[PATCH] c-user: Mention possible preemptions
Mon Jun 15 12:15:37 UTC 2020
Mention that object create/delete may case the calling task to be
preempted due to the object allocator mutex.
 c-user/barrier_manager.rst           | 6 +++++-
 c-user/dual_ports_memory_manager.rst | 8 +++++---
 c-user/message_manager.rst           | 6 +++++-
 c-user/partition_manager.rst         | 6 ++++--
 c-user/rate_monotonic_manager.rst    | 6 ++++--
 c-user/semaphore_manager.rst         | 6 +++++-
 c-user/user_extensions.rst           | 7 ++++---
 7 files changed, 32 insertions(+), 13 deletions(-)
diff --git a/c-user/barrier_manager.rst b/c-user/barrier_manager.rst
index dc50eb5..4438f9c 100644
--- a/c-user/barrier_manager.rst
+++ b/c-user/barrier_manager.rst
@@ -218,7 +218,8 @@ DESCRIPTION:
     the tasks waiting at the barrier unblocked.
 NOTES:
-    This directive will not cause the calling task to be preempted.
+    This directive may cause the calling task to be preempted due to an
+    obtain and release of the object allocator mutex.
     The following barrier attribute constants are defined by RTEMS:
@@ -309,6 +310,9 @@ DESCRIPTION:
     barrier is reclaimed by RTEMS.
 NOTES:
     The calling task will be preempted if it is enabled by the task's execution
     mode and a higher priority local task is waiting on the deleted barrier.
     The calling task will NOT be preempted if all of the tasks that are waiting
diff --git a/c-user/dual_ports_memory_manager.rst b/c-user/dual_ports_memory_manager.rst
index 2c864ad..a8b7183 100644
--- a/c-user/dual_ports_memory_manager.rst
+++ b/c-user/dual_ports_memory_manager.rst
@@ -142,11 +142,12 @@ DESCRIPTION:
     is not used to store the DPCB.
 NOTES:
     The internal_address and external_address parameters must be on a four byte
     boundary.
 .. raw:: latex
    \clearpage
@@ -222,7 +223,8 @@ DESCRIPTION:
     DPCB for the deleted dual-ported memory area is reclaimed by RTEMS.
 NOTES:
     The calling task does not have to be the task that created the port.  Any
     local task that knows the port id can delete the port.
diff --git a/c-user/message_manager.rst b/c-user/message_manager.rst
index 3132f2c..0289dca 100644
--- a/c-user/message_manager.rst
+++ b/c-user/message_manager.rst
@@ -273,7 +273,8 @@ DESCRIPTION:
     specified, waiting tasks are serviced in First In-First Out order.
 NOTES:
     The following message queue attribute constants are defined by RTEMS:
@@ -396,6 +397,9 @@ DESCRIPTION:
     message buffers is reclaimed by RTEMS.
 NOTES:
     The calling task will be preempted if its preemption mode is enabled and
     one or more local tasks with a higher priority than the calling task are
     waiting on the deleted queue.  The calling task will NOT be preempted if
diff --git a/c-user/partition_manager.rst b/c-user/partition_manager.rst
index 0590c0b..765881f 100644
--- a/c-user/partition_manager.rst
+++ b/c-user/partition_manager.rst
@@ -192,7 +192,8 @@ DESCRIPTION:
     local PTCB free pool and initializes it.
 NOTES:
     The partition buffer area specified by the ``starting_address`` must be
     properly aligned.  It must be possible to directly store target
@@ -360,7 +361,8 @@ DESCRIPTION:
     deleted partition is reclaimed by RTEMS.
 NOTES:
     The calling task does not have to be the task that created the partition.
     Any local task that knows the partition id can delete the partition.
diff --git a/c-user/rate_monotonic_manager.rst b/c-user/rate_monotonic_manager.rst
index 6152005..e9241bc 100644
--- a/c-user/rate_monotonic_manager.rst
+++ b/c-user/rate_monotonic_manager.rst
@@ -666,7 +666,8 @@ DESCRIPTION:
 NOTES:
 .. raw:: latex
@@ -785,7 +786,8 @@ DESCRIPTION:
     period is reclaimed by RTEMS.
 NOTES:
-    This directive will not cause the running task to be preempted.
     A rate monotonic period can be deleted by a task other than the task which
     created the period.
diff --git a/c-user/semaphore_manager.rst b/c-user/semaphore_manager.rst
index 3e6008d..13058f3 100644
--- a/c-user/semaphore_manager.rst
+++ b/c-user/semaphore_manager.rst
@@ -376,7 +376,8 @@ DESCRIPTION:
 NOTES:
     The priority inheritance and priority ceiling algorithms are only supported
     for local, binary semaphores that use the priority task wait queue blocking
@@ -523,6 +524,9 @@ DESCRIPTION:
     this semaphore is reclaimed by RTEMS.
 NOTES:
     mode and a higher priority local task is waiting on the deleted semaphore.
diff --git a/c-user/user_extensions.rst b/c-user/user_extensions.rst
index 89b86fd..f5318da 100644
--- a/c-user/user_extensions.rst
+++ b/c-user/user_extensions.rst
@@ -487,8 +487,8 @@ DESCRIPTION:
     specified by :c:data:`table` is copied to the ESCB.
 NOTES:
 .. raw:: latex
@@ -566,7 +566,8 @@ DESCRIPTION:
     deleted extension set is reclaimed by RTEMS.
 NOTES:
     A extension set can be deleted by a task other than the task which created
     the extension set.
2.26.2
