[PATCH] APA definitions
Richi Dubey richidubey at gmail.com
Fri Jun 19 09:51:50 UTC 2020
Hi,
Thanks again for your detailed explanation and review. I've sent in the new
patch with the changes. Also writing 'qa' after visually selecting words by
pressing v did not do anything. I also search the docs on
http://vimdoc.sourceforge.net/htmldoc/editing.html but couldn't find
anything. What is qa supposed to do? Is it related to formatting?
Please let me know.
Thanks,
Richi.
On Thu, Jun 18, 2020 at 10:42 PM Sebastian Huber <
> On 17/06/2020 14:13, Richi Dubey wrote:
> >   c-user/glossary.rst | 29 +++++++++++++++++++++++++++++
> >   1 file changed, 29 insertions(+)
> > diff --git a/c-user/glossary.rst b/c-user/glossary.rst
> > index 86350a8..1d95f26 100644
> > --- a/c-user/glossary.rst
> > +++ b/c-user/glossary.rst
> > @@ -1,5 +1,6 @@
> >   .. SPDX-License-Identifier: CC-BY-SA-4.0
> > +.. Copyright (C) 2020 Richi Dubey (richidubey at gmail.com)
> >   .. Copyright (C) 2017, 2019 embedded brains GmbH (
> http://www.embedded-brains.de)
> >   .. Copyright (C) 1988, 1998 On-Line Applications Research Corporation
> (OAR)
> > @@ -16,6 +17,13 @@ Glossary
> >           A term used to describe an object which has been created by an
> >           application.
> > +    APA
> > +        This term is an acronym for Arbitrary Processor Affinity.
> > +        In this model,
> Model of what?
> > a thread is allowed to have an arbitrary affinity to
> > +        the processor set, rather than a global mapping from one thread
> to all
> Maybe "a processor set"?
> I would say: rather than a restricted mapping to only one processor of
> the set or the ability to run on all processors of the set.
> > +        processors or one thread to one processor.
> > +        It has two variants, :term:`Weak APA` and :term:`Strong APA`.
> >       aperiodic task
> >           A task which must execute only at irregular intervals and has
> only a soft
> >           deadline.
> > @@ -777,6 +785,19 @@ Glossary
> >           :term:`return value` to indicate a successful operation or
> error
> >           conditions.
> > +    Strong APA
> > +        Strong APA is a specialization of :term:`APA`.
> > +        This variant of APA refers to a system model in which whenever a
> Is it really a system model?
> > +        :term:`thread` becomes ready for execution, recursively the
> processor
> > +        in the thread's affinity set is checked, followed by the
> processor in
> > +        the affinity set of threads that are assigned the processor
> present in
> > +        the ready thread's affinity set. This is done to find a thread
> to processor
> > +        mapping that does not violate the priority ordering and provide
> a schedule
> > +        with a higher total priority of the threads scheduled.
> > +        Similar analysis is done when a thread finishes its execution.
> Since you learn vim currently, maybe you can try to visually select this
> paragraph and then type "qa".
> > +     :cite:`Cerqueira:2014:LPA`
> Please use a sentence, for example "See also :cite:`Cerqueira:2014:LPA`".
> >       suspend
> >           A term used to describe a task that is not competing for the
> CPU because it
> >           has had a ``rtems_task_suspend`` directive.
> > @@ -905,6 +926,14 @@ Glossary
> >           Message queues, regions, and semaphores have a wait queue
> associated with
> >           them.
> > +    Weak APA
> > +        Weak APA is a specialization of :term:`APA`.
> > +        This refers to Linux's pull push implementation of APA model.
> push/pull or "push and pull"
> > +        A ready thread is scheduled when a processor in its affinity
> set is idle
> > +        or is executing a thread which is at a lower priority.
> Maybe mention that no threads are forced to migrate to find a processor.
> >       YAML
> >           This term is an acronym for `YAML Ain't Markup Language <
> https://yaml.org/>`_.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200619/8d37012f/attachment.html>
