd have to bite through it once and then you will surely
> get it compiled.
> Great start Heinz! Mritunjay, I think this definitely the way forward.
> Later, you might try to circle back and fix the hacks in nicer ways by
> learning how to make the autoconf stuff work correctly, and contribute
> those fixes back upstream to ptpd project.
> > HTH Heinz
> > On 2020-06-04 20:29, Mritunjay Sharma wrote:
> > On Thu, Jun 4, 2020 at 11:07 PM Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
> > On 04/06/2020 16:22, Gedare Bloom wrote:
> > >>> In the github version this code is conditional on sys/cpuset.h being
> present.
> > > Well, we do have a sys/cpuset.h in newlib. It doesn't have these BSD
> > > definitions though. Probably either:
> > > 1. Add more stuff to sys/cpuset.h to make it support BSDisms. This
> > > would mean adding cpuset_setaffinity support in rtems, I guess.
> > > 2. Figure out how to disable the conditional code using the
> > > cpuset_setaffinity function.
> > The <sys/cpuset.h> is already as compatible as possible to glibc and
> > FreeBSD. There is always room for improvement, however, in this area it
> > will be difficult.
> > Please it would be kind of you all to guide on what is the best thing I
> can do next. It is looking
> > a little difficult. If something similar has been done earlier, sharing
> it can be a lot helpful to take a cue.
> > Mritunjay
> > devel mailing list
> > devel at rtems.org
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200614/2989f34c/attachment-0001.html>
RTEMS Tools Project - Source Builder Error Report
Build: error: building ptpd-master-arm-rtems5-1
Command Line: ../source-builder/sb-set-builder --log=log --prefix=/home/mritunjay/development/rtems/5 --with-tools=/home/mritunjay/development/rtems/5 --host=arm-rtems5 --with-rtems-bsp=xilinx_zynq_a9_qemu net/ptpd
Python: 2.7.17 (default, Apr 15 2020, 17:20:14) [GCC 7.5.0]
git://git.rtems.org/rtems-source-builder.git/origin/855818015a378a8333754625296f3b15ce52aadd-modified
Linux mritunjay-XPS-15-9570 5.3.0-51-generic #44~18.04.2-Ubuntu SMP Thu Apr 23 14:27:18 UTC 2020 x86_64
Tail of the build log:
script: 31: export SB_DOC_DIR
script: 32: # Packages
script: 33: SB_PACKAGE_NAME="ptpd-master-arm-rtems5-1"
script: 34: SB_PACKAGE_BUILDNAME="ptpd-master-arm-rtems5-1"
script: 35: SB_PACKAGE_VERSION="master"
script: 36: SB_PACKAGE_RELEASE="1"
script: 37: export SB_PACKAGE_NAME SB_PACKAGE_VERSION SB_PACKAGE_RELEASE
script: 38: # Build directories
script: 39: export SB_PREFIX
script: 40: SB_BUILD_DIR="/home/mritunjay/development/rtems/rsb/rtems/build/ptpd-master-arm-rtems5-1"
script: 41: SB_BUILD_ROOT="/home/mritunjay/development/rtems/rsb/rtems/build/tmp/ptpd-master-arm-rtems5-1-1000"
script: 42: SB_BUILD_ROOT_BINDIR="/home/mritunjay/development/rtems/rsb/rtems/build/tmp/ptpd-master-arm-rtems5-1-1000/${SB_PREFIX_CLEAN}/bin"
script: 43: export SB_BUILD_ROOT SB_BUILD_DIR SB_BUILD_ROOT_BINDIR
script: 44: SB_BUILD_CXC_DIR="/home/mritunjay/development/rtems/rsb/rtems/build/ptpd-master-arm-rtems5-1-cxc"
script: 45: SB_BUILD_CXC_ROOT="/home/mritunjay/development/rtems/rsb/rtems/build/tmp/ptpd-master-arm-rtems5-1-1000-cxc"
script: 46: SB_BUILD_CXC_ROOT_BINDIR="/home/mritunjay/development/rtems/rsb/rtems/build/tmp/ptpd-master-arm-rtems5-1-1000-cxc/${SB_PREFIX_CLEAN}/bin"
script: 47: export SB_BUILD_CXC_ROOT SB_BUILD_CXC_DIR SB_BUILD_CXC_ROOT_BINDIR
script: 48: SB_TMPROOT="/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/net/ptpd"
script: 49: SB_TMPPREFIX="/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/net/ptpd/${SB_PREFIX_CLEAN}"
script: 50: SB_TMPBINDIR="/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/net/ptpd/${SB_PREFIX_CLEAN}/bin"
script: 51: export SB_TMPROOT SB_TMPPREFIX SB_TMPBINDIR
script: 52: SB_TMPCXCROOT="/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/net/ptpd"
script: 53: SB_TMPCXCPREFIX="/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000-cxc/net/ptpd/${SB_PREFIX_CLEAN}"
script: 54: SB_TMPCXCBINDIR="/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000-cxc/net/ptpd/${SB_PREFIX_CLEAN}/bin"
script: 55: export SB_TMPCXCROOT SB_TMPCXCPREFIX SB_TMPCXCBINDIR
script: 56: # Extra path support
script: 57: SB_EXTRAPATH="/home/mritunjay/development/rtems/rsb/source-builder"
script: 58: # The compiler flags
script: 59:
script: 60:
script: 61: export CFLAGS_FOR_TARGET
script: 62: export CXXFLAGS_FOR_TARGET
script: 63: # Set up the path. Put the CXC path first.
script: 64: if test -n "${SB_TMPBINDIR}" ; then
script: 65: PATH="${SB_TMPBINDIR}:$PATH"
script: 66: fi
script: 67: if test -n "${SB_TMPCXCBINDIR}" ; then
script: 68: PATH="${SB_TMPCXCBINDIR}:$PATH"
script: 69: fi
script: 70: if test -n "${SB_EXTRAPATH}" ; then
script: 71: PATH="${SB_EXTRAPATH}:$PATH"
script: 72: fi
script: 73: PATH="/home/mritunjay/development/rtems/5/bin:$PATH"
script: 74:
script: 75: export PATH
script: 76: # Default environment set up.
script: 77: LANG=C
script: 78: export LANG
script: 79: unset DISPLAY || :
script: 80: umask 022
script: 81: cd "/home/mritunjay/development/rtems/rsb/rtems/build/ptpd-master-arm-rtems5-1"
script: 82: echo "=> ptpd-master-arm-rtems5-1: CLEAN"
script: 83: echo "==> %clean:"
removing: /home/mritunjay/development/rtems/rsb/rtems/build/ptpd-master-arm-rtems5-1
making dir: /home/mritunjay/development/rtems/rsb/rtems/build/ptpd-master-arm-rtems5-1
write script: /home/mritunjay/development/rtems/rsb/rtems/build/ptpd-master-arm-rtems5-1/do-build
write script: /home/mritunjay/development/rtems/rsb/rtems/build/ptpd-master-arm-rtems5-1/do-clean
building: ptpd-master-arm-rtems5-1
run: /bin/sh -ex /home/mritunjay/development/rtems/rsb/rtems/build/ptpd-master-arm-rtems5-1/do-build
+ export SB_ORIG_PATH=/home/mritunjay/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
+ SB_PREFIX=/home/mritunjay/development/rtems/5
+ echo /home/mritunjay/development/rtems/5
+ /bin/sed -e s/^\///
+ SB_PREFIX_CLEAN=home/mritunjay/development/rtems/5
+ SB_SOURCE_DIR=/home/mritunjay/development/rtems/rsb/rtems/sources
+ SB_BUILD_DIR=/home/mritunjay/development/rtems/rsb/rtems/build/ptpd-master-arm-rtems5-1
+ SB_HOST_CPPFLAGS=-I/home/mritunjay/development/rtems/5/arm-rtems5/xilinx_zynq_a9_qemu/lib/include
+ SB_HOST_CFLAGS=-qrtems -B/home/mritunjay/development/rtems/5/arm-rtems5/lib/ -B/home/mritunjay/development/rtems/5/arm-rtems5/xilinx_zynq_a9_qemu/lib/ --specs bsp_specs -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O0 -g -ffunction-sections -fdata-sections
+ SB_HOST_CXXFLAGS=-qrtems -B/home/mritunjay/development/rtems/5/arm-rtems5/lib/ -B/home/mritunjay/development/rtems/5/arm-rtems5/xilinx_zynq_a9_qemu/lib/ --specs bsp_specs -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O0 -g -ffunction-sections -fdata-sections
+ echo -qrtems -B/home/mritunjay/development/rtems/5/arm-rtems5/lib/ -B/home/mritunjay/development/rtems/5/arm-rtems5/xilinx_zynq_a9_qemu/lib/ --specs bsp_specs -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O0 -g -ffunction-sections -fdata-sections
+ awk {for (i=1;i<NF;++i) if ($i ~ /\-m/) printf("%s ",$i);}
+ SB_HOST_LDFLAGS=-L/home/mritunjay/development/rtems/5/arm-rtems5/xilinx_zynq_a9_qemu/lib -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -L/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/net/ptpd/home/mritunjay/development/rtems/5/lib
+ SB_HOST_LIBS=-lbsd -lm -lz -lrtemsdefaultconfig
+ SB_BUILD_CFLAGS=-O2 -g -pipe -I/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/net/ptpd/home/mritunjay/development/rtems/5/include
+ SB_BUILD_CXXFLAGS=-O2 -g -pipe -I/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/net/ptpd/home/mritunjay/development/rtems/5/include
+ SB_BUILD_LDFLAGS= -L/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/net/ptpd/home/mritunjay/development/rtems/5/lib
+ SB_BUILD_LBS=
+ SB_CFLAGS=-O2 -g -pipe -I/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/net/ptpd/home/mritunjay/development/rtems/5/include
+ SB_CXXFLAGS=-O2 -g -pipe -I/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/net/ptpd/home/mritunjay/development/rtems/5/include
+ SB_ARCH=arm
+ SB_OS=linux
+ export SB_SOURCE_DIR SB_BUILD_DIR SB_ARCH SB_OS
+ export SB_HOST_CPPFLAGS SB_HOST_CFLAGS SB_HOST_CXXFLAGS SB_HOST_LDFLAGS SB_HOST_LIBS
+ export SB_BUILD_CFLAGS SB_BUILD_CXXFLAGS SB_BUILD_LDFLAGS SB_BUILD_LIBS
+ export SB_CFLAGS SB_CXXFLAGS
+ SB_DOC_DIR=/home/mritunjay/development/rtems/5/share/doc
+ export SB_DOC_DIR
+ SB_PACKAGE_NAME=ptpd-master-arm-rtems5-1
+ SB_PACKAGE_BUILDNAME=ptpd-master-arm-rtems5-1
+ SB_PACKAGE_VERSION=master
+ SB_PACKAGE_RELEASE=1
+ export SB_PACKAGE_NAME SB_PACKAGE_VERSION SB_PACKAGE_RELEASE
+ export SB_PREFIX
+ SB_BUILD_ROOT=/home/mritunjay/development/rtems/rsb/rtems/build/tmp/ptpd-master-arm-rtems5-1-1000
+ SB_BUILD_ROOT_BINDIR=/home/mritunjay/development/rtems/rsb/rtems/build/tmp/ptpd-master-arm-rtems5-1-1000/home/mritunjay/development/rtems/5/bin
+ export SB_BUILD_ROOT SB_BUILD_DIR SB_BUILD_ROOT_BINDIR
+ SB_BUILD_CXC_DIR=/home/mritunjay/development/rtems/rsb/rtems/build/ptpd-master-arm-rtems5-1-cxc
+ SB_BUILD_CXC_ROOT=/home/mritunjay/development/rtems/rsb/rtems/build/tmp/ptpd-master-arm-rtems5-1-1000-cxc
+ SB_BUILD_CXC_ROOT_BINDIR=/home/mritunjay/development/rtems/rsb/rtems/build/tmp/ptpd-master-arm-rtems5-1-1000-cxc/home/mritunjay/development/rtems/5/bin
+ export SB_BUILD_CXC_ROOT SB_BUILD_CXC_DIR SB_BUILD_CXC_ROOT_BINDIR
+ SB_TMPROOT=/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/net/ptpd
+ SB_TMPPREFIX=/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/net/ptpd/home/mritunjay/development/rtems/5
+ SB_TMPBINDIR=/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/net/ptpd/home/mritunjay/development/rtems/5/bin
+ export SB_TMPROOT SB_TMPPREFIX SB_TMPBINDIR
+ SB_TMPCXCROOT=/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/net/ptpd
+ SB_TMPCXCPREFIX=/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000-cxc/net/ptpd/home/mritunjay/development/rtems/5
+ SB_TMPCXCBINDIR=/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000-cxc/net/ptpd/home/mritunjay/development/rtems/5/bin
+ export SB_TMPCXCROOT SB_TMPCXCPREFIX SB_TMPCXCBINDIR
+ SB_EXTRAPATH=/home/mritunjay/development/rtems/rsb/source-builder
+ export CFLAGS_FOR_TARGET
+ export CXXFLAGS_FOR_TARGET
+ test -n /home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/net/ptpd/home/mritunjay/development/rtems/5/bin
+ PATH=/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/net/ptpd/home/mritunjay/development/rtems/5/bin:/home/mritunjay/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
+ test -n /home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000-cxc/net/ptpd/home/mritunjay/development/rtems/5/bin
+ PATH=/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000-cxc/net/ptpd/home/mritunjay/development/rtems/5/bin:/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/net/ptpd/home/mritunjay/development/rtems/5/bin:/home/mritunjay/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
+ test -n /home/mritunjay/development/rtems/rsb/source-builder
+ PATH=/home/mritunjay/development/rtems/rsb/source-builder:/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000-cxc/net/ptpd/home/mritunjay/development/rtems/5/bin:/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/net/ptpd/home/mritunjay/development/rtems/5/bin:/home/mritunjay/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
=> ptpd-master-arm-rtems5-1: BUILD
==> %prep:
+ PATH=/home/mritunjay/development/rtems/5/bin:/home/mritunjay/development/rtems/rsb/source-builder:/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000-cxc/net/ptpd/home/mritunjay/development/rtems/5/bin:/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/net/ptpd/home/mritunjay/development/rtems/5/bin:/home/mritunjay/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
+ export PATH
+ LANG=C
+ export LANG
+ unset DISPLAY
+ umask 022
+ cd /home/mritunjay/development/rtems/rsb/rtems/build/ptpd-master-arm-rtems5-1
+ echo => ptpd-master-arm-rtems5-1: BUILD
+ echo ==> %prep:
+ pwd
+ build_top=/home/mritunjay/development/rtems/rsb/rtems/build/ptpd-master-arm-rtems5-1
+ source_dir_ptpd=ptpd-master
+ /bin/rm -rf ptpd-master
+ /bin/gzip -dc /home/mritunjay/development/rtems/rsb/rtems/sources/ptpd.tar.gz
+ /bin/tar -xvv -f -
drwxr-xr-x mritunjay/mritunjay 0 2020-06-07 11:02 ptpd-master/
-rw-r--r-- mritunjay/mritunjay 866 2020-06-06 03:35 ptpd-master/Makefile.am
drwxr-xr-x mritunjay/mritunjay 0 2020-06-06 03:35 ptpd-master/src/
-rw-r--r-- mritunjay/mritunjay 8635 2020-06-06 03:35 ptpd-master/src/arith.c
-rw-r--r-- mritunjay/mritunjay 15404 2020-06-06 03:35 ptpd-master/src/ptp_datatypes.h
-rw-r--r-- mritunjay/mritunjay 63438 2020-06-06 03:35 ptpd-master/src/Doxyfile
-rw-r--r-- mritunjay/mritunjay 23434 2020-06-06 03:35 ptpd-master/src/datatypes.h
-rw-r--r-- mritunjay/mritunjay 2133 2020-06-06 03:35 ptpd-master/src/Makefile.am
-rw-r--r-- mritunjay/mritunjay 943 2020-06-06 03:35 ptpd-master/src/ptp_primitives.h
-rw-r--r-- mritunjay/mritunjay 3846 2020-06-06 03:35 ptpd-master/src/ptp_timers.c
-rw-r--r-- mritunjay/mritunjay 26831 2020-06-06 03:35 ptpd-master/src/bmc.c
-rw-r--r-- mritunjay/mritunjay 10405 2020-06-06 03:35 ptpd-master/src/leap-seconds.list
-rw-r--r-- mritunjay/mritunjay 3658 2020-06-06 03:35 ptpd-master/src/ptp_timers.h
-rw-r--r-- mritunjay/mritunjay 735 2020-06-06 03:35 ptpd-master/src/templates.conf
-rw-r--r-- mritunjay/mritunjay 46086 2020-06-06 03:35 ptpd-master/src/signaling.c
-rw-r--r-- mritunjay/mritunjay 34260 2020-06-06 03:35 ptpd-master/src/display.c
-rw-r--r-- mritunjay/mritunjay 34562 2020-06-06 03:35 ptpd-master/src/ptpd2.conf.default-full
-rw-r--r-- mritunjay/mritunjay 67869 2020-06-06 03:35 ptpd-master/src/ptpd2.conf.5.in
-rw-r--r-- mritunjay/mritunjay 2912 2020-06-06 03:35 ptpd-master/src/Makefile.old
-rw-r--r-- mritunjay/mritunjay 123250 2020-06-06 03:35 ptpd-master/src/protocol.c
drwxr-xr-x mritunjay/mritunjay 0 2020-06-06 03:35 ptpd-master/src/dep/
-rw-r--r-- mritunjay/mritunjay 5761 2020-06-06 03:35 ptpd-master/src/dep/constants_dep.h
-rw-r--r-- mritunjay/mritunjay 74744 2020-06-06 03:35 ptpd-master/src/dep/sys.c
-rw-r--r-- mritunjay/mritunjay 10526 2020-06-06 03:35 ptpd-master/src/dep/ipv4_acl.c
-rw-r--r-- mritunjay/mritunjay 60485 2020-06-06 03:35 ptpd-master/src/dep/net.c
drwxr-xr-x mritunjay/mritunjay 0 2020-06-06 03:35 ptpd-master/src/dep/iniparser/
-rw-r--r-- mritunjay/mritunjay 309 2020-06-06 03:35 ptpd-master/src/dep/iniparser/AUTHORS
-rw-r--r-- mritunjay/mritunjay 11711 2020-06-06 03:35 ptpd-master/src/dep/iniparser/iniparser.h
-rw-r--r-- mritunjay/mritunjay 7422 2020-06-06 03:35 ptpd-master/src/dep/iniparser/dictionary.h
-rw-r--r-- mritunjay/mritunjay 295 2020-06-06 03:35 ptpd-master/src/dep/iniparser/README
-rw-r--r-- mritunjay/mritunjay 1083 2020-06-06 03:35 ptpd-master/src/dep/iniparser/LICENSE
-rw-r--r-- mritunjay/mritunjay 23637 2020-06-06 03:35 ptpd-master/src/dep/iniparser/iniparser.c
-rw-r--r-- mritunjay/mritunjay 15181 2020-06-06 03:35 ptpd-master/src/dep/iniparser/dictionary.c
-rw-r--r-- mritunjay/mritunjay 3971 2020-06-06 03:35 ptpd-master/src/dep/datatypes_dep.h
-rw-r--r-- mritunjay/mritunjay 6205 2020-06-06 03:35 ptpd-master/src/dep/eventtimer_itimer.c
-rw-r--r-- mritunjay/mritunjay 20593 2020-06-06 03:35 ptpd-master/src/dep/configdefaults.c
-rw-r--r-- mritunjay/mritunjay 91140 2020-06-06 03:35 ptpd-master/src/dep/msg.c
-rw-r--r-- mritunjay/mritunjay 12560 2020-06-06 03:35 ptpd-master/src/dep/alarms.c
-rw-r--r-- mritunjay/mritunjay 1081 2020-06-06 03:35 ptpd-master/src/dep/configdefaults.h
-rw-r--r-- mritunjay/mritunjay 41486 2020-06-06 03:35 ptpd-master/src/dep/servo.c
-rw-r--r-- mritunjay/mritunjay 19618 2020-06-06 03:35 ptpd-master/src/dep/ptpd_dep.h
-rw-r--r-- mritunjay/mritunjay 2354 2020-06-06 03:35 ptpd-master/src/dep/eventtimer.h
-rw-r--r-- mritunjay/mritunjay 11581 2020-06-06 03:35 ptpd-master/src/dep/outlierfilter.c
-rw-r--r-- mritunjay/mritunjay 5727 2020-06-06 03:35 ptpd-master/src/dep/eventtimer_posix.c
-rw-r--r-- mritunjay/mritunjay 1238 2020-06-06 03:35 ptpd-master/src/dep/ipv4_acl.h
-rw-r--r-- mritunjay/mritunjay 90135 2020-06-06 03:35 ptpd-master/src/dep/snmp.c
-rw-r--r-- mritunjay/mritunjay 31954 2020-06-06 03:35 ptpd-master/src/dep/startup.c
-rw-r--r-- mritunjay/mritunjay 137634 2020-06-06 03:35 ptpd-master/src/dep/daemonconfig.c
-rw-r--r-- mritunjay/mritunjay 26635 2020-06-06 03:35 ptpd-master/src/dep/statistics.c
-rw-r--r-- mritunjay/mritunjay 2840 2020-06-06 03:35 ptpd-master/src/dep/daemonconfig.h
-rw-r--r-- mritunjay/mritunjay 4935 2020-06-06 03:35 ptpd-master/src/dep/alarms.h
-rw-r--r-- mritunjay/mritunjay 5957 2020-06-06 03:35 ptpd-master/src/dep/statistics.h
-rw-r--r-- mritunjay/mritunjay 3013 2020-06-06 03:35 ptpd-master/src/dep/eventtimer.c
drwxr-xr-x mritunjay/mritunjay 0 2020-06-06 03:35 ptpd-master/src/dep/ntpengine/
-rw-r--r-- mritunjay/mritunjay 20443 2020-06-06 03:35 ptpd-master/src/dep/ntpengine/ntpdcontrol.c
-rw-r--r-- mritunjay/mritunjay 12271 2020-06-06 03:35 ptpd-master/src/dep/ntpengine/ntpdcontrol.h
-rw-r--r-- mritunjay/mritunjay 8689 2020-06-06 03:35 ptpd-master/src/dep/ntpengine/ntp_isc_md5.c
-rw-r--r-- mritunjay/mritunjay 3298 2020-06-06 03:35 ptpd-master/src/dep/ntpengine/ntp_isc_md5.h
-rw-r--r-- mritunjay/mritunjay 3695 2020-06-06 03:35 ptpd-master/src/dep/outlierfilter.h
-rw-r--r-- mritunjay/mritunjay 71143 2020-06-06 03:35 ptpd-master/src/management.c
-rw-r--r-- mritunjay/mritunjay 26559 2020-06-06 03:35 ptpd-master/src/timingdomain.c
drwxr-xr-x mritunjay/mritunjay 0 2020-06-06 03:35 ptpd-master/src/def/
-rw-r--r-- mritunjay/mritunjay 439 2020-06-06 03:35 ptpd-master/src/def/README
drwxr-xr-x mritunjay/mritunjay 0 2020-06-06 03:35 ptpd-master/src/def/signalingTLV/
-rw-r--r-- mritunjay/mritunjay 418 2020-06-06 03:35 ptpd-master/src/def/signalingTLV/grantUnicastTransmission.def
-rw-r--r-- mritunjay/mritunjay 294 2020-06-06 03:35 ptpd-master/src/def/signalingTLV/cancelUnicastTransmission.def
-rw-r--r-- mritunjay/mritunjay 347 2020-06-06 03:35 ptpd-master/src/def/signalingTLV/requestUnicastTransmission.def
-rw-r--r-- mritunjay/mritunjay 299 2020-06-06 03:35 ptpd-master/src/def/signalingTLV/acknowledgeCancelUnicastTransmission.def
-rw-r--r-- mritunjay/mritunjay 200 2020-06-06 03:35 ptpd-master/src/def/signalingTLV/signalingTLV.def
drwxr-xr-x mritunjay/mritunjay 0 2020-06-06 03:35 ptpd-master/src/def/managementTLV/
-rw-r--r-- mritunjay/mritunjay 246 2020-06-06 03:35 ptpd-master/src/def/managementTLV/logAnnounceInterval.def
-rw-r--r-- mritunjay/mritunjay 1112 2020-06-06 03:35 ptpd-master/src/def/managementTLV/clockDescription.def
-rw-r--r-- mritunjay/mritunjay 208 2020-06-06 03:35 ptpd-master/src/def/managementTLV/unicastNegotiationEnable.def
-rw-r--r-- mritunjay/mritunjay 256 2020-06-06 03:35 ptpd-master/src/def/managementTLV/logMinPdelayReqInterval.def
-rw-r--r-- mritunjay/mritunjay 272 2020-06-06 03:35 ptpd-master/src/def/managementTLV/utcProperties.def
-rw-r--r-- mritunjay/mritunjay 306 2020-06-06 03:35 ptpd-master/src/def/managementTLV/errorStatus.def
-rw-r--r-- mritunjay/mritunjay 237 2020-06-06 03:35 ptpd-master/src/def/managementTLV/clockAccuracy.def
-rw-r--r-- mritunjay/mritunjay 253 2020-06-06 03:35 ptpd-master/src/def/managementTLV/announceReceiptTimeout.def
-rw-r--r-- mritunjay/mritunjay 245 2020-06-06 03:35 ptpd-master/src/def/managementTLV/userDescription.def
-rw-r--r-- mritunjay/mritunjay 225 2020-06-06 03:35 ptpd-master/src/def/managementTLV/priority2.def
-rw-r--r-- mritunjay/mritunjay 225 2020-06-06 03:35 ptpd-master/src/def/managementTLV/priority1.def
-rw-r--r-- mritunjay/mritunjay 194 2020-06-06 03:35 ptpd-master/src/def/managementTLV/time.def
-rw-r--r-- mritunjay/mritunjay 580 2020-06-06 03:35 ptpd-master/src/def/managementTLV/parentDataSet.def
-rw-r--r-- mritunjay/mritunjay 208 2020-06-06 03:35 ptpd-master/src/def/managementTLV/initialize.def
-rw-r--r-- mritunjay/mritunjay 239 2020-06-06 03:35 ptpd-master/src/def/managementTLV/timescaleProperties.def
-rw-r--r-- mritunjay/mritunjay 305 2020-06-06 03:35 ptpd-master/src/def/managementTLV/timePropertiesDataSet.def
-rw-r--r-- mritunjay/mritunjay 631 2020-06-06 03:35 ptpd-master/src/def/managementTLV/portDataSet.def
-rw-r--r-- mritunjay/mritunjay 276 2020-06-06 03:35 ptpd-master/src/def/managementTLV/versionNumber.def
-rw-r--r-- mritunjay/mritunjay 235 2020-06-06 03:35 ptpd-master/src/def/managementTLV/traceabilityProperties.def
-rw-r--r-- mritunjay/mritunjay 217 2020-06-06 03:35 ptpd-master/src/def/managementTLV/slaveOnly.def
-rw-r--r-- mritunjay/mritunjay 239 2020-06-06 03:35 ptpd-master/src/def/managementTLV/delayMechanism.def
-rw-r--r-- mritunjay/mritunjay 262 2020-06-06 03:35 ptpd-master/src/def/managementTLV/managementTLV.def
-rw-r--r-- mritunjay/mritunjay 292 2020-06-06 03:35 ptpd-master/src/def/managementTLV/currentDataSet.def
-rw-r--r-- mritunjay/mritunjay 480 2020-06-06 03:35 ptpd-master/src/def/managementTLV/defaultDataSet.def
-rw-r--r-- mritunjay/mritunjay 225 2020-06-06 03:35 ptpd-master/src/def/managementTLV/domain.def
-rw-r--r-- mritunjay/mritunjay 238 2020-06-06 03:35 ptpd-master/src/def/managementTLV/logSyncInterval.def
drwxr-xr-x mritunjay/mritunjay 0 2020-06-06 03:35 ptpd-master/src/def/derivedData/
-rw-r--r-- mritunjay/mritunjay 211 2020-06-06 03:35 ptpd-master/src/def/derivedData/timestamp.def
-rw-r--r-- mritunjay/mritunjay 268 2020-06-06 03:35 ptpd-master/src/def/derivedData/portAddress.def
-rw-r--r-- mritunjay/mritunjay 175 2020-06-06 03:35 ptpd-master/src/def/derivedData/timeInterval.def
-rw-r--r-- mritunjay/mritunjay 454 2020-06-06 03:35 ptpd-master/src/def/derivedData/faultRecord.def
-rw-r--r-- mritunjay/mritunjay 212 2020-06-06 03:35 ptpd-master/src/def/derivedData/ptpText.def
-rw-r--r-- mritunjay/mritunjay 246 2020-06-06 03:35 ptpd-master/src/def/derivedData/tlv.def
-rw-r--r-- mritunjay/mritunjay 261 2020-06-06 03:35 ptpd-master/src/def/derivedData/clockQuality.def
-rw-r--r-- mritunjay/mritunjay 232 2020-06-06 03:35 ptpd-master/src/def/derivedData/portIdentity.def
-rw-r--r-- mritunjay/mritunjay 378 2020-06-06 03:35 ptpd-master/src/def/derivedData/physicalAddress.def
-rw-r--r-- mritunjay/mritunjay 440 2020-06-06 03:35 ptpd-master/src/def/derivedData/timePropertiesDS.def
drwxr-xr-x mritunjay/mritunjay 0 2020-06-06 03:35 ptpd-master/src/def/message/
-rw-r--r-- mritunjay/mritunjay 423 2020-06-06 03:35 ptpd-master/src/def/message/management.def
-rw-r--r-- mritunjay/mritunjay 717 2020-06-06 03:35 ptpd-master/src/def/message/header.def
-rw-r--r-- mritunjay/mritunjay 229 2020-06-06 03:35 ptpd-master/src/def/message/signaling.def
-rw-r--r-- mritunjay/mritunjay 12222 2020-06-06 03:35 ptpd-master/src/constants.h
-rw-r--r-- mritunjay/mritunjay 16380 2020-06-06 03:35 ptpd-master/src/ptpd2.8.in
-rw-r--r-- mritunjay/mritunjay 15005 2020-06-06 03:35 ptpd-master/src/ptpd.h
-rw-r--r-- mritunjay/mritunjay 5313 2020-06-06 03:35 ptpd-master/src/timingdomain.h
-rw-r--r-- mritunjay/mritunjay 1346 2020-06-06 03:35 ptpd-master/src/ptpd2.conf.minimal
-rw-r--r-- mritunjay/mritunjay 4500 2020-06-06 03:35 ptpd-master/src/ptpd.c
-rw-r--r-- mritunjay/mritunjay 455 2020-06-06 03:35 ptpd-master/README.repocheckout
drwxr-xr-x mritunjay/mritunjay 0 2020-06-06 03:35 ptpd-master/tools/
drwxr-xr-x mritunjay/mritunjay 0 2020-06-06 03:35 ptpd-master/tools/ntplib/
-rw-r--r-- mritunjay/mritunjay 141 2020-06-06 03:35 ptpd-master/tools/ntplib/NAMESPACE
drwxr-xr-x mritunjay/mritunjay 0 2020-06-06 03:35 ptpd-master/tools/ntplib/R/
-rw-r--r-- mritunjay/mritunjay 6631 2020-06-06 03:35 ptpd-master/tools/ntplib/R/ntplib.R
-rw-r--r-- mritunjay/mritunjay 489 2020-06-06 03:35 ptpd-master/tools/ntplib/DESCRIPTION
drwxr-xr-x mritunjay/mritunjay 0 2020-06-06 03:35 ptpd-master/tools/ntplib/man/
-rw-r--r-- mritunjay/mritunjay 382 2020-06-06 03:35 ptpd-master/tools/ntplib/man/ntpPeerRead.Rd
-rw-r--r-- mritunjay/mritunjay 515 2020-06-06 03:35 ptpd-master/tools/ntplib/man/ntpHistogram.Rd
-rw-r--r-- mritunjay/mritunjay 504 2020-06-06 03:35 ptpd-master/tools/ntplib/man/ntpLoopRead.Rd
-rw-r--r-- mritunjay/mritunjay 421 2020-06-06 03:35 ptpd-master/tools/ntplib/man/ntpLoopStats.Rd
-rw-r--r-- mritunjay/mritunjay 529 2020-06-06 03:35 ptpd-master/tools/ntplib/man/ntpGraph.Rd
-rwxr-xr-x mritunjay/mritunjay 2323 2020-06-06 03:35 ptpd-master/tools/compare.R
-rwxr-xr-x mritunjay/mritunjay 2002 2020-06-06 03:35 ptpd-master/tools/offset.R
-rwxr-xr-x mritunjay/mritunjay 478 2020-06-06 03:35 ptpd-master/tools/filter_response.m
-rwxr-xr-x mritunjay/mritunjay 2048 2020-06-06 03:35 ptpd-master/tools/graph.R
-rw-r--r-- mritunjay/mritunjay 303 2020-06-06 03:35 ptpd-master/tools/cleanup_sf2.sed
drwxr-xr-x mritunjay/mritunjay 0 2020-06-06 03:35 ptpd-master/tools/ptplib/
-rw-r--r-- mritunjay/mritunjay 269 2020-06-06 03:35 ptpd-master/tools/ptplib/NAMESPACE
drwxr-xr-x mritunjay/mritunjay 0 2020-06-06 03:35 ptpd-master/tools/ptplib/R/
-rw-r--r-- mritunjay/mritunjay 16322 2020-06-06 03:35 ptpd-master/tools/ptplib/R/ptplib.R
-rw-r--r-- mritunjay/mritunjay 507 2020-06-06 03:35 ptpd-master/tools/ptplib/DESCRIPTION
drwxr-xr-x mritunjay/mritunjay 0 2020-06-06 03:35 ptpd-master/tools/ptplib/man/
-rw-r--r-- mritunjay/mritunjay 464 2020-06-06 03:35 ptpd-master/tools/ptplib/man/ptpStats.Rd
-rw-r--r-- mritunjay/mritunjay 536 2020-06-06 03:35 ptpd-master/tools/ptplib/man/ptpCompare.Rd
-rw-r--r-- mritunjay/mritunjay 484 2020-06-06 03:35 ptpd-master/tools/ptplib/man/ptpOffsetStats.Rd
-rw-r--r-- mritunjay/mritunjay 381 2020-06-06 03:35 ptpd-master/tools/ptplib/man/ptpQualityRead.Rd
-rw-r--r-- mritunjay/mritunjay 511 2020-06-06 03:35 ptpd-master/tools/ptplib/man/ptpGraph.Rd
-rw-r--r-- mritunjay/mritunjay 384 2020-06-06 03:35 ptpd-master/tools/ptplib/man/ptpQualityGraph.Rd
-rw-r--r-- mritunjay/mritunjay 360 2020-06-06 03:35 ptpd-master/tools/ptplib/man/ptpHistogramCompare.Rd
-rw-r--r-- mritunjay/mritunjay 494 2020-06-06 03:35 ptpd-master/tools/ptplib/man/ptpLogRead.Rd
-rw-r--r-- mritunjay/mritunjay 348 2020-06-06 03:35 ptpd-master/tools/ptplib/man/ptpQualityStats.Rd
-rw-r--r-- mritunjay/mritunjay 356 2020-06-06 03:35 ptpd-master/tools/ptplib/man/ptpHistogram.Rd
-rw-r--r-- mritunjay/mritunjay 417 2020-06-06 03:35 ptpd-master/tools/ptplib/man/ptpQualityGraphCompare.Rd
-rwxr-xr-x mritunjay/mritunjay 7672 2020-06-06 03:35 ptpd-master/tools/snmptpq
-rwxr-xr-x mritunjay/mritunjay 2048 2020-06-06 03:35 ptpd-master/tools/stats.R
-rwxr-xr-x mritunjay/mritunjay 1987 2020-06-06 03:35 ptpd-master/tools/offset_stats.m
-rw-r--r-- mritunjay/mritunjay 336 2020-06-06 03:35 ptpd-master/tools/cleanup.sed
-rw-r--r-- mritunjay/mritunjay 2705 2020-06-06 03:35 ptpd-master/tools/README.md
-rwxr-xr-x mritunjay/mritunjay 2000 2020-06-06 03:35 ptpd-master/tools/ntpoffset.R
-rw-r--r-- mritunjay/mritunjay 36026 2020-06-07 11:02 ptpd-master/aclocal.m4
-rw-r--r-- mritunjay/mritunjay 17458 2020-06-07 14:56 ptpd-master/configure.ac
drwxr-xr-x mritunjay/mritunjay 0 2020-06-06 03:35 ptpd-master/m4/
-rw-r--r-- mritunjay/mritunjay 131 2020-06-06 03:35 ptpd-master/m4/version.m4
drwxr-xr-x mritunjay/mritunjay 0 2020-06-07 11:02 ptpd-master/autom4te.cache/
-rw-r--r-- mritunjay/mritunjay 245010 2020-06-07 11:02 ptpd-master/autom4te.cache/output.1
-rw-r--r-- mritunjay/mritunjay 7327 2020-06-07 11:02 ptpd-master/autom4te.cache/requests
-rw-r--r-- mritunjay/mritunjay 46257 2020-06-07 11:02 ptpd-master/autom4te.cache/traces.0
-rw-r--r-- mritunjay/mritunjay 245010 2020-06-07 11:02 ptpd-master/autom4te.cache/output.0
-rw-r--r-- mritunjay/mritunjay 57397 2020-06-07 11:02 ptpd-master/autom4te.cache/traces.1
-rw-r--r-- mritunjay/mritunjay 845 2020-06-06 03:35 ptpd-master/Makefile.old
-rw-r--r-- mritunjay/mritunjay 20155 2020-06-06 03:35 ptpd-master/ChangeLog
-rw-r--r-- mritunjay/mritunjay 2058 2020-06-06 03:35 ptpd-master/TODO
drwxr-xr-x mritunjay/mritunjay 0 2020-06-06 03:35 ptpd-master/packagebuild/
drwxr-xr-x mritunjay/mritunjay 0 2020-06-06 03:35 ptpd-master/packagebuild/rpm-rh/
-rw-r--r-- mritunjay/mritunjay 2050 2020-06-06 03:35 ptpd-master/packagebuild/rpm-rh/ptpd.conf
-rw-r--r-- mritunjay/mritunjay 7236 2020-06-06 03:35 ptpd-master/packagebuild/rpm-rh/ptpd.spec
-rw-r--r-- mritunjay/mritunjay 460 2020-06-06 03:35 ptpd-master/packagebuild/rpm-rh/ptpd.service
-rw-r--r-- mritunjay/mritunjay 242 2020-06-06 03:35 ptpd-master/packagebuild/rpm-rh/ptpd.sysconfig
-rw-r--r-- mritunjay/mritunjay 3256 2020-06-06 03:35 ptpd-master/packagebuild/rpm-rh/ptpd.init
-rw-r--r-- mritunjay/mritunjay 1975 2020-06-06 03:35 ptpd-master/packagebuild/rpm-rh/README.RH
-rwxr-xr-x mritunjay/mritunjay 2700 2020-06-06 03:35 ptpd-master/packagebuild/rpm-rh/rpmbuild.sh
-rw-r--r-- mritunjay/mritunjay 479 2020-06-06 03:35 ptpd-master/.gitignore
drwxr-xr-x mritunjay/mritunjay 0 2020-06-06 03:35 ptpd-master/doc/
-rw-r--r-- mritunjay/mritunjay 6505 2020-06-06 03:35 ptpd-master/doc/ptpd-2.3.0-migration-guide.html
-rw-r--r-- mritunjay/mritunjay 272225 2020-06-06 03:35 ptpd-master/doc/IEEE1588v1_vs_IEEE1588v2.pdf
-rw-r--r-- mritunjay/mritunjay 138186 2020-06-06 03:35 ptpd-master/doc/draft-ietf-tictoc-ptp-mib-01.txt
-rw-r--r-- mritunjay/mritunjay 323600 2020-06-06 03:35 ptpd-master/doc/ptpd_2005_1588_conference_paper.pdf
-rw-r--r-- mritunjay/mritunjay 4151 2020-06-06 03:35 ptpd-master/doc/index.html
-rw-r--r-- mritunjay/mritunjay 172062 2020-06-06 03:35 ptpd-master/doc/PTPBASE-MIB.txt
-rw-r--r-- mritunjay/mritunjay 2349 2020-06-06 03:35 ptpd-master/COPYRIGHT
-rwxr-xr-x mritunjay/mritunjay 243781 2020-06-07 11:02 ptpd-master/configure
-rw-r--r-- mritunjay/mritunjay 1793 2020-06-06 03:35 ptpd-master/README.md
drwxr-xr-x mritunjay/mritunjay 0 2020-06-07 11:02 ptpd-master/build-aux/
-rw-r--r-- mritunjay/mritunjay 6233 2020-06-06 03:35 ptpd-master/INSTALL
-rw-r--r-- mritunjay/mritunjay 119 2020-06-06 03:35 ptpd-master/.travis.yml
drwxr-xr-x mritunjay/mritunjay 0 2020-06-06 03:35 ptpd-master/test/
-rw-r--r-- mritunjay/mritunjay 15580 2020-06-06 03:35 ptpd-master/test/client-e2e-8023.conf
-rw-r--r-- mritunjay/mritunjay 610 2020-06-06 03:35 ptpd-master/test/testing.org
-rw-r--r-- mritunjay/mritunjay 15565 2020-06-06 03:35 ptpd-master/test/client-e2e-pcap.conf
-rw-r--r-- mritunjay/mritunjay 15558 2020-06-06 03:35 ptpd-master/test/client-e2e-socket.conf
+ tar_exit=0
+ cd ptpd-master
+ /bin/chmod -R a+rX,g-w,o-w .
+ SB_CXC=no
==> clean %{buildroot}: /home/mritunjay/development/rtems/rsb/rtems/build/tmp/ptpd-master-arm-rtems5-1-1000
+ echo ==> clean %{buildroot}: /home/mritunjay/development/rtems/rsb/rtems/build/tmp/ptpd-master-arm-rtems5-1-1000
+ /bin/rm -rf /home/mritunjay/development/rtems/rsb/rtems/build/tmp/ptpd-master-arm-rtems5-1-1000
+ /bin/mkdir -p /home/mritunjay/development/rtems/rsb/rtems/build/tmp/ptpd-master-arm-rtems5-1-1000
+ echo ==> %build:
==> %build:
+ pwd
+ test x86_64-linux-gnu != arm-rtems5
+ test -z -o arm-rtems5 ==
/home/mritunjay/development/rtems/rsb/rtems/build/ptpd-master-arm-rtems5-1/do-build: 102: test: arm-rtems5: unexpected operator
+ build_dir=build-cxc
+ mkdir -p build-cxc
+ cd build-cxc
+ echo arm-rtems5-gcc
+ sed -e s,-std=gnu99 ,,
+ CC=arm-rtems5-gcc
+ echo arm-rtems5-g++
+ CXX=arm-rtems5-g++
+ CPPFLAGS=-I/home/mritunjay/development/rtems/5/arm-rtems5/xilinx_zynq_a9_qemu/lib/include
+ CFLAGS=-qrtems -B/home/mritunjay/development/rtems/5/arm-rtems5/lib/ -B/home/mritunjay/development/rtems/5/arm-rtems5/xilinx_zynq_a9_qemu/lib/ --specs bsp_specs -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O0 -g -ffunction-sections -fdata-sections
+ CXXFLAGS=-qrtems -B/home/mritunjay/development/rtems/5/arm-rtems5/lib/ -B/home/mritunjay/development/rtems/5/arm-rtems5/xilinx_zynq_a9_qemu/lib/ --specs bsp_specs -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O0 -g -ffunction-sections -fdata-sections
+ LDFLAGS=-L/home/mritunjay/development/rtems/5/arm-rtems5/xilinx_zynq_a9_qemu/lib -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -L/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/net/ptpd/home/mritunjay/development/rtems/5/lib
+ LDLIBS=-lbsd -lm -lz -lrtemsdefaultconfig
+ LIBS=-lbsd -lm -lz -lrtemsdefaultconfig
+ CPPFLAGS_FOR_HOST=-I/home/mritunjay/development/rtems/5/arm-rtems5/xilinx_zynq_a9_qemu/lib/include
+ CFLAGS_FOR_HOST=-qrtems -B/home/mritunjay/development/rtems/5/arm-rtems5/lib/ -B/home/mritunjay/development/rtems/5/arm-rtems5/xilinx_zynq_a9_qemu/lib/ --specs bsp_specs -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O0 -g -ffunction-sections -fdata-sections
+ CXXFLAGS_FOR_HOST=-qrtems -B/home/mritunjay/development/rtems/5/arm-rtems5/lib/ -B/home/mritunjay/development/rtems/5/arm-rtems5/xilinx_zynq_a9_qemu/lib/ --specs bsp_specs -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O0 -g -ffunction-sections -fdata-sections
+ LDFLAGS_FOR_HOST=-L/home/mritunjay/development/rtems/5/arm-rtems5/xilinx_zynq_a9_qemu/lib -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -L/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/net/ptpd/home/mritunjay/development/rtems/5/lib
+ LDLIBS_FOR_HOST=-lbsd -lm -lz -lrtemsdefaultconfig
+ LIBS_FOR_HOST=-lbsd -lm -lz -lrtemsdefaultconfig
+ echo gcc -qrtems -B/home/mritunjay/development/rtems/5/arm-rtems5/lib/ -B/home/mritunjay/development/rtems/5/arm-rtems5/xilinx_zynq_a9_qemu/lib/ --specs bsp_specs -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O0 -g -ffunction-sections -fdata-sections
+ CC_FOR_HOST=gcc -qrtems -B/home/mritunjay/development/rtems/5/arm-rtems5/lib/ -B/home/mritunjay/development/rtems/5/arm-rtems5/xilinx_zynq_a9_qemu/lib/ --specs bsp_specs -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O0 -g -ffunction-sections -fdata-sections
+ echo g++ -qrtems -B/home/mritunjay/development/rtems/5/arm-rtems5/lib/ -B/home/mritunjay/development/rtems/5/arm-rtems5/xilinx_zynq_a9_qemu/lib/ --specs bsp_specs -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O0 -g -ffunction-sections -fdata-sections
+ CXX_FOR_HOST=g++ -qrtems -B/home/mritunjay/development/rtems/5/arm-rtems5/lib/ -B/home/mritunjay/development/rtems/5/arm-rtems5/xilinx_zynq_a9_qemu/lib/ --specs bsp_specs -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O0 -g -ffunction-sections -fdata-sections
+ CFLAGS_FOR_BUILD=-O2 -g -pipe -I/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/net/ptpd/home/mritunjay/development/rtems/5/include
+ CXXFLAGS_FOR_BUILD=-O2 -g -pipe -I/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/net/ptpd/home/mritunjay/development/rtems/5/include
+ LDFLAGS_FOR_BUILD= -L/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/net/ptpd/home/mritunjay/development/rtems/5/lib
+ LDLIBS_FOR_BUILD=
+ LIBS_FOR_BUILD=
+ echo gcc -O2 -g -pipe -I/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/net/ptpd/home/mritunjay/development/rtems/5/include
+ CC_FOR_BUILD=gcc -O2 -g -pipe -I/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/net/ptpd/home/mritunjay/development/rtems/5/include
+ echo g++ -O2 -g -pipe -I/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/net/ptpd/home/mritunjay/development/rtems/5/include
+ CXX_FOR_BUILD=g++ -O2 -g -pipe -I/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/net/ptpd/home/mritunjay/development/rtems/5/include
+ export CC CXX CPPFLAGS CFLAGS CXXFLAGS LDFLAGS LIBS LDLIBS
+ export CC_FOR_HOST CXX_FOR_HOST CPPFLAGS_FOR_HOST CFLAGS_FOR_HOST CXXFLAGS_FOR_HOST LDFLAGS_FOR_HOST LDLIBS_FOR_HOST LIBS_FOR_HOST
+ export CC_FOR_BUILD CXX_FOR_BUILD CFLAGS_FOR_BUILD CXXFLAGS_FOR_BUILD LDFLAGS_FOR_BUILD LDLIBS_FOR_BUILS LIBS_FOR_BUILS
+ ../ptpd-master/configure --host=arm-rtems5 --prefix=/home/mritunjay/development/rtems/5 --bindir=/home/mritunjay/development/rtems/5/arm-rtems5/xilinx_zynq_a9_qemu/bin --exec_prefix=/home/mritunjay/development/rtems/5/arm-rtems5/xilinx_zynq_a9_qemu --includedir=/home/mritunjay/development/rtems/5/arm-rtems5/xilinx_zynq_a9_qemu/lib/include --libdir=/home/mritunjay/development/rtems/5/arm-rtems5/xilinx_zynq_a9_qemu/lib --libexecdir=/home/mritunjay/development/rtems/5/arm-rtems5/xilinx_zynq_a9_qemu/libexec --mandir=/home/mritunjay/development/rtems/5/arm-rtems5/xilinx_zynq_a9_qemu/share/man --infodir=/home/mritunjay/development/rtems/5/arm-rtems5/xilinx_zynq_a9_qemu/share/info --datadir=/home/mritunjay/development/rtems/5/arm-rtems5/xilinx_zynq_a9_qemu/share --disable-shared --disable-statistics --enable-slave-only --disable-posix-timers --with-max-unicast-destinations=2048 --enable-experimental-options
configure: error: cannot find install-sh, install.sh, or shtool in build-aux "../ptpd-master"/build-aux
shell cmd failed: /bin/sh -ex /home/mritunjay/development/rtems/rsb/rtems/build/ptpd-master-arm-rtems5-1/do-build
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200614/2989f34c/attachment-0001.obj>
