GSoC 2020: [rtems/rsb]: Error while adding ptp support. This time building for xilinx_zynq_a9_qemu
Heinz Junkes
junkes at fhi-berlin.mpg.de
Mon Jun 15 20:46:47 UTC 2020
If you want to get ahead, just make a version that already has a configure, then
you can save yourself the trouble with autoconf. I'd put that in the back.
Heinz
> On 15. Jun 2020, at 20:46, Mritunjay Sharma <mritunjaysharma394 at gmail.com> wrote:
> Hello everyone,
> The latest update is that by changing a couple of things in source-builder/config/ptpd-2-1.cfg which are:
> "%source setup ptpd -q -n ptpd-%{ptpd_version}
> %patch setup ptpd -p1
> +automake --add-missing
> +autoreconf --install --force
> cd ${build_top}
> %build"
> GitHub Link: https://github.com/RTEMS/rtems-source-builder/commit/413ea684f1e8672f921ce80abbc59f1e352acbc2
> The earlier configure: error: cannot find install-sh, install.sh, or shtool in build-aux "../ptpd-master"/build-aux has gone
> but another error has come as follows:
> "configure.ac:28: installing './compile'
> configure.ac:16: installing './install-sh'
> configure.ac:16: installing './missing'
> configure.ac:13: error: required file 'config.h.in' not found
> src/Makefile.am: installing './depcomp'
> shell cmd failed: /bin/sh -ex /home/mritunjay/development/rtems/rsb/rtems/build/ptpd-master-arm-rtems5-1/do-build
> error: building ptpd-master-arm-rtems5-1"
> What can be the reason for this? Should I create another tar of this and set it as the source?
> The trace and report are attached. The tutorial by Heinz has again helped me a lot!
> Thank you for that again!
> Thanks,
> Mritunjay
> On Sun, Jun 14, 2020 at 3:07 AM Mritunjay Sharma <mritunjaysharma394 at gmail.com> wrote:
> First of all Heinz, I would like to thank you for such a wonderful guide which really helped me fix a lot of errors.
> After following your advice, I made certain changes to make PTPd work,
> few errors came again but I managed to remove them with the use of Google.
> However, the recent most error has caught me in a fix and I am still trying to figure it out where I went wrong.
> https://github.com/mritunjaysharma394/rtems-source-builder/tree/master/source-builder
> https://github.com/ptpd/ptpd/compare/master...mritunjaysharma394:master
> The above two links will tell what changes I have made and the error that I am receiving now is:
> "configure: WARNING: unrecognized options: --disable-shared
> I have attached the trace log file and error report.
> I tried to google and made few more changes in ptpd Makefile.am but it didn't help.
> It will be very kind of you all to help me figure out on how to tackle this bug.
> Thanks
> Mritunjay
> On Sun, Jun 7, 2020 at 10:19 AM junkes <junkes at fhi-berlin.mpg.de> wrote:
> This is an unusually long text for the mailing list. I tried to write a kind
> of tutorial using an example for a GSOC student. I'm looking forward to the
> comments from the pros and can write it down completely.
> Hello, Mritunjay
> if I understood it correctly, one idea of the rtems source builder is to make existing
> software packages usable for RTEMS. Most existing software packages do not work without
> changes in the RTEMS environment. You have already noticed this with ptpd ;-)
> The most common auto-tools and configure have trouble making the correct
> assumptions for the rtems environment. Here you have to intervene. This can
> be done with the builder-cfg files.
> This is a bit of hard work and you have to approach it with small steps.
> You also have to use not so clean tricks in different places. When you have
> achieved the integration you can/must then try to optimize it so that it becomes
> generally valid.
> That's my policy. Maybe the others here in the maillist have more ideas, also for me.
> I have now tried to implement what I mean using a similar example (openntp).
> Unfortunately, I haven't finished yet, but I hope to clear a few hurdles for you.
> I was doing some digging around and I came across this:
> https://github.com/openntpd-portable/openntpd-portable
> Here I was then confronted with the same problems as you with autoreconf etc. Here it
> didn't work, just run autoreconf twice and generate a tar-file for installation like
> I did with the ptpd from github.
> Then I found this: https://artfiles.org/openbsd/OpenNTPD/openntpd-6.2p3.tar.gz
> Now I have made a "standard" config file for rsb:
> # OpenNTPd 6.2p3 Version 1.
> # This configuration file configure's, make's and install's OpenNTPd.
> %if %{release} == %{nil}
> %define release 1
> %endif
> Summary: NTP is the Network Time Protocol.
> Version: %{openntpd_version}
> Release: %{release}
> URL: https://github.com/openntpd-portable
> # NTP Source
> %source set openntpd https://artfiles.org/openbsd/OpenNTPD/openntpd-%{openntpd_version}.tar.gz
> %hash sha512 openntpd-%{openntpd_version}.tar.gz 56a04bfd8b161b365607673ac80086ff53ae943938fa49bf52edbc541432eca30730a46a4af581fe26ce3bbceb144cb25982a38959b7a3f9304c727fe60f9
> f50
> # Prepare the source code.
> %prep
> build_top=$(pwd)
> source_dir_openntpd="openntpd-%{openntpd_version}"
> %source setup openntpd -q -n openntpd-%{openntpd_version}
> %patch setup openntpd -p1
> cd ${build_top}
> %build
> build_top=$(pwd)
> %{build_directory}
> mkdir -p ${build_dir}
> cd ${build_dir}
> %{host_build_flags}
> ../${source_dir_openntpd}/configure \
> --host=%{_host} \
> --prefix=%{_prefix} \
> --bindir=%{_bindir} \
> --exec_prefix=%{_exec_prefix} \
> --includedir=%{_includedir} \
> --libdir=%{_libdir} \
> --libexecdir=%{_libexecdir} \
> --mandir=%{_mandir} \
> --infodir=%{_infodir} \
> --datadir=%{_datadir} \
> --disable-shared \
> --enable-static \
> --with-gnu-ld \
> --disable-https-constraint
> %{__make} all
> cd ${build_top}
> %install
> build_top=$(pwd)
> %{__rmdir} $SB_BUILD_ROOT
> cd ${build_dir}
> %{__make} DESTDIR=$SB_BUILD_ROOT install
> cd ${build_top}
> Then I "executed" that.
> [h1 at earth rtems (master *)]$ ../source-builder/sb-set-builder --log log.ntpd.txt --with-rtems-bsp=xilinx_zynq_a9_qemu --host=arm-rtems5 --prefix /home/h1/GSOC/RTEMS/5.0.0-m20
> 03 net/ntpd
> RTEMS Source Builder - Set Builder, 5 (26e335ca159e modified)
> Build Set: net/ntpd
> config: net/openntpd-6.2p3-1.cfg
> package: openntpd-6.2p3-arm-rtems5-1
> building: openntpd-6.2p3-arm-rtems5-1
> error: building openntpd-6.2p3-arm-rtems5-1
> Build FAILED
> See error report: rsb-report-openntpd-6.2p3-arm-rtems5-1.txt
> Build Set: Time 0:00:16.036623
> Build FAILED
> Error! I looked at that one:
> [h1 at earth rtems (master *)]$ tail -20 rsb-report-openntpd-6.2p3-arm-rtems5-1.txt
> CC setproctitle.lo
> CC bsd-setresgid.lo
> CC bsd-setresuid.lo
> CCLD libcompat.la
> arm-rtems5-ar: `u' modifier ignored since `D' is the default (see `U')
> CCLD libcompatnoopt.la
> make[1]: Leaving directory '/home/h1/GSOC/RTEMS_DEV/rtems-source-builder/rtems/build/openntpd-6.2p3-arm-rtems5-1/build-cxc/compat'
> Making all in src
> make[1]: Entering directory '/home/h1/GSOC/RTEMS_DEV/rtems-source-builder/rtems/build/openntpd-6.2p3-arm-rtems5-1/build-cxc/src'
> CC ntpd-client.o
> arm-rtems5-gcc: fatal error: /home/h1/GSOC/RTEMS/5.0.0-m2003/arm-rtems5/xilinx_zynq_a9_qemu/lib/bsp_specs: attempt to rename spec 'endfile' to already defined spec 'old_endfi
> le'
> compilation terminated.
> Makefile:526: recipe for target 'ntpd-client.o' failed
> make[1]: *** [ntpd-client.o] Error 1
> make[1]: Leaving directory '/home/h1/GSOC/RTEMS_DEV/rtems-source-builder/rtems/build/openntpd-6.2p3-arm-rtems5-1/build-cxc/src'
> Makefile:401: recipe for target 'all-recursive' failed
> make: *** [all-recursive] Error 1
> shell cmd failed: /bin/sh -ex /home/h1/GSOC/RTEMS_DEV/rtems-source-builder/rtems/build/openntpd-6.2p3-arm-rtems5-1/do-build
> In build/openntpd-6.2p3-arm-rtems5-1/openntpd-6.2p3/src/Makefile.am I found that CFLAGS gets includes twice which leads to this error "attempt to rename..."
> ntpd_CFLAGS = $(CFLAGS)
> ntpd_CFLAGS += -DSYSCONFDIR=\"$(sysconfdir)\"
> ntpd_CFLAGS += -DLOCALSTATEDIR=\"$(localstatedir)\"
> Then I changed the cfg-file:
> %{host_build_flags}
> # src/Makefile.am includes CFLAGS twice?
> # this leads to : bsp_specs: attempt to rename spec 'endfile' to already defined spec 'old_endfile'
> sed -i 's/ntpd_CFLAGS = $(CFLAGS)/ntpd_CFLAGS = $(CFLAGS)/g' ../${source_dir_openntpd}/src/Makefile.am
> sed -i 's/ntpd_CFLAGS += -DSYSCONFDIR=/ntpd_CFLAGS = -DSYSCONFDIR=/g' ../${source_dir_openntpd}/src/Makefile.am
> --host=%{_host} \
> Now I've come a long way, but
> asnprintf
> CC ntpd-ntp.o
> CC ntpd-ntp_dns.o
> ../../openntpd-6.2p3/src/ntp_dns.c: In function 'ntp_dns':
> ../../openntpd-6.2p3/src/ntp_dns.c:58:6: warning: implicit declaration of function 'setpriority'; did you mean 'setprotoent'? [-Wimplicit-function-declaration]
> if (setpriority(PRIO_PROCESS, 0, 0) == -1)
> setprotoent
> ../../openntpd-6.2p3/src/ntp_dns.c:58:18: error: 'PRIO_PROCESS' undeclared (first use in this function); did you mean 'EINPROGRESS'?
> EINPROGRESS
> ../../openntpd-6.2p3/src/ntp_dns.c:58:18: note: each undeclared identifier is reported only once for each function it appears in
> Makefile:624: recipe for target 'ntpd-ntp_dns.o' failed
> make[1]: *** [ntpd-ntp_dns.o] Error 1
> Now a little bit of searching...
> Adding "#include <rtems/bsd/sys/resource.h>" solves the problem.
> But the next one arises:
> CC ntpd-ntpd.o
> CC ntpd-parse.o
> parse.y: In function 'yyerror':
> parse.y:473:6: warning: implicit declaration of function 'vasprintf'; did you mean 'vasnprintf'? [-Wimplicit-function-declaration]
> parse.y: In function 'yylex':
> parse.y:686:22: warning: implicit declaration of function 'strtonum'; did you mean 'strtoul'? [-Wimplicit-function-declaration]
> CC ntpd-fake-sensors.o
> CC ntpd-server.o
> ../../openntpd-6.2p3/src/server.c: In function 'setup_listeners':
> ../../openntpd-6.2p3/src/server.c:65:21: error: 'struct if_data' has no member named 'ifi_rdomain'; did you mean 'ifi_addrlen'?
> rdomain = ifd->ifi_rdomain;
> ifi_addrlen
> Makefile:708: recipe for target 'ntpd-server.o' failed
> That looks a little more complicated. It uses an if_data structure that is probably only available in openbsd?
> But also here google helps ;-)
> Here I found a patch : https://github.com/freebsd/freebsd-ports/tree/master/net/openntpd/files
> [h1 at earth build-cxc (master *)]$ patch ../openntpd-6.2p3/src/server.c /tmp/openntp/openntpd-6.2p3/patch-src_server.c
> And it's gotten me this far:
> [h1 at earth build-cxc (master *)]$ make
> Making all in include
> make[1]: Entering directory '/home/h1/GSOC/RTEMS_DEV/rtems-source-builder/rtems/build/openntpd-6.2p3-arm-rtems5-1/build-cxc/include'
> make[1]: Nothing to be done for 'all'.
> make[1]: Leaving directory '/home/h1/GSOC/RTEMS_DEV/rtems-source-builder/rtems/build/openntpd-6.2p3-arm-rtems5-1/build-cxc/include'
> Making all in compat
> make[1]: Entering directory '/home/h1/GSOC/RTEMS_DEV/rtems-source-builder/rtems/build/openntpd-6.2p3-arm-rtems5-1/build-cxc/compat'
> Making all in src
> CC ntpd-server.o
> CC ntpd-util.o
> CCLD ntpd
> /home/h1/GSOC/RTEMS/5.0.0-m2003/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: ntpd-ntp_dns.o: in function `ntp_dns':
> /home/h1/GSOC/RTEMS_DEV/rtems-source-builder/rtems/build/openntpd-6.2p3-arm-rtems5-1/build-cxc/src/../../openntpd-6.2p3/src/ntp_dns.c:59: undefined reference to `setpriority'
> /home/h1/GSOC/RTEMS/5.0.0-m2003/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: ntpd-ntpd.o: in function `main':
> /home/h1/GSOC/RTEMS_DEV/rtems-source-builder/rtems/build/openntpd-6.2p3-arm-rtems5-1/build-cxc/src/../../openntpd-6.2p3/src/ntpd.c:243: undefined reference to `setpriority'
> /home/h1/GSOC/RTEMS/5.0.0-m2003/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: /home/h1/GSOC/RTEMS_DEV/rtems-source-builder/rtems/build/openntpd-6.2p3-arm-rtems5-1/b
> uild-cxc/src/../../openntpd-6.2p3/src/ntpd.c:251: undefined reference to `daemon'
> uild-cxc/src/../../openntpd-6.2p3/src/ntpd.c:330: undefined reference to `daemon'
> /home/h1/GSOC/RTEMS/5.0.0-m2003/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: ntpd-ntpd.o: in function `dispatch_imsg':
> /home/h1/GSOC/RTEMS_DEV/rtems-source-builder/rtems/build/openntpd-6.2p3-arm-rtems5-1/build-cxc/src/../../openntpd-6.2p3/src/ntpd.c:435: undefined reference to `daemon'
> /home/h1/GSOC/RTEMS/5.0.0-m2003/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: ntpd-ntpd.o: in function `ntpd_adjtime':
> /home/h1/GSOC/RTEMS_DEV/rtems-source-builder/rtems/build/openntpd-6.2p3-arm-rtems5-1/build-cxc/src/../../openntpd-6.2p3/src/ntpd.c:487: undefined reference to `update_time_sy
> nc_status'
> /home/h1/GSOC/RTEMS/5.0.0-m2003/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: ntpd-ntpd.o: in function `ntpd_adjfreq':
> /home/h1/GSOC/RTEMS_DEV/rtems-source-builder/rtems/build/openntpd-6.2p3-arm-rtems5-1/build-cxc/src/../../openntpd-6.2p3/src/ntpd.c:498: undefined reference to `adjfreq'
> uild-cxc/src/../../openntpd-6.2p3/src/ntpd.c:522: undefined reference to `adjfreq'
> /home/h1/GSOC/RTEMS/5.0.0-m2003/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: ntpd-ntpd.o: in function `ntpd_settime':
> /home/h1/GSOC/RTEMS_DEV/rtems-source-builder/rtems/build/openntpd-6.2p3-arm-rtems5-1/build-cxc/src/../../openntpd-6.2p3/src/ntpd.c:542: undefined reference to `settimeofday'
> /home/h1/GSOC/RTEMS/5.0.0-m2003/lib/gcc/arm-rtems5/7.5.0/../../../../arm-rtems5/bin/ld: ntpd-ntpd.o: in function `readfreq':
> /home/h1/GSOC/RTEMS_DEV/rtems-source-builder/rtems/build/openntpd-6.2p3-arm-rtems5-1/build-cxc/src/../../openntpd-6.2p3/src/ntpd.c:565: undefined reference to `adjfreq'
> uild-cxc/src/../../openntpd-6.2p3/src/ntpd.c:574: undefined reference to `adjfreq'
> collect2: error: ld returned 1 exit status
> Makefile:476: recipe for target 'ntpd' failed
> make[1]: *** [ntpd] Error 1
> This is where I am now. From now on, it's gonna be exciting. Now it's all about anchoring the daemon process in RTEMS.
> But that is nice work now. I still have to do it.
> But I wanted to show you this step-by-step so you can get over the first hurdles.
> I hope this helps you and it was not too long.
> Heinz
> On 2020-06-06 01:31, Mritunjay Sharma wrote:
>> Thank you so much Heinz for such a detailed response.
>> It really helped me a lot.
>> As advised by you and Heinz, I changed the source to https://github.com/mritunjaysharma394/ptpd/archive/master.zip
>> with suggested changes. However, I have encountered few bugs again related to autoreconf.
>> It looks somewhat like this:
>> + autoreconf -i -v
>> autoreconf: Entering directory `.'
>> autoreconf: configure.ac: not using Gettext
>> autoreconf: running: aclocal -I m4
>> autoreconf: configure.ac: tracing
>> autoreconf: configure.ac: creating directory build-aux
>> autoreconf: configure.ac: not using Libtool
>> autoreconf: running: /home/mritunjay/development/rtems/5/bin/autoconf
>> configure.ac:28: error: possibly undefined macro: AC_PROG_LIBTOOL
>> If this token and others are legitimate, please use m4_pattern_allow.
>> See the Autoconf documentation.
>> autoreconf: /home/mritunjay/development/rtems/5/bin/autoconf failed with exit status: 1
>> I have attached the error report as well and changes in cfg files can be found here:
>> https://github.com/mritunjaysharma394/rtems-source-builder/commit/6b6bb2b3bd778ebe56e9a1bf3aec1747b078fd39
>> Thanks,
>> Mritunjay
>> On Fri, Jun 5, 2020 at 2:53 AM Gedare Bloom <gedare at rtems.org> wrote:
>> On Thu, Jun 4, 2020 at 1:38 PM junkes <junkes at fhi-berlin.mpg.de> wrote:
>> > Hallo Mritunjay,
>> > You can't just take the github ptpd sources and make them work in RTEMS. You have to make some configuration
>> > and sources changes before you can build the with the rsb.
>> > Some things like the sys/cpuset.h seems not to be fully compatible yet and so the configure simply makes
>> > "wrong" decisions. E.g. defines HAVE_SYS_CPUSET_H = 1 as sys/cpuset.h exists.I played a little bit with it and reset
>> > the definition in ptpd-master/src/ptpd.h (quick and dirty) and could reduce the error messages because there is a query for
>> > this variable in the code (src/dep/sys.c):
>> > in ptpd.h after the include of the created configs :
>> > #ifdef HAVE_CONFIG_H
>> > # include <config.h>
>> > #endif /* HAVE_CONFIG_H */
>> > #undef HAVE_NTP_GETTIME
>> > #undef HAVE_SYS_CPUSET_H
>> > #ifdef linux
>> > in src/dep/sys.c
>> > #ifdef HAVE_SYS_CPUSET_H
>> > cpuset_t mask;
>> > CPU_ZERO(&mask);
>> > if(cpu >= 0) {
>> > CPU_SET(cpu,&mask);
>> > } else {
>> > int i;
>> > for(i = 0; i < CPU_SETSIZE; i++) {
>> > CPU_SET(i, &mask);
>> > return(cpuset_setaffinity(CPU_LEVEL_WHICH, CPU_WHICH_PID,
>> > -1, sizeof(mask), &mask));
>> > #endif /* HAVE_SYS_CPUSET_H */
>> > In src/dep/constants_dep.h one can find:
>> > * platform dependent */
>> > #if !defined(linux) && !defined(__NetBSD__) && !defined(__FreeBSD__) && \
>> > !defined(__APPLE__) && !defined(__OpenBSD__) && !defined(__sun) && !defined(__QNXNTO__)
>> > #error PTPD hasn't been ported to this OS - should be possible \
>> > if it's POSIX compatible, if you succeed, report it to ptpd-devel at sourceforge.net
>> > #endif
>> > here I added "&& !defined(__rtems__)
>> > and here:
>> > #if defined(__NetBSD__) || defined(__FreeBSD__) || defined(__APPLE__) || defined(__OpenBSD__) || defined(__sun) || defined(__QNXNTO__) || defined(__rtems__)
>> > # include <sys/types.h>
>> > # include <sys/socket.h>
>> > #ifdef HAVE_SYS_SOCKIO_H
>> > #include <sys/sockio.h>
>> > #endif /* HAVE_SYS_SOCKIO_H */
>> > # include <netinet/in.h>
>> > # include <net/if.h>
>> > # include <net/if_dl.h>
>> > # include <net/if_types.h>
>> > #ifdef HAVE_NET_IF_ETHER_H
>> > # include <net/if_ether.h>
>> > and so on... You'd have to bite through it once and then you will surely get it compiled.
>> Great start Heinz! Mritunjay, I think this definitely the way forward.
>> Later, you might try to circle back and fix the hacks in nicer ways by
>> learning how to make the autoconf stuff work correctly, and contribute
>> those fixes back upstream to ptpd project.
>> > HTH Heinz
>> > On 2020-06-04 20:29, Mritunjay Sharma wrote:
>> > On Thu, Jun 4, 2020 at 11:07 PM Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
>> > On 04/06/2020 16:22, Gedare Bloom wrote:
>> > >>> In the github version this code is conditional on sys/cpuset.h being present.
>> > > Well, we do have a sys/cpuset.h in newlib. It doesn't have these BSD
>> > > definitions though. Probably either:
>> > > 1. Add more stuff to sys/cpuset.h to make it support BSDisms. This
>> > > would mean adding cpuset_setaffinity support in rtems, I guess.
>> > > 2. Figure out how to disable the conditional code using the
>> > > cpuset_setaffinity function.
>> > The <sys/cpuset.h> is already as compatible as possible to glibc and
>> > FreeBSD. There is always room for improvement, however, in this area it
>> > will be difficult.
>> > Please it would be kind of you all to guide on what is the best thing I can do next. It is looking
>> > a little difficult. If something similar has been done earlier, sharing it can be a lot helpful to take a cue.
>> > Mritunjay
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
>> > devel mailing list
>> > devel at rtems.org
> <rsb-report-ptpd-master-arm-rtems5-1.txt><log>
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200615/1afffbf0/attachment-0001.bin>
