[PATCH 2/2] Adding strong and weak definitions
Richi Dubey richidubey at gmail.com
Mon Jun 15 11:32:29 UTC 2020
Hi,
Thanks for your quick response. I am getting the following error:
richi at YouAreAmazing:~/rtems-qual$ git pull
Already up to date.
richi at YouAreAmazing:~/rtems-qual$ ./spec2doc.py
  File "./spec2doc.py", line 31
    def main() -> None:
SyntaxError: invalid syntax
Is it because I am running Python 2.7.17?
On Wed, Jun 10, 2020 at 9:07 PM Sebastian Huber <
> On 10/06/2020 16:41, Richi Dubey wrote:
> > Hi,
> > Please mark the following required changes:
> > 1) Add: cd rtems-qual/
> > After git clone and before git submodule init.
> > 2) I am getting the following error on running git submodule update:
> > richi at YouAreAmazing:~/rtems-qual$ git submodule update
> > Cloning into '/home/richi/rtems-qual/external/rsb'...
> > Cloning into '/home/richi/rtems-qual/external/rtems'...
> > Cloning into '/home/richi/rtems-qual/external/rtems-docs'...
> > Submodule path 'external/rsb': checked out
> > '9482a1b33b4c8552f6affa582664b4ac25f9cdf4'
> > error: Server does not allow request for unadvertised object
> > aaa638b1550e94b37df382474fe4785a6cc7d350
> > Fetched in submodule path 'external/rtems', but it did not contain
> > aaa638b1550e94b37df382474fe4785a6cc7d350. Direct fetching of that
> > commit failed.
> > I don't understand this error.
> Sorry, I fixed this issue. Please do a:
> git pull
> git submodule init
> make env
> > 3) Is the space in ". env/bin/activate" intentional?
> Yes:
> https://unix.stackexchange.com/questions/114300/whats-the-meaning-of-a-dot-before-a-command-in-shell
> > 4) I do not know how to use cite, Can i use it directly in the text
> field?
> Yes, just use :cite:`XYZ` in the text field.
> > 5) When I run ./spec2doc.py, I get the following error:
> > (env) richi at YouAreAmazing:~/rtems-qual$ ./spec2doc.py
> > Traceback (most recent call last):
> >    File "./spec2doc.py", line 41, in <module>
> >      main()
> >    File "./spec2doc.py", line 34, in main
> >      item_cache = rtemsqual.items.ItemCache(config["spec"])
> >    File "/home/richi/rtems-qual/rtemsqual/items.py", line 331, in
> __init__
> >      self._load_items(config)
> >    File "/home/richi/rtems-qual/rtemsqual/items.py", line 403, in
> _load_items
> >      self._load_items_recursive(path, path, cache_dir)
> >    File "/home/richi/rtems-qual/rtemsqual/items.py", line 381, in
> >      for name in os.listdir(path):
> > FileNotFoundError: [Errno 2] No such file or directory:
> 'external/rtems/spec'
> > Is it because I messed something up in the strongapa.yml ?
> > My /spec/glossary/strongapa.yml is :
> > SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> > copyrights:
> > - Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de
> > enabled-by: true
> > glossary-type: term
> > links:
> > - role: glossary-member
> >    uid: ../glossary-general
> > term: Strong APA
> > text:
> Maybe start with:
> Strong APA is a specialization of ${apa:/term}.
> >    In this model, on the arrival of a task, every task reachable
> task -> thread
> For the first use of thread use: ${thread:/term}
> >    from the newly arrived task is checked to see if an existing
> >    task can be shifted(or deallocated its processor) and newly
> space before (
> >    arrived task can take its place if the newly arrived task has
> >    a higher priority. Similar analysis is done when a task
> >    finishes its execution (Here task and thread have interchangeable
> >    defintions).
> >    :cite:`Cerqueira:2014:LPA`.
> > type: glossary
> > Please tell me how to resolve this error.
> > Thanks,
> > Richi.
> > On Mon, Jun 8, 2020 at 1:13 PM Sebastian Huber
> > <sebastian.huber at embedded-brains.de> wrote:
> >> On 07/06/2020 15:36, Sebastian Huber wrote:
> >>> On 06/06/2020 15:09, Richi Dubey wrote:
> >>>> Hii,
> >>>> Thanks for your review.
> >>>>> The glossary is generated from specification items:
> >>>>> https://git.rtems.org/sebh/rtems-qual.git/tree/spec/glos/term
> >>>>> I will work on a documentation how this works in the next days.
> >>>> Have you already submitted one? If yes, could you please send me the
> >>>> link to it. If no, Do I need to wait and learn that before sending in
> >>>> the new patch?
> >>> Yes, I sent a patch for the RTEMS Software Engineering manual:
> >>> https://lists.rtems.org/pipermail/devel/2020-June/060036.html
> >>> I will probably check it in tomorrow.
> >> I updated the documentation:
> https://docs.rtems.org/branches/master/eng/req/howto.html#getting-started
> >> Could you please try to add the new glossary terms using the method
> >> described in this how-to. You are some sort of a beta tester for this.
> >> If anything is unclear, then please complain immediately.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200615/69c1be92/attachment-0001.html>
