Changes to libbsd for Applications?
Joel Sherrill
joel at rtems.org
Mon Jun 15 15:06:54 UTC 2020
Hi
Lou put together a simple networked application example which was last
touched back in January. It doesn't compile now. It appears that a number
of headers have moved so the network_inif.h file has at least a half dozen
includes which don't work now. I am attaching the files and would
appreciate advice/help/changes to make it work again.
It really is a simple example. It worked on the zynq qemu for sure.
Thanks.
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200615/f7e6bc7b/attachment-0001.html>
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200615/f7e6bc7b/attachment-0003.obj>
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200615/f7e6bc7b/attachment-0004.obj>
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200615/f7e6bc7b/attachment-0005.obj>
