[PATCH rtems-tools] trace: Use c++14 instead of c++11 if possible
Christian Mauderer
oss at c-mauderer.de
Mon Jun 15 15:36:07 UTC 2020
Ping.
Currently shouldn't be a matter for much hosts (less than 20 including
FreeBSD, Fedora, Arch, openSUSE according to distrowatch [1]) but I
assume that llvm 10 will spread fast.
[1]
http://distrowatch.org/search.php?pkg=llvm&relation=greaterequal&pkgver=10&distrorange=InLatest#pkgsearch
On 08/06/2020 08:52, Christian Mauderer wrote:
> llvm version 10 uses features from c++14 standard in the headers. With
> that, the record/record-main-lttng.cc doesn't build any more. This patch
> makes sure that c++14 is used if it is available.
> trace/wscript | 6 +++++-
> 1 file changed, 5 insertions(+), 1 deletion(-)
> diff --git a/trace/wscript b/trace/wscript
> index 656f92b..53a1ab4 100644
> --- a/trace/wscript
> +++ b/trace/wscript
> @@ -45,6 +45,7 @@ def configure(conf):
> if conf.check(header_name='zlib.h', features='cxx', mandatory=False):
> conf.check_cxx(lib = 'z')
> conf.check_cxx(lib = 'ws2_32', mandatory=False)
> + conf.check_cxx(cxxflags='-std=c++14', mandatory=False, define_name="HAVE_STD_CXX14")
> conf.write_config_header('config.h')
> def build(bld):
> @@ -60,7 +61,10 @@ def build(bld):
> conf['warningflags'] = ['-Wall', '-Wextra', '-pedantic']
> conf['optflags'] = bld.env.C_OPTS
> conf['cflags'] = ['-pipe', '-g'] + conf['optflags']
> - conf['cxxflags'] = ['-std=c++11'] + conf['cflags']
> + cxxstd = '-std=c++11'
> + if bld.env.HAVE_STD_CXX14:
> + cxxstd = '-std=c++14'
> + conf['cxxflags'] = [cxxstd] + conf['cflags']
> conf['linkflags'] = ['-g']
> conf['lib'] = []
> if bld.env.LIB_WS2_32:
