[PATCH 10/10] mDNSResponder: Port to RTEMS
Sebastian Huber
Fri Jun 19 11:02:24 UTC 2020
Update #4010.
mDNSResponder/mDNSCore/anonymous.c | 15 ++++--
mDNSResponder/mDNSCore/mDNS.c | 4 ++
mDNSResponder/mDNSCore/mDNSEmbeddedAPI.h | 40 ++++++++++++++
mDNSResponder/mDNSPosix/mDNSPosix.c | 58 +++++++++++++++++++++
mDNSResponder/mDNSPosix/mDNSPosix.h | 6 +++
mDNSResponder/mDNSPosix/mDNSUNP.c | 2 +-
mDNSResponder/mDNSShared/dnssd_clientshim.c | 13 ++++-
mDNSResponder/mDNSShared/mDNSDebug.c | 4 ++
testsuite/foobarserver/test_main.c | 2 +-
9 files changed, 136 insertions(+), 8 deletions(-)
diff --git a/mDNSResponder/mDNSCore/anonymous.c b/mDNSResponder/mDNSCore/anonymous.c
index 5c138d23..fde3ed80 100644
--- a/mDNSResponder/mDNSCore/anonymous.c
+++ b/mDNSResponder/mDNSCore/anonymous.c
@@ -274,12 +274,17 @@ mDNSexport void SetAnonData(DNSQuestion *q, ResourceRecord *rr, mDNSBool ForQues
+mDNSlocal char *RRDisplayStringBuf(const ResourceRecord *const rr, char *const buffer)
+ return GetRRDisplayString_rdb(rr, &rr->rdata->u, buffer);
// returns -1 if the caller should ignore the result
// returns 1 if the record answers the question
// returns 0 if the record does not answer the question
mDNSexport int AnonInfoAnswersQuestion(const ResourceRecord *const rr, const DNSQuestion *const q)
- mDNSexport mDNS mDNSStorage;
+ char MsgBuffer[MaxMsg]; // Temp storage used while building error log messages
ResourceRecord *nsec3RR;
int i;
AnonymousInfo *qai, *rai;
@@ -363,7 +368,7 @@ mDNSexport int AnonInfoAnswersQuestion(const ResourceRecord *const rr, const DNS
mDNSPlatformMemCmp(qai->AnonData, rai->AnonData, qai->AnonDataLen) != 0)
debugf("AnonInfoAnswersQuestion: AnonData mis-match for record %s question %##s ",
- RRDisplayString(&mDNSStorage, rr), q->qname.c);
+ RRDisplayStringBuf(rr, MsgBuffer), q->qname.c);
return 0;
// AnonData matches i.e they belong to the same group and the same service.
@@ -401,10 +406,10 @@ mDNSexport int AnonInfoAnswersQuestion(const ResourceRecord *const rr, const DNS
// AnonData can be NULL for the cache entry and if we are hearing our own question back, AnonData is NULL for
// that too and we can end up here for that case.
debugf("AnonInfoAnswersQuestion: AnonData %p or nsec3RR %p, NULL for question %##s, record %s", AnonData, nsec3RR,
- q->qname.c, RRDisplayString(&mDNSStorage, rr));
+ q->qname.c, RRDisplayStringBuf(rr, MsgBuffer));
return 0;
- debugf("AnonInfoAnswersQuestion: Validating question %##s, ResourceRecord %s", q->qname.c, RRDisplayString(&mDNSStorage, nsec3RR));
+ debugf("AnonInfoAnswersQuestion: Validating question %##s, ResourceRecord %s", q->qname.c, RRDisplayStringBuf(nsec3RR, MsgBuffer));
nsec3 = (rdataNSEC3 *)nsec3RR->rdata->u.data;
@@ -436,7 +441,7 @@ mDNSexport int AnonInfoAnswersQuestion(const ResourceRecord *const rr, const DNS
return 0;
- LogInfo("AnonInfoAnswersQuestion: ResourceRecord %s matched question %##s (%s)", RRDisplayString(&mDNSStorage, nsec3RR), q->qname.c, DNSTypeName(q->qtype));
+ LogInfo("AnonInfoAnswersQuestion: ResourceRecord %s matched question %##s (%s)", RRDisplayStringBuf(nsec3RR, MsgBuffer), q->qname.c, DNSTypeName(q->qtype));
return 1;
diff --git a/mDNSResponder/mDNSCore/mDNS.c b/mDNSResponder/mDNSCore/mDNS.c
index 4e70ef83..4473e82a 100755
--- a/mDNSResponder/mDNSCore/mDNS.c
+++ b/mDNSResponder/mDNSCore/mDNS.c
@@ -14586,7 +14586,11 @@ mDNSlocal mStatus mDNS_InitStorage(mDNS *const m, mDNS_PlatformSupport *const p,
m->WABBrowseQueriesCount = 0;
m->WABLBrowseQueriesCount = 0;
m->WABRegQueriesCount = 0;
+#ifndef __rtems__
m->AutoTargetServices = 0;
+#else /* __rtems__ */
+ m->AutoTargetServices = 1;
+#endif /* __rtems__ */
#if BONJOUR_ON_DEMAND
m->NumAllInterfaceRecords = 0;
diff --git a/mDNSResponder/mDNSCore/mDNSEmbeddedAPI.h b/mDNSResponder/mDNSCore/mDNSEmbeddedAPI.h
index d714de49..ba5dfb3f 100755
--- a/mDNSResponder/mDNSCore/mDNSEmbeddedAPI.h
+++ b/mDNSResponder/mDNSCore/mDNSEmbeddedAPI.h
@@ -3665,6 +3665,46 @@ extern void D2D_stop_advertising_record(AuthRecord *ar);
+#ifdef __rtems__
+typedef struct
+ // Client API fields: The client must set up name and InterfaceID *before* calling mDNS_StartResolveService()
+ // When the callback is invoked, ip, port, TXTlen and TXTinfo will have been filled in with the results learned from the network.
+ domainname name;
+ mDNSInterfaceID InterfaceID; // ID of the interface the response was received on
+ mDNSAddr ip; // Remote (destination) IP address where this service can be accessed
+ mDNSIPPort port; // Port where this service can be accessed
+ mDNSu16 TXTlen;
+ mDNSu8 TXTinfo[2048]; // Additional demultiplexing information (e.g. LPR queue name)
+} ServiceInfo;
+// Note: Within an mDNSServiceInfoQueryCallback mDNS all API calls are legal except mDNS_Init(), mDNS_Exit(), mDNS_Execute()
+typedef struct ServiceInfoQuery_struct ServiceInfoQuery;
+typedef void mDNSServiceInfoQueryCallback (mDNS *const m, ServiceInfoQuery *query);
+struct ServiceInfoQuery_struct
+ // Internal state fields. These are used internally by mDNSCore; the client layer needn't be concerned with them.
+ // No fields need to be set up by the client prior to calling mDNS_StartResolveService();
+ // all required data is passed as parameters to that function.
+ // The ServiceInfoQuery structure memory is working storage for mDNSCore to discover the requested information
+ // and place it in the ServiceInfo structure. After the client has called mDNS_StopResolveService(), it may
+ // dispose of the ServiceInfoQuery structure while retaining the results in the ServiceInfo structure.
+ DNSQuestion qSRV;
+ DNSQuestion qTXT;
+ DNSQuestion qAv4;
+ DNSQuestion qAv6;
+ mDNSu8 GotSRV;
+ mDNSu8 GotTXT;
+ mDNSu8 GotADD;
+ mDNSu32 Answers;
+ ServiceInfo *info;
+ mDNSServiceInfoQueryCallback *ServiceInfoQueryCallback;
+ void *ServiceInfoQueryContext;
+extern mStatus mDNS_StartResolveService(mDNS *const m, ServiceInfoQuery *query, ServiceInfo *info, mDNSServiceInfoQueryCallback *Callback, void *Context);
+extern void mDNS_StopResolveService (mDNS *const m, ServiceInfoQuery *query);
#ifdef __cplusplus
#endif
diff --git a/mDNSResponder/mDNSPosix/mDNSPosix.c b/mDNSResponder/mDNSPosix/mDNSPosix.c
index 308252fb..9b4dbed8 100755
--- a/mDNSResponder/mDNSPosix/mDNSPosix.c
+++ b/mDNSResponder/mDNSPosix/mDNSPosix.c
@@ -40,6 +40,10 @@
#include <netinet/in.h>
#include <arpa/inet.h>
#include <time.h> // platform support for UTC time
+#ifdef __rtems__
+#include <sys/param.h>
+#include <rtems/libio_.h>
#if USES_NETLINK
#include <asm/types.h>
@@ -76,7 +80,12 @@ struct IfChangeRec
typedef struct IfChangeRec IfChangeRec;
// Note that static data is initialized to zero in (modern) C.
+#ifndef __rtems__
static fd_set gEventFDs;
+static fd_set *gAllocatedEventFDs;
+#define gEventFDs (*gAllocatedEventFDs)
static int gMaxFD; // largest fd in gEventFDs
static GenLinkedList gEventSources; // linked list of PosixEventSource's
static sigset_t gEventSignalSet; // Signals which event loop listens for
@@ -439,6 +448,15 @@ mDNSexport mDNSBool mDNSPlatformSetDNSConfig(mDNSBool setservers, mDNSBool setse
(void) RegDomains;
(void) BrowseDomains;
(void) ackConfig;
+#ifdef __rtems__
+ * Copied from mDNSMacOSX/mDNSMacOSX.c to prevent use of uninitialized
+ * stack variables.
+ if (fqdn ) fqdn->c[0] = 0;
+ if (RegDomains ) *RegDomains = NULL;
+ if (BrowseDomains) *BrowseDomains = NULL;
return mDNStrue;
@@ -657,6 +675,7 @@ mDNSlocal int SetupSocket(struct sockaddr *intfAddr, mDNSIPPort port, int interf
#endif
if (err < 0) { err = errno; perror("setsockopt - SO_REUSExxxx"); }
+#ifndef __rtems__
// Enable inbound packets on IFEF_AWDL interface.
// Only done for multicast sockets, since we don't expect unicast socket operations
// on the IFEF_AWDL interface. Operation is a no-op for other interface types.
@@ -664,6 +683,7 @@ mDNSlocal int SetupSocket(struct sockaddr *intfAddr, mDNSIPPort port, int interf
#define SO_RECV_ANYIF 0x1104 /* unrestricted inbound processing */
#endif
if (setsockopt(*sktPtr, SOL_SOCKET, SO_RECV_ANYIF, &kOn, sizeof(kOn)) < 0) perror("setsockopt - SO_RECV_ANYIF");
// We want to receive destination addresses and interface identifiers.
@@ -1208,14 +1228,23 @@ mDNSlocal mDNSu32 ProcessRoutingNotification(int sd)
mDNSlocal void InterfaceChangeCallback(int fd, short filter, void *context)
IfChangeRec *pChgRec = (IfChangeRec*) context;
+#ifndef __rtems__
fd_set readFDs;
+ fd_set bigEnoughReadFDs[howmany(rtems_libio_number_iops, sizeof(fd_set) * 8)];
+#define readFDs (*(&bigEnoughReadFDs[0]))
mDNSu32 changedInterfaces = 0;
struct timeval zeroTimeout = { 0, 0 };
(void)fd; // Unused
(void)filter; // Unused
+#ifndef __rtems__
FD_ZERO(&readFDs);
+ memset(bigEnoughReadFDs, 0, sizeof(bigEnoughReadFDs));
FD_SET(pChgRec->NotifySD, &readFDs);
do
@@ -1272,6 +1301,9 @@ mDNSexport mStatus mDNSPlatformInit(mDNS *const m)
int err = 0;
struct sockaddr sa;
+#ifdef __rtems__
+ pthread_mutexattr_t attr;
assert(m != NULL);
if (mDNSPlatformInit_CanReceiveUnicast()) m->CanReceiveUnicastOn5353 = mDNStrue;
@@ -1289,6 +1321,16 @@ mDNSexport mStatus mDNSPlatformInit(mDNS *const m)
if (m->hostlabel.c[0] == 0) MakeDomainLabelFromLiteralString(&m->hostlabel, "Computer");
mDNS_SetFQDN(m);
+#ifdef __rtems__
+ if (err == mStatus_NoError) {
+ gAllocatedEventFDs = calloc(howmany(rtems_libio_number_iops, sizeof(fd_set) * 8), sizeof(fd_set));
+ if (gAllocatedEventFDs == NULL) err = mStatus_NoMemoryErr;
+ if (err == mStatus_NoError) err = pthread_mutexattr_init(&attr);
+ if (err == mStatus_NoError) err = pthread_mutexattr_setprotocol(&attr, PTHREAD_PRIO_INHERIT);
+ if (err == mStatus_NoError) err = pthread_mutex_init(&m->p->mutex, &attr);
+ if (err == mStatus_NoError) err = pthread_mutexattr_destroy(&attr);
sa.sa_family = AF_INET;
m->p->unicastSocket4 = -1;
@@ -1373,14 +1415,22 @@ mDNSexport mStatus mDNSPlatformPosixRefreshInterfaceList(mDNS *const m)
// the platform from reentering mDNS core code.
mDNSexport void mDNSPlatformLock (const mDNS *const m)
+#ifndef __rtems__
(void) m; // Unused
+ pthread_mutex_lock(&m->p->mutex);
// mDNS core calls this routine when it release the lock taken by
// mDNSPlatformLock and allow the platform to reenter mDNS core code.
mDNSexport void mDNSPlatformUnlock (const mDNS *const m)
+#ifndef __rtems__
(void) m; // Unused
+ pthread_mutex_unlock(&m->p->mutex);
#if COMPILER_LIKES_PRAGMA_MARK
@@ -1755,8 +1805,10 @@ mStatus mDNSPosixAddFDToEventLoop(int fd, mDNSPosixEventCallback callback, void
if (gEventSources.LinkOffset == 0)
InitLinkedList(&gEventSources, offsetof(PosixEventSource, Next));
+#ifndef __rtems__
if (fd >= (int) FD_SETSIZE || fd < 0)
return mStatus_UnsupportedErr;
if (callback == NULL)
return mStatus_BadParamErr;
@@ -1836,7 +1888,13 @@ mStatus mDNSPosixIgnoreSignalInEventLoop(int signum)
mStatus mDNSPosixRunEventLoopOnce(mDNS *m, const struct timeval *pTimeout,
sigset_t *pSignalsReceived, mDNSBool *pDataDispatched)
+#ifndef __rtems__
fd_set listenFDs = gEventFDs;
+ fd_set bigEnoughListenFDs[howmany(rtems_libio_number_iops, sizeof(fd_set) * 8)];
+#define listenFDs (*(&bigEnoughListenFDs[0]))
+ memcpy(bigEnoughListenFDs, gAllocatedEventFDs, sizeof(bigEnoughListenFDs));
int fdMax = 0, numReady;
struct timeval timeout = *pTimeout;
diff --git a/mDNSResponder/mDNSPosix/mDNSPosix.h b/mDNSResponder/mDNSPosix/mDNSPosix.h
index ca60d806..acff9c33 100755
--- a/mDNSResponder/mDNSPosix/mDNSPosix.h
+++ b/mDNSResponder/mDNSPosix/mDNSPosix.h
@@ -20,6 +20,9 @@
#include <signal.h>
#include <sys/time.h>
+#ifdef __rtems__
+#include <pthread.h>
#ifdef __cplusplus
extern "C" {
@@ -55,6 +58,9 @@ struct mDNS_PlatformSupport_struct
#if HAVE_IPV6
int unicastSocket6;
#endif
+#ifdef __rtems__
+ pthread_mutex_t mutex;
#define uDNS_SERVERS_FILE "/etc/resolv.conf"
diff --git a/mDNSResponder/mDNSPosix/mDNSUNP.c b/mDNSResponder/mDNSPosix/mDNSUNP.c
index e00ddd62..148a3594 100755
--- a/mDNSResponder/mDNSPosix/mDNSUNP.c
+++ b/mDNSResponder/mDNSPosix/mDNSUNP.c
@@ -256,7 +256,7 @@ struct ifi_info *get_ifi_info(int family, int doaliases)
lastlen = 0;
len = 100 * sizeof(struct ifreq); /* initial buffer size guess */
for ( ; ; ) {
- buf = (char*)malloc(len);
+ buf = (char*)calloc(1, len);
if (buf == NULL) {
goto gotError;
diff --git a/mDNSResponder/mDNSShared/dnssd_clientshim.c b/mDNSResponder/mDNSShared/dnssd_clientshim.c
index c0a309d5..04806f8a 100644
--- a/mDNSResponder/mDNSShared/dnssd_clientshim.c
+++ b/mDNSResponder/mDNSShared/dnssd_clientshim.c
@@ -25,6 +25,8 @@
#include "dns_sd.h" // Defines the interface to the client layer above
#include "mDNSEmbeddedAPI.h" // The interface we're building on top of
+#include <sys/socket.h>
+#include <netinet/in.h>
extern mDNS mDNSStorage; // We need to pass the address of this storage to the lower-layer functions
#if MDNS_BUILDINGSHAREDLIBRARY || MDNS_BUILDINGSTUBLIBRARY
@@ -68,6 +70,14 @@ typedef struct
DNSQuestion q;
} mDNS_DirectOP_Browse;
+typedef struct
+ mDNS_DirectOP_Dispose *disposefn;
+ DNSServiceRef aQuery;
+ DNSServiceGetAddrInfoReply callback;
+ void *context;
+} mDNS_DirectOP_GetAddrInfo;
typedef struct
@@ -261,6 +271,7 @@ DNSServiceErrorType DNSServiceRegister
err = mDNS_RegisterService(&mDNSStorage, &x->s,
&x->name, &t, &d, // Name, type, domain
&x->host, port, // Host and port
+ mDNSNULL,
txtRecord, txtLen, // TXT data, length
SubTypes, NumSubTypes, // Subtypes
mDNSInterface_Any, // Interface ID
@@ -674,7 +685,7 @@ DNSServiceErrorType DNSServiceQueryRecord
x->q.ExpectUnique = mDNSfalse;
x->q.ForceMCast = (flags & kDNSServiceFlagsForceMulticast) != 0;
x->q.ReturnIntermed = (flags & kDNSServiceFlagsReturnIntermediates) != 0;
- x->q.SuppressUnsable = (flags & kDNSServiceFlagsSuppressUnusable) != 0;
+ x->q.SuppressUnusable = (flags & kDNSServiceFlagsSuppressUnusable) != 0;
x->q.SearchListIndex = 0;
x->q.AppendSearchDomains = 0;
x->q.RetryWithSearchDomains = mDNSfalse;
diff --git a/mDNSResponder/mDNSShared/mDNSDebug.c b/mDNSResponder/mDNSShared/mDNSDebug.c
index dfe77a1d..aa6e662a 100644
--- a/mDNSResponder/mDNSShared/mDNSDebug.c
+++ b/mDNSResponder/mDNSShared/mDNSDebug.c
@@ -60,7 +60,11 @@ mDNSlocal void LogMsgWithLevelv(mDNSLogLevel_t logLevel, const char *format, va_
char buffer[512];
buffer[mDNS_vsnprintf((char *)buffer, sizeof(buffer), format, ptr)] = 0;
+#ifndef __rtems__
mDNSPlatformWriteLogMsg(ProgramName, buffer, logLevel);
+ mDNSPlatformWriteLogMsg(NULL, buffer, logLevel);
#define LOG_HELPER_BODY(L) \
diff --git a/testsuite/foobarserver/test_main.c b/testsuite/foobarserver/test_main.c
index 84c40c4d..be841bd4 100644
--- a/testsuite/foobarserver/test_main.c
+++ b/testsuite/foobarserver/test_main.c
@@ -110,7 +110,7 @@ foobar_register(mDNSu16 port)
MakeDomainNameFromDNSNameString(&domain, "local.");
status = mDNS_RegisterService(&mDNSStorage, srs, &name, &type, &domain,
- NULL, mDNSOpaque16fromIntVal(port), NULL, 0, NULL, 0,
+ NULL, mDNSOpaque16fromIntVal(port), NULL, NULL, 0, NULL, 0,
mDNSInterface_Any, foobar_callback, srs, 0);
assert(status == mStatus_NoError);
2.26.2
