[PATCH v1 0/9] Enable SMP for pc386 based bsps
Chris Johns
chrisj at rtems.org
Tue Jun 16 08:17:51 UTC 2020
On 11/6/20 12:21 pm, Chris Johns wrote:
> On 1/6/20 12:22 am, Jan Sommer wrote:
>> Hello,
>> Here is a patch set which should enable SMP again for the pc386-based BSPs (mainly tested with pc686).
> Many thanks for these patches and your efforts.
>> So far I only tested it with qemu. Tests on real hardware are pending.
> It would be good to test results for hardware with SMP disabled. If the test
> results do not show any regressions then I am fine with these patches for RTEMS
> 5.2 with SMP documented as experimental. I will take a look at doing this.
I have finally managed to get my test PC to load a iPXE loader and with that I
can boot RTEMS. Without the changes I can run hello.exe and it prints the right
stuff on the monitor however the iPXE boot command line that use to work ...
chain tftp://10.10.5.2/rtems.exe --console=/dev/com1,115200
--printk=/dev/com1,115200
... does not generate any serial output. The output is being redirected and the
serial port because nothing appears on the monitor and I tested the cable is
working with a loop-back jumper.
Is the PC serial port driver broken?
