[PATCH RTEMS v2 5/6] libfreebsd: Port OFW to RTEMS
Christian Mauderer oss at c-mauderer.de
Sun Jun 14 12:18:19 UTC 2020
On 14/06/2020 13:37, Vijay Kumar Banerjee wrote:
> On Sat, Jun 13, 2020 at 11:44 PM Niteesh G. S. <niteesh.gs at gmail.com> wrote:
>> On Sat, Jun 13, 2020 at 6:30 PM Vijay Kumar Banerjee <vijay at rtems.org> wrote:
>>> On Thu, Jun 11, 2020 at 5:53 PM G S Niteesh Babu <niteesh.gs at gmail.com> wrote:
>>>> The following files have been ported to RTEMS
>>>> 1) openfirm.h
>>>> 2) openfirm.c
>>>> 3) ofw_fdt.c
>>>>  cpukit/libfreebsd/dev/ofw/ofw_fdt.c  | 146 ++++++++++++++++++++++++++-
>>>>  cpukit/libfreebsd/dev/ofw/openfirm.c |  58 ++++++++++-
>>>>  cpukit/libfreebsd/dev/ofw/openfirm.h |  17 ++++
>>>>  3 files changed, 219 insertions(+), 2 deletions(-)
>>>> diff --git a/cpukit/libfreebsd/dev/ofw/ofw_fdt.c b/cpukit/libfreebsd/dev/ofw/ofw_fdt.c
>>>> index e4f72e8142..aba170d67a 100644
>>>> --- a/cpukit/libfreebsd/dev/ofw/ofw_fdt.c
>>>> +++ b/cpukit/libfreebsd/dev/ofw/ofw_fdt.c
>>>> @@ -30,9 +30,12 @@
>>>>  #include <sys/cdefs.h>
>>>> +#ifndef __rtems__
>>>>  __FBSDID("$FreeBSD$");
>>>> +#endif /* __rtems__ */
>>>>  #include <sys/param.h>
>>>> +#ifndef __rtems__
>>>>  #include <sys/kernel.h>
>>>>  #include <sys/malloc.h>
>>>>  #include <sys/systm.h>
>>>> @@ -45,9 +48,20 @@ __FBSDID("$FreeBSD$");
>>>>  #include <dev/ofw/ofwvar.h>
>>>>  #include <dev/ofw/openfirm.h>
>>>>  #include <dev/ofw/ofw_bus_subr.h>
>>>>  #include "ofw_if.h"
>>>> +#ifdef __rtems__
>>>> +#include <rtems.h>
>>>> +#include <rtems/sysinit.h>
>>>> +#include <bsp/fatal.h>
>>>> +#include <libfdt.h>
>>>> +#include <assert.h>
>>>> +#include "openfirm.h"
>>>> +#ifndef __rtems__
>>>>  #ifdef DEBUG
>>>>  #define debugf(fmt, args...) do { printf("%s(): ", __func__);  \
>>>>      printf(fmt,##args); } while (0)
>>>> @@ -63,6 +77,7 @@ __FBSDID("$FreeBSD$");
>>>>  #define FDT_MARVELL
>>>>  #endif
>>>>  #endif
>>>>  static int ofw_fdt_init(ofw_t, void *);
>>>>  static phandle_t ofw_fdt_peer(ofw_t, phandle_t);
>>>> @@ -78,6 +93,7 @@ static ssize_t ofw_fdt_canon(ofw_t, const char *, char *, size_t);
>>>>  static phandle_t ofw_fdt_finddevice(ofw_t, const char *);
>>>>  static ssize_t ofw_fdt_instance_to_path(ofw_t, ihandle_t, char *, size_t);
>>>>  static ssize_t ofw_fdt_package_to_path(ofw_t, phandle_t, char *, size_t);
>>>> +#ifndef __rtems__
>>>>  static int ofw_fdt_interpret(ofw_t, const char *, int, cell_t *);
>>>>  static ofw_method_t ofw_fdt_methods[] = {
>>>> @@ -104,9 +120,11 @@ static ofw_def_t ofw_fdt = {
>>>>         0
>>>>  OFW_DEF(ofw_fdt);
>>>>  static void *fdtp = NULL;
>>>> +#ifndef __rtems__
>>>>  static int
>>>>  sysctl_handle_dtb(SYSCTL_HANDLER_ARGS)
>>>> @@ -127,6 +145,27 @@ sysctl_register_fdt_oid(void *arg)
>>>>             sysctl_handle_dtb, "", "Device Tree Blob");
>>>>  SYSINIT(dtb_oid, SI_SUB_KMEM, SI_ORDER_ANY, sysctl_register_fdt_oid, NULL);
>>>> +#else /* __rtems__ */
>>>> +const void* bsp_fdt_get(void);
>>> Why is it declared here? The function declaration is in fdt.h which is
>>> included in the libfdt.h
>> We cannot include a BSP headers from cpukit.
> The definition of the function is in bsps/shared/start so we're
> already using code from the bsps/ here. I wonder if this raises the
> question of whether cpukit is the right location for this driver or if
> we should use the bsps codes in this driver as a special case?
I wondered about that too. That's why Niteesh moved it in an earlier
patch set. I think Sebastian said that it would be better in cpukit.
But I'm not that happy with the current solution either. That code
wouldn't even link without the bsp_fdt_get function. Is there an
alternative that we could use that would link?
>>>> +static void
>>>> +ofw_init(void)
>>>> +       int rv;
>>>> +       const void *fdt;
>>>> +       fdt = bsp_fdt_get();
>>>> +       rv = ofw_fdt_init(NULL, fdt);
>>>> +       /* Fatal if invalid FDT is provided */
>>>> +       if (rv != 0)
>>>> +               bsp_fatal(LIBFREEBSD_FATAL_INVALID_FDT);
>>>> +RTEMS_SYSINIT_ITEM(
>>>> +       ofw_init,
>>>> +       RTEMS_SYSINIT_BSP_START,
>>>> +       RTEMS_SYSINIT_ORDER_FIRST
>>>>  static int
>>>>  ofw_fdt_init(ofw_t ofw, void *data)
>>>> @@ -297,7 +336,11 @@ ofw_fdt_getprop(ofw_t ofw, phandle_t package, const char *propname, void *buf,
>>>>         if (prop == NULL)
>>>>                 return (-1);
>>>> +#ifndef __rtems__
>>>>         bcopy(prop, buf, min(len, buflen));
>>>> +       memcpy(buf, prop, MIN(len, buflen));
>>>>         return (len);
>>>> @@ -407,6 +450,7 @@ ofw_fdt_package_to_path(ofw_t ofw, phandle_t package, char *buf, size_t len)
>>>>         return (-1);
>>>> +#ifndef __rtems__
>>>>  #if defined(FDT_MARVELL)
>>>>  static int
>>>>  ofw_fdt_fixup(ofw_t ofw)
>>>> @@ -476,4 +520,104 @@ ofw_fdt_interpret(ofw_t ofw, const char *cmd, int nret, cell_t *retvals)
>>>>  #else
>>>>         return (0);
>>>>  #endif
>>>> \ No newline at end of file
>>>> +#ifdef __rtems__
>>>> +int
>>>> +OFW_INIT(ofw_t ofw_obj, void *cookie)
>>>> +       return (ofw_fdt_init(ofw_obj, cookie));
>>>> +phandle_t
>>>> +OFW_PEER(ofw_t ofw_obj, phandle_t node)
>>>> +       return (ofw_fdt_peer(ofw_obj, node));
>>>> +phandle_t
>>>> +OFW_CHILD(ofw_t ofw_obj, phandle_t node)
>>>> +       return (ofw_fdt_child(ofw_obj, node));
>>>> +phandle_t
>>>> +OFW_PARENT(ofw_t ofw_obj, phandle_t node)
>>>> +       return (ofw_fdt_parent(ofw_obj, node));
>>>> +phandle_t
>>>> +OFW_INSTANCE_TO_PACKAGE(ofw_t ofw_obj, ihandle_t instance)
>>>> +       return (ofw_fdt_instance_to_package(ofw_obj, instance));
>>>> +ssize_t
>>>> +OFW_GETPROPLEN(ofw_t ofw_obj, phandle_t package, const char *propname)
>>>> +       return (ofw_fdt_getproplen(ofw_obj, package, propname));
>>>> +ssize_t
>>>> +OFW_GETPROP(ofw_t ofw_obj, phandle_t package, const char *propname,
>>>> +    void *buf, size_t buflen
>>>> +       return (ofw_fdt_getprop(ofw_obj, package, propname, buf, buflen));
>>>> +int
>>>> +OFW_NEXTPROP(ofw_t ofw_obj, phandle_t package, const char *prev, char *buf,
>>>> +    size_t size)
>>>> +       return (ofw_fdt_nextprop(ofw_obj, package, prev, buf, size));
>>>> +int
>>>> +OFW_SETPROP(ofw_t ofw_obj, phandle_t package, const char *propname,
>>>> +    const void *buf, size_t len)
>>>> +       return (ofw_fdt_setprop(ofw_obj, package, propname, buf, len));
>>>> +ssize_t
>>>> +OFW_CANON(ofw_t ofw_obj, const char *device, char *buf, size_t len)
>>>> +       return (ofw_fdt_canon(ofw_obj, device, buf, len));
>>>> +phandle_t
>>>> +OFW_FINDDEVICE(ofw_t ofw_obj, const char *device)
>>>> +       return (ofw_fdt_finddevice(ofw_obj, device));
>>>> +ssize_t
>>>> +OFW_INSTANCE_TO_PATH(ofw_t ofw_obj, ihandle_t instance, char *buf,
>>>> +    size_t len)
>>>> +       return (ofw_fdt_instance_to_path(ofw_obj, instance, buf, len));
>>>> +ssize_t
>>>> +OFW_PACKAGE_TO_PATH(ofw_t ofw_obj, phandle_t package, char *buf,
>>>> +    size_t len)
>>>> +       return (ofw_fdt_package_to_path(ofw_obj, package, buf, len));
>>>> diff --git a/cpukit/libfreebsd/dev/ofw/openfirm.c b/cpukit/libfreebsd/dev/ofw/openfirm.c
>>>> index 50ebf2cf16..e7a67cfd34 100644
>>>> --- a/cpukit/libfreebsd/dev/ofw/openfirm.c
>>>> +++ b/cpukit/libfreebsd/dev/ofw/openfirm.c
>>>> @@ -58,26 +58,37 @@
>>>> +#ifndef __rtems__
>>>>  #include "opt_platform.h"
>>>> +#ifndef __rtems__
>>>>  #include <sys/lock.h>
>>>>  #include <sys/mutex.h>
>>>>  #include <sys/queue.h>
>>>>  #include <sys/endian.h>
>>>> +#ifndef __rtems__
>>>>  #include <machine/stdarg.h>
>>>>  #include "ofw_if.h"
>>>> +#ifdef __rtems__
>>>> +#include "../../rtems-freebsd-helper.h"
>>> Can we add the file rtems-freebsd-helper.h in somewhere like
>>> libfreebsd/include and install this header file? This will avoid
>>> future confusions with the number of dots required and we can have
>>> something like <libfreebsd/rtems-freebsd-helper.h>
>> We still haven't decided where to place the FreeBSD header files.
>> Once we decide upon this I'll move it and change all references.
>> Since we have also planned to move all FreeBSD sources under
>> libfreebsd/freebsd this patch is not valid anymore.
>> But the code will remain the same so we can use this to discuss
>> changes but it is not valid for pushing.
> Ok. Thanks for the note. libfreebsd/freebsd sounds like an approach
> similar to libbsd so it should be OK.
> We can write a post to the devel regarding the plan so that we can get
> ideas from the devel as well. This will make it easier to merge it
> later as the plan will be understood by everyone beforehand.
> Best regards,
> Vijay
>>>> +#ifndef __rtems__
>>>>  static void OF_putchar(int c, void *arg);
>>>>  MALLOC_DEFINE(M_OFWPROP, "openfirm", "Open Firmware properties");
>>>> @@ -85,7 +96,9 @@ MALLOC_DEFINE(M_OFWPROP, "openfirm", "Open Firmware properties");
>>>>  static ihandle_t stdout;
>>>>  static ofw_def_t       *ofw_def_impl = NULL;
>>>>  static ofw_t           ofw_obj;
>>>> +#ifndef __rtems__
>>>>  static struct ofw_kobj ofw_kernel_obj;
>>>>  static struct kobj_ops ofw_kernel_kops;
>>>> @@ -224,14 +237,18 @@ OF_install(char *name, int prio)
>>>>         return (FALSE);
>>>>  /* Initializer */
>>>>  int
>>>>  OF_init(void *cookie)
>>>> +#ifndef __rtems__
>>>>         phandle_t chosen;
>>>>         int rv;
>>>> +#ifndef __rtems__
>>>>         if (ofw_def_impl == NULL)
>>>>                 return (-1);
>>>> @@ -242,17 +259,21 @@ OF_init(void *cookie)
>>>>         kobj_class_compile_static(ofw_def_impl, &ofw_kernel_kops);
>>>>         kobj_init_static((kobj_t)ofw_obj, ofw_def_impl);
>>>>         rv = OFW_INIT(ofw_obj, cookie);
>>>> +#ifndef __rtems__
>>>>         if ((chosen = OF_finddevice("/chosen")) != -1)
>>>>                 if (OF_getencprop(chosen, "stdout", &stdout,
>>>>                     sizeof(stdout)) == -1)
>>>>                         stdout = -1;
>>>>         return (rv);
>>>> +#ifndef __rtems__
>>>>  static void
>>>>  OF_putchar(int c, void *arg __unused)
>>>> @@ -314,6 +335,7 @@ OF_interpret(const char *cmd, int nreturns, ...)
>>>>         return (status);
>>>>   * Device tree functions
>>>> @@ -324,8 +346,10 @@ phandle_t
>>>>  OF_peer(phandle_t node)
>>>> +#ifndef __rtems__
>>>>                 return (0);
>>>>         return (OFW_PEER(ofw_obj, node));
>>>> @@ -335,8 +359,10 @@ phandle_t
>>>>  OF_child(phandle_t node)
>>>> +#ifndef __rtems__
>>>>                 return (0);
>>>>         return (OFW_CHILD(ofw_obj, node));
>>>> @@ -346,8 +372,10 @@ phandle_t
>>>>  OF_parent(phandle_t node)
>>>> +#ifndef __rtems__
>>>>                 return (0);
>>>>         return (OFW_PARENT(ofw_obj, node));
>>>> @@ -357,8 +385,10 @@ phandle_t
>>>>  OF_instance_to_package(ihandle_t instance)
>>>> +#ifndef __rtems__
>>>>                 return (-1);
>>>>         return (OFW_INSTANCE_TO_PACKAGE(ofw_obj, instance));
>>>> @@ -368,8 +398,10 @@ ssize_t
>>>>  OF_getproplen(phandle_t package, const char *propname)
>>>> +#ifndef __rtems__
>>>>                 return (-1);
>>>>         return (OFW_GETPROPLEN(ofw_obj, package, propname));
>>>> @@ -387,8 +419,10 @@ ssize_t
>>>>  OF_getprop(phandle_t package, const char *propname, void *buf, size_t buflen)
>>>> +#ifndef __rtems__
>>>>                 return (-1);
>>>>         return (OFW_GETPROP(ofw_obj, package, propname, buf, buflen));
>>>> @@ -532,8 +566,10 @@ int
>>>>  OF_nextprop(phandle_t package, const char *previous, char *buf, size_t size)
>>>> +#ifndef __rtems__
>>>>                 return (-1);
>>>>         return (OFW_NEXTPROP(ofw_obj, package, previous, buf, size));
>>>> @@ -543,8 +579,10 @@ int
>>>>  OF_setprop(phandle_t package, const char *propname, const void *buf, size_t len)
>>>> +#ifndef __rtems__
>>>>                 return (-1);
>>>>         return (OFW_SETPROP(ofw_obj, package, propname, buf,len));
>>>> @@ -554,8 +592,10 @@ ssize_t
>>>>  OF_canon(const char *device, char *buf, size_t len)
>>>> +#ifndef __rtems__
>>>>                 return (-1);
>>>>         return (OFW_CANON(ofw_obj, device, buf, len));
>>>> @@ -565,8 +605,10 @@ phandle_t
>>>>  OF_finddevice(const char *device)
>>>> +#ifndef __rtems__
>>>>                 return (-1);
>>>>         return (OFW_FINDDEVICE(ofw_obj, device));
>>>> @@ -576,8 +618,10 @@ ssize_t
>>>>  OF_instance_to_path(ihandle_t instance, char *buf, size_t len)
>>>> +#ifndef __rtems__
>>>>                 return (-1);
>>>>         return (OFW_INSTANCE_TO_PATH(ofw_obj, instance, buf, len));
>>>> @@ -587,8 +631,10 @@ ssize_t
>>>>  OF_package_to_path(phandle_t package, char *buf, size_t len)
>>>> +#ifndef __rtems__
>>>>                 return (-1);
>>>>         return (OFW_PACKAGE_TO_PATH(ofw_obj, package, buf, len));
>>>> @@ -626,14 +672,18 @@ OF_child_xref_phandle(phandle_t parent, phandle_t xref)
>>>>  phandle_t
>>>>  OF_node_from_xref(phandle_t xref)
>>>> +#ifndef __rtems__
>>>>         struct xrefinfo *xi;
>>>>         phandle_t node;
>>>> +#ifndef __rtems__
>>>>         if (xref_init_done) {
>>>>                 if ((xi = xrefinfo_find(xref, FIND_BY_XREF)) == NULL)
>>>>                         return (xref);
>>>>                 return (xi->node);
>>>>         if ((node = OF_child_xref_phandle(OF_peer(0), xref)) == -1)
>>>>                 return (xref);
>>>> @@ -643,14 +693,18 @@ OF_node_from_xref(phandle_t xref)
>>>>  phandle_t
>>>>  OF_xref_from_node(phandle_t node)
>>>> +#ifndef __rtems__
>>>>         phandle_t xref;
>>>> +#ifndef __rtems__
>>>>                 if ((xi = xrefinfo_find(node, FIND_BY_NODE)) == NULL)
>>>>                         return (node);
>>>>                 return (xi->xref);
>>>>         if (OF_getencprop(node, "phandle", &xref, sizeof(xref)) == -1 &&
>>>>             OF_getencprop(node, "ibm,phandle", &xref, sizeof(xref)) == -1 &&
>>>> @@ -659,6 +713,7 @@ OF_xref_from_node(phandle_t node)
>>>>         return (xref);
>>>> +#ifndef __rtems__
>>>>  device_t
>>>>  OF_device_from_xref(phandle_t xref)
>>>> @@ -845,4 +900,5 @@ OF_exit()
>>>>         for (;;)                        /* just in case */
>>>> diff --git a/cpukit/libfreebsd/dev/ofw/openfirm.h b/cpukit/libfreebsd/dev/ofw/openfirm.h
>>>> index 74a7075367..b4f6bf292a 100644
>>>> --- a/cpukit/libfreebsd/dev/ofw/openfirm.h
>>>> +++ b/cpukit/libfreebsd/dev/ofw/openfirm.h
>>>> @@ -63,7 +63,12 @@
>>>>  #define _DEV_OPENFIRM_H_
>>>>  #include <sys/types.h>
>>>> +#ifndef __rtems__
>>>>  #include <machine/_bus.h>
>>>> +#include <rtems.h>
>>>>   * Prototypes for Open Firmware Interface Routines
>>>> @@ -73,7 +78,12 @@ typedef uint32_t     ihandle_t;
>>>>  typedef uint32_t       phandle_t;
>>>>  typedef uint32_t       pcell_t;
>>>> +#ifdef __rtems__
>>>> +typedef uint32_t       cell_t;
>>>>  #ifdef _KERNEL
>>>> +#ifndef __rtems__
>>>>  #include <machine/ofw_machdep.h>
>>>> @@ -86,8 +96,10 @@ MALLOC_DECLARE(M_OFWPROP);
>>>>  boolean_t      OF_install(char *name, int prio);
>>>> +#endif /* __rtems__*/
>>>>  int            OF_init(void *cookie);
>>>> +#ifndef __rtems__
>>>>   * Known Open Firmware interface names
>>>> @@ -100,6 +112,7 @@ int         OF_init(void *cookie);
>>>>  /* Generic functions */
>>>>  int            OF_test(const char *name);
>>>>  void           OF_printf(const char *fmt, ...);
>>>>  /* Device tree functions */
>>>>  phandle_t      OF_peer(phandle_t node);
>>>> @@ -141,6 +154,7 @@ ssize_t             OF_package_to_path(phandle_t node, char *buf, size_t len);
>>>>  phandle_t      OF_node_from_xref(phandle_t xref);
>>>>  phandle_t      OF_xref_from_node(phandle_t node);
>>>> +#ifndef __rtems__
>>>>   * When properties contain references to other nodes using xref handles it is
>>>>   * often necessary to use interfaces provided by the driver for the referenced
>>>> @@ -158,9 +172,11 @@ void               OF_close(ihandle_t instance);
>>>>  ssize_t                OF_read(ihandle_t instance, void *buf, size_t len);
>>>>  ssize_t                OF_write(ihandle_t instance, const void *buf, size_t len);
>>>>  int            OF_seek(ihandle_t instance, uint64_t where);
>>>>  phandle_t      OF_instance_to_package(ihandle_t instance);
>>>>  ssize_t                OF_instance_to_path(ihandle_t instance, char *buf, size_t len);
>>>> +#ifndef __rtems__
>>>>  int            OF_call_method(const char *method, ihandle_t instance,
>>>>                     int nargs, int nreturns, ...);
>>>> @@ -183,5 +199,6 @@ int         OF_interpret(const char *cmd, int nreturns, ...);
>>>>  int            OF_decode_addr(phandle_t dev, int regno, bus_space_tag_t *ptag,
>>>>                     bus_space_handle_t *phandle, bus_size_t *sz);
>>>>  #endif /* _KERNEL */
>>>>  #endif /* _DEV_OPENFIRM_H_ */
>>>> 2.17.1
