[PATCH 2/2] Adding strong and weak definitions
Richi Dubey
richidubey at gmail.com
Mon Jun 15 12:33:04 UTC 2020
Hi,
rtems_to_spec and ./spec2doc, both are giving similar error:
$ ./spec2doc.py
Traceback (most recent call last):
File "./spec2doc.py", line 41, in <module>
main()
File "./spec2doc.py", line 37, in main
rtemsqual.glossary.generate(config["glossary"], item_cache)
File "/home/richi/rtems-qual/rtemsqual/glossary.py", line 137, in generate
_generate_project_glossary(config["project-target"], project_glossary)
File "/home/richi/rtems-qual/rtemsqual/glossary.py", line 108, in
content = _generate_glossary_content(glossary.uid_to_item)
File "/home/richi/rtems-qual/rtemsqual/glossary.py", line 68, in
text = SphinxMapper(item).substitute(item["text"])
File "/home/richi/rtems-qual/rtemsqual/items.py", line 317, in substitute
return ItemTemplate(text).substitute(self)
File "/usr/lib/python3.6/string.py", line 130, in substitute
return self.pattern.sub(convert, self.template)
File "/usr/lib/python3.6/string.py", line 123, in convert
return str(mapping[named])
File "/home/richi/rtems-qual/rtemsqual/items.py", line 307, in __getitem__
return self.map(identifier)[1]
File "/home/richi/rtems-qual/rtemsqual/items.py", line 299, in map
item = self._item.map(uid)
File "/home/richi/rtems-qual/rtemsqual/items.py", line 188, in map
return self._item_cache[self.to_abs_uid(abs_or_rel_uid)]
File "/home/richi/rtems-qual/rtemsqual/items.py", line 334, in __getitem__
return self._items[uid]
KeyError: '/glossary/apa'
(env)
I can't find apa.yml in the glossary as well. What might be wrong?
strongapa.yml:
SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
copyrights:
- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
enabled-by: true
glossary-type: term
links:
- role: glossary-member
uid: ../glossary-general
term: Strong APA
text:
Strong APA is a specialization of ${apa:/term}.
In this model, on the arrival of a ${thread:/term}, every thread
reachable from the newly arrived thread is checked to see if an
existing thread can be shifted (or deallocated its processor) and
the newly arrived thread take its place if the newly arrived thread
has a higher priority. Similar analysis is done when a thread finishes
its execution (Here, the terms task and thread have interchangeable
definitions).
:cite:`Cerqueira:2014:LPA`
type: glossary
On Mon, Jun 15, 2020 at 5:04 PM Sebastian Huber <
> On 15/06/2020 13:32, Richi Dubey wrote:
> > Thanks for your quick response. I am getting the following error:
> > richi at YouAreAmazing:~/rtems-qual$ git pull
> > Already up to date.
> > richi at YouAreAmazing:~/rtems-qual$ ./spec2doc.py
> > File "./spec2doc.py", line 31
> > def main() -> None:
> > SyntaxError: invalid syntax
> > Is it because I am running Python 2.7.17?
> Please read the README.md.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200615/8e2f6b83/attachment.html>
