[PATCH 08/10] mDNSResponder: Update to v878.260.1
Sebastian Huber
Fri Jun 19 11:02:22 UTC 2020
The sources can be obtained via:
https://opensource.apple.com/tarballs/mDNSResponder/mDNSResponder-878.260.1.tar.gz
Update #4010.
mDNSResponder/Makefile | 2 +-
mDNSResponder/mDNSCore/mDNS.c | 19 +-
mDNSResponder/mDNSCore/mDNSEmbeddedAPI.h | 2 +-
mDNSResponder/mDNSMacOSX/mDNSMacOSX.c | 336 +++++++++++------------
mDNSResponder/mDNSMacOSX/mDNSMacOSX.h | 2 -
mDNSResponder/mDNSShared/dns_sd.h | 2 +-
6 files changed, 176 insertions(+), 187 deletions(-)
diff --git a/mDNSResponder/Makefile b/mDNSResponder/Makefile
index 9aaa08eb..b647c70a 100644
--- a/mDNSResponder/Makefile
+++ b/mDNSResponder/Makefile
@@ -17,7 +17,7 @@
include $(MAKEFILEPATH)/pb_makefiles/platform.make
-MVERS = "mDNSResponder-878.250.4"
+MVERS = "mDNSResponder-878.260.1"
VER =
ifneq ($(strip $(GCC_VERSION)),)
diff --git a/mDNSResponder/mDNSCore/mDNS.c b/mDNSResponder/mDNSCore/mDNS.c
index 9e1ac506..bf1bce2f 100755
--- a/mDNSResponder/mDNSCore/mDNS.c
+++ b/mDNSResponder/mDNSCore/mDNS.c
@@ -6092,7 +6092,7 @@ mDNSexport mStatus UpdateKeepaliveRData(mDNS *const m, AuthRecord *rr, NetworkIn
if ((intf != mDNSNULL) && (mti.IntfId != intf->InterfaceID))
- LogInfo("mDNSPlatformRetrieveTCPInfo: InterfaceID mismatch mti.IntfId = %p InterfaceID = %p", mti.IntfId, intf->InterfaceID);
+ LogInfo("mDNSPlatformRetrieveTCPInfo: InterfaceID mismatch mti.IntfId = %p InterfaceID = %p", mti.IntfId, intf->InterfaceID);
return mStatus_BadParamErr;
@@ -6661,6 +6661,7 @@ mDNSlocal void BeginSleepProcessing(mDNS *const m)
NetworkInterfaceInfo *intf;
for (intf = GetFirstActiveInterface(m->HostInterfaces); intf; intf = GetFirstActiveInterface(intf->next))
+ mDNSBool skipFullSleepProxyRegistration = mDNSfalse;
// Intialize it to false. These values make sense only when SleepState is set to Sleeping.
intf->SendGoodbyes = 0;
@@ -6687,18 +6688,21 @@ mDNSlocal void BeginSleepProcessing(mDNS *const m)
continue;
- // Check if we have already registered with a sleep proxy for this subnet
+ // Check if we have already registered with a sleep proxy for this subnet.
+ // If so, then the subsequent in-NIC sleep proxy registration is limited to any keepalive records that belong
+ // to the interface.
if (skipSameSubnetRegistration(m, registeredIntfIDS, registeredCount, intf->InterfaceID))
- LogSPS("%s : Skipping sleep proxy registration on %s", __func__, intf->ifname);
- continue;
+ LogSPS("%s : Skipping full sleep proxy registration on %s", __func__, intf->ifname);
+ skipFullSleepProxyRegistration = mDNStrue;
#if APPLE_OSX_mDNSResponder
- else if (SupportsInNICProxy(intf))
+ if (SupportsInNICProxy(intf))
mDNSBool keepaliveOnly = mDNSfalse;
- if (ActivateLocalProxy(intf, &keepaliveOnly) == mStatus_NoError)
+ const mStatus err = ActivateLocalProxy(intf, skipFullSleepProxyRegistration, &keepaliveOnly);
+ if (!skipFullSleepProxyRegistration && !err)
SendGoodbyesForWakeOnlyService(m, &WakeOnlyService);
@@ -6716,9 +6720,10 @@ mDNSlocal void BeginSleepProcessing(mDNS *const m)
registeredIntfIDS[registeredCount] = intf->InterfaceID;
registeredCount++;
+ continue;
#endif // APPLE_OSX_mDNSResponder
- else
+ if (!skipFullSleepProxyRegistration)
// If on battery, do not attempt to offload to external sleep proxies
diff --git a/mDNSResponder/mDNSCore/mDNSEmbeddedAPI.h b/mDNSResponder/mDNSCore/mDNSEmbeddedAPI.h
index 26c70089..e9f3bb8a 100755
--- a/mDNSResponder/mDNSCore/mDNSEmbeddedAPI.h
+++ b/mDNSResponder/mDNSCore/mDNSEmbeddedAPI.h
@@ -3390,7 +3390,7 @@ extern void RemoveAutoTunnel6Record(mDNS *const m);
extern mDNSBool RecordReadyForSleep(AuthRecord *rr);
// For now this LocalSleepProxy stuff is specific to Mac OS X.
// In the future, if there's demand, we may see if we can abstract it out cleanly into the platform layer
-extern mStatus ActivateLocalProxy(NetworkInterfaceInfo *const intf, mDNSBool *keepaliveOnly);
+extern mStatus ActivateLocalProxy(NetworkInterfaceInfo *const intf, mDNSBool offloadKeepAlivesOnly, mDNSBool *keepaliveOnly);
extern void mDNSPlatformUpdateDNSStatus(DNSQuestion *q);
extern void mDNSPlatformTriggerDNSRetry(DNSQuestion *v4q, DNSQuestion *v6q);
extern void mDNSPlatformLogToFile(int log_level, const char *buffer);
diff --git a/mDNSResponder/mDNSMacOSX/mDNSMacOSX.c b/mDNSResponder/mDNSMacOSX/mDNSMacOSX.c
index 47142935..b7e53032 100644
--- a/mDNSResponder/mDNSMacOSX/mDNSMacOSX.c
+++ b/mDNSResponder/mDNSMacOSX/mDNSMacOSX.c
@@ -825,7 +825,7 @@ mDNSexport mStatus mDNSPlatformSendUDP(const mDNS *const m, const void *const ms
return(result);
-mDNSexport ssize_t myrecvfrom(const int s, void *const buffer, const size_t max,
+mDNSlocal ssize_t myrecvfrom(const int s, void *const buffer, const size_t max,
struct sockaddr *const from, size_t *const fromlen, mDNSAddr *dstaddr, char ifname[IF_NAMESIZE], mDNSu8 *ttl)
static unsigned int numLogMessages = 0;
@@ -853,20 +853,22 @@ mDNSexport ssize_t myrecvfrom(const int s, void *const buffer, const size_t max,
if (errno != EWOULDBLOCK && numLogMessages++ < 100) LogMsg("mDNSMacOSX.c: recvmsg(%d) returned error %d errno %d", s, n, errno);
return(-1);
- if (msg.msg_controllen < (int)sizeof(struct cmsghdr))
- if (numLogMessages++ < 100) LogMsg("mDNSMacOSX.c: recvmsg(%d) returned %d msg.msg_controllen %d < sizeof(struct cmsghdr) %lu, errno %d",
- s, n, msg.msg_controllen, sizeof(struct cmsghdr), errno);
- return(-1);
if (msg.msg_flags & MSG_CTRUNC)
if (numLogMessages++ < 100) LogMsg("mDNSMacOSX.c: recvmsg(%d) msg.msg_flags & MSG_CTRUNC", s);
return(-1);
*fromlen = msg.msg_namelen;
+ if (msg.msg_controllen < (int)sizeof(struct cmsghdr))
+ if (numLogMessages++ < 100)
+ LogMsg("mDNSMacOSX.c: recvmsg(%d) returned %ld msg.msg_controllen %lu < sizeof(struct cmsghdr) %lu",
+ s, (long)n, (unsigned long)msg.msg_controllen, (unsigned long)sizeof(struct cmsghdr));
+ goto exit;
// Parse each option out of the ancillary data.
for (cmPtr = CMSG_FIRSTHDR(&msg); cmPtr; cmPtr = CMSG_NXTHDR(&msg, cmPtr))
@@ -900,6 +902,7 @@ mDNSexport ssize_t myrecvfrom(const int s, void *const buffer, const size_t max,
*ttl = *(int*)CMSG_DATA(cmPtr);
+exit:
return(n);
@@ -2452,7 +2455,7 @@ mDNSlocal int GetRemoteMacinternal(int family, v6addr_t raddr, ethaddr_t eth)
ret = getMACAddress(family, raddr, gateway, &gfamily, eth);
if (ret == -1)
- memcpy(raddr, gateway, sizeof(family));
+ memcpy(raddr, gateway, (gfamily == AF_INET) ? 4 : 16);
family = gfamily;
count++;
@@ -3183,6 +3186,42 @@ mDNSlocal int GetMAC(mDNSEthAddr *eth, u_short ifindex)
#define ifr_wake_flags ifr_ifru.ifru_intval
#endif
+mDNSlocal
+kern_return_t
+RegistryEntrySearchCFPropertyAndIOObject( io_registry_entry_t entry,
+ const io_name_t plane,
+ CFStringRef keystr,
+ CFTypeRef * outProperty,
+ io_registry_entry_t * outEntry)
+ kern_return_t kr;
+ IOObjectRetain(entry);
+ while (entry)
+ CFTypeRef ref = IORegistryEntryCreateCFProperty(entry, keystr, kCFAllocatorDefault, mDNSNULL);
+ if (ref)
+ if (outProperty) *outProperty = ref;
+ else CFRelease(ref);
+ break;
+ io_registry_entry_t parent;
+ kr = IORegistryEntryGetParentEntry(entry, plane, &parent);
+ if (kr != KERN_SUCCESS) parent = mDNSNULL;
+ IOObjectRelease(entry);
+ entry = parent;
+ if (!entry) kr = kIOReturnNoDevice;
+ else
+ if (outEntry) *outEntry = entry;
+ else IOObjectRelease(entry);
+ kr = KERN_SUCCESS;
+ return(kr);
mDNSlocal mDNSBool CheckInterfaceSupport(NetworkInterfaceInfo *const intf, const char *key)
io_service_t service = IOServiceGetMatchingService(kIOMasterPortDefault, IOBSDNameMatching(kIOMasterPortDefault, 0, intf->ifname));
@@ -3192,42 +3231,17 @@ mDNSlocal mDNSBool CheckInterfaceSupport(NetworkInterfaceInfo *const intf, cons
return mDNSfalse;
- io_name_t n1, n2;
- IOObjectGetClass(service, n1);
- io_object_t parent = IO_OBJECT_NULL;
mDNSBool ret = mDNSfalse;
- kern_return_t kr = IORegistryEntryGetParentEntry(service, kIOServicePlane, &parent);
- if (kr == KERN_SUCCESS)
- CFStringRef keystr = CFStringCreateWithCString(NULL, key, kCFStringEncodingUTF8);
- IOObjectGetClass(parent, n2);
- LogSPS("CheckInterfaceSupport: Interface %s service %s parent %s", intf->ifname, n1, n2);
- CFTypeRef ref = mDNSNULL;
- // Currently, the key can be in a different part of the IOKit hierarchy on the AppleTV.
- // TODO: revist if it is ok to have the same call for all platforms.
- if (IsAppleTV())
- ref = IORegistryEntrySearchCFProperty(parent, kIOServicePlane, keystr, kCFAllocatorDefault, kIORegistryIterateParents | kIORegistryIterateRecursively);
- else
- ref = IORegistryEntryCreateCFProperty(parent, keystr, kCFAllocatorDefault, mDNSNULL);
- if (!ref)
- LogSPS("CheckInterfaceSupport: No %s for interface %s/%s/%s", key, intf->ifname, n1, n2);
- ret = mDNSfalse;
- else
- ret = mDNStrue;
- CFRelease(ref);
- IOObjectRelease(parent);
- CFRelease(keystr);
+ CFStringRef keystr = CFStringCreateWithCString(NULL, key, kCFStringEncodingUTF8);
+ kern_return_t kr = RegistryEntrySearchCFPropertyAndIOObject(service, kIOServicePlane, keystr, mDNSNULL, mDNSNULL);
+ CFRelease(keystr);
+ if (kr == KERN_SUCCESS) ret = mDNStrue;
else
- LogSPS("CheckInterfaceSupport: IORegistryEntryGetParentEntry for %s/%s failed %d", intf->ifname, n1, kr);
+ io_name_t n1;
+ IOObjectGetClass(service, n1);
+ LogSPS("CheckInterfaceSupport: No %s for interface %s/%s kr %d", key, intf->ifname, n1, kr);
ret = mDNSfalse;
@@ -6875,30 +6889,22 @@ typedef struct
#include <IOKit/IOKitLib.h>
#include <dns_util.h>
-mDNSlocal mDNSu16 GetPortArray(int trans, mDNSIPPort *portarray, mDNSBool TCPKAOnly, mDNSBool supportsTCPKA)
+mDNSlocal mDNSu32 GetPortArray(int trans, mDNSIPPort *portarray)
mDNS *const m = &mDNSStorage;
const domainlabel *const tp = (trans == mDNSTransport_UDP) ? (const domainlabel *)"\x4_udp" : (const domainlabel *)"\x4_tcp";
- int count = 0;
+ mDNSu32 count = 0;
AuthRecord *rr;
for (rr = m->ResourceRecords; rr; rr=rr->next)
- mDNSBool isKeepAliveRecord = mDNS_KeepaliveRecord(&rr->resrec);
- // Skip over all other records if we are registering TCP KeepAlive records only
- // Skip over TCP KeepAlive records if the policy prohibits it or if the interface does not support TCP Keepalive
- // supportsTCPKA is set to true if both policy and interface allow TCP Keepalive
- if ((TCPKAOnly && !isKeepAliveRecord) || (isKeepAliveRecord && !supportsTCPKA)) {
- continue;
if (rr->resrec.rrtype == kDNSType_SRV && SameDomainLabel(ThirdLabel(rr->resrec.name)->c, tp->c))
if (!portarray)
count++;
else
- int i;
+ mDNSu32 i;
for (i = 0; i < count; i++)
if (mDNSSameIPPort(portarray[i], rr->resrec.rdata->u.srv.port))
break;
@@ -6913,7 +6919,7 @@ mDNSlocal mDNSu16 GetPortArray(int trans, mDNSIPPort *portarray, mDNSBool TCPKAO
// If Back to My Mac is on, also wake for packets to the IPSEC UDP port (4500)
if (trans == mDNSTransport_UDP && m->AutoTunnelNAT.clientContext)
- LogSPS("GetPortArray Back to My Mac at %d", count);
+ LogSPS("GetPortArray Back to My Mac at %u", count);
if (portarray) portarray[count] = IPSECPort;
count++;
@@ -6957,11 +6963,12 @@ mDNSlocal mDNSBool OnBattery(void)
#define TfrRecordToNIC(RR) \
((!(RR)->resrec.InterfaceID && ((RR)->ForceMCast || IsLocalDomain((RR)->resrec.name))))
-mDNSlocal mDNSu32 CountProxyRecords(uint32_t *const numbytes, NetworkInterfaceInfo *const intf, mDNSBool TCPKAOnly, mDNSBool supportsTCPKA)
+mDNSlocal mDNSu32 CountProxyRecords(uint32_t *const numbytes, mDNSBool TCPKAOnly, mDNSBool supportsTCPKA)
*numbytes = 0;
- int count = 0;
+ uint32_t count = 0;
+ mDNSBool isKeepAliveRecord = mDNSfalse;
AuthRecord *rr;
@@ -6970,31 +6977,22 @@ mDNSlocal mDNSu32 CountProxyRecords(uint32_t *const numbytes, NetworkInterfaceIn
if (!(rr->AuthFlags & AuthFlagsWakeOnly) && rr->resrec.RecordType > kDNSRecordTypeDeregistering)
#if APPLE_OSX_mDNSResponder && !TARGET_OS_EMBEDDED
+ isKeepAliveRecord = mDNS_KeepaliveRecord(&rr->resrec);
// Skip over TCP KeepAlive records if the policy prohibits it or if the interface does not support TCP Keepalive.
continue;
- // Update the record before calculating the number of bytes required
- // We offload the TCP Keepalive record even if the update fails. When the driver gets the record, it will
- // attempt to update the record again.
- if (isKeepAliveRecord && (UpdateKeepaliveRData(m, rr, intf, mDNSfalse, mDNSNULL) != mStatus_NoError))
- LogSPS("CountProxyRecords: Failed to update keepalive record - %s", ARDisplayString(m, rr));
- // Offload only Valid Keepalive records
- if (isKeepAliveRecord && !mDNSValidKeepAliveRecord(rr))
- continue;
#else
(void) TCPKAOnly; // unused
(void) supportsTCPKA; // unused
- (void) intf; // unused
-#endif // APPLE_OSX_mDNSResponder
+#endif
if (TfrRecordToNIC(rr))
- *numbytes += DomainNameLength(rr->resrec.name) + 10 + rr->resrec.rdestimate;
- LogSPS("CountProxyRecords: %3d size %5d total %5d %s",
- count, DomainNameLength(rr->resrec.name) + 10 + rr->resrec.rdestimate, *numbytes, ARDisplayString(m,rr));
+ // For KeepAlive records, use an estimated length of 256, which is the maximum size.
+ const uint32_t rdataLen = isKeepAliveRecord ? ((uint32_t)sizeof(UTF8str255)) : rr->resrec.rdestimate;
+ const uint32_t recordSize = DomainNameLength(rr->resrec.name) + 10 + rdataLen;
+ *numbytes += recordSize;
+ LogSPS("CountProxyRecords: %3u size %5u total %5u %s", count, recordSize, *numbytes, ARDisplayString(m,rr));
count++;
@@ -7002,14 +7000,15 @@ mDNSlocal mDNSu32 CountProxyRecords(uint32_t *const numbytes, NetworkInterfaceIn
return(count);
-mDNSlocal void GetProxyRecords(DNSMessage *const msg, uint32_t *const numbytes, FatPtr *const records, mDNSBool TCPKAOnly, mDNSBool supportsTCPKA)
+mDNSlocal void GetProxyRecords(DNSMessage *const msg, uint32_t *const numbytes, FatPtr *const records,
+ uint32_t *outRecordCount, NetworkInterfaceInfo *const intf, mDNSBool TCPKAOnly, mDNSBool supportsTCPKA)
mDNSu8 *p = msg->data;
const mDNSu8 *const limit = p + *numbytes;
InitializeDNSMessage(&msg->h, zeroID, zeroID);
- int count = 0;
AuthRecord *rr;
@@ -7017,18 +7016,31 @@ mDNSlocal void GetProxyRecords(DNSMessage *const msg, uint32_t *const numbytes,
+ const mDNSBool isKeepAliveRecord = mDNS_KeepaliveRecord(&rr->resrec);
continue;
- continue;
+ // Update the record before calculating the number of bytes required
+ // We offload the TCP Keepalive record even if the update fails. When the driver gets the record, it will
+ // attempt to update the record again.
+ if (isKeepAliveRecord)
+ if (UpdateKeepaliveRData(m, rr, intf, mDNSfalse, mDNSNULL) != mStatus_NoError)
+ LogSPS("GetProxyRecords: Failed to update keepalive record - %s", ARDisplayString(m, rr));
+ continue;
+ // Offload only Valid Keepalive records
+ if (!mDNSValidKeepAliveRecord(rr))
+ continue;
#else
+ (void) intf; // unused
@@ -7048,6 +7060,7 @@ mDNSlocal void GetProxyRecords(DNSMessage *const msg, uint32_t *const numbytes,
*numbytes = p - msg->data;
+ if (outRecordCount) *outRecordCount = count;
mDNSexport mDNSBool SupportsInNICProxy(NetworkInterfaceInfo *const intf)
@@ -7060,128 +7073,101 @@ mDNSexport mDNSBool SupportsInNICProxy(NetworkInterfaceInfo *const intf)
return CheckInterfaceSupport(intf, mDNS_IOREG_KEY);
-mDNSexport mStatus ActivateLocalProxy(NetworkInterfaceInfo *const intf, mDNSBool *keepaliveOnly) // Called with the lock held
+// Called with the lock held
+mDNSexport mStatus ActivateLocalProxy(NetworkInterfaceInfo *const intf, mDNSBool offloadKeepAlivesOnly, mDNSBool *keepaliveOnly)
mStatus result = mStatus_UnknownErr;
mDNSBool TCPKAOnly = mDNSfalse;
mDNSBool supportsTCPKA = mDNSfalse;
- mDNSBool onbattery = mDNSfalse;
- onbattery = OnBattery();
// Check if the interface supports TCP Keepalives and the system policy says it is ok to offload TCP Keepalive records
- supportsTCPKA = (InterfaceSupportsKeepAlive(intf) && SupportsTCPKeepAlive());
- // Only TCP Keepalive records are to be offloaded if
- // - The system is on battery
- // - OR wake for network access is not set but powernap is enabled
- TCPKAOnly = supportsTCPKA && ((mDNSStorage.SystemWakeOnLANEnabled == mDNS_WakeOnBattery) || onbattery);
+ supportsTCPKA = (InterfaceSupportsKeepAlive(intf) && SupportsTCPKeepAlive()) ? mDNStrue : mDNSfalse;
+ if (!offloadKeepAlivesOnly)
+ // Only TCP Keepalive records are to be offloaded if
+ // - The system is on battery
+ // - OR wake for network access is not set but powernap is enabled
+ TCPKAOnly = supportsTCPKA && ((mDNSStorage.SystemWakeOnLANEnabled == mDNS_WakeOnBattery) || OnBattery());
+ else
+ TCPKAOnly = mDNStrue;
#else
- (void) onbattery; // unused;
+ (void)offloadKeepAlivesOnly; // Unused.
#endif
if (!service) { LogMsg("ActivateLocalProxy: No service for interface %s", intf->ifname); return(mStatus_UnknownErr); }
- io_name_t n1, n2;
+ io_name_t n1, n2;
- if (kr != KERN_SUCCESS) LogMsg("ActivateLocalProxy: IORegistryEntryGetParentEntry for %s/%s failed %d", intf->ifname, n1, kr);
+ CFTypeRef ref;
+ io_object_t parent;
+ kern_return_t kr = RegistryEntrySearchCFPropertyAndIOObject(service, kIOServicePlane, CFSTR(mDNS_IOREG_KEY), &ref, &parent);
+ IOObjectRelease(service);
+ if (kr != KERN_SUCCESS) LogSPS("ActivateLocalProxy: No mDNS_IOREG_KEY for interface %s/%s kr %d", intf->ifname, n1, kr);
else
- if (IsAppleTV())
- while (service)
- ref = IORegistryEntryCreateCFProperty(parent, CFSTR(mDNS_IOREG_KEY), kCFAllocatorDefault, mDNSNULL);
- if (!ref)
- IOObjectRelease(service);
- service = parent;
- kr = IORegistryEntryGetParentEntry(service, kIOServicePlane, &parent);
- LogMsg("ActivateLocalProxy: IORegistryEntryGetParentEntry for %s/%s failed %d", intf->ifname, n1, kr);
- parent = IO_OBJECT_NULL;
- result = mStatus_BadStateErr;
- break;
- else
- LogSPS("ActivateLocalProxy: Found %s Interface %s parent %s", mDNS_IOREG_KEY, intf->ifname, n2);
- break;
- else
- LogSPS("ActivateLocalProxy: Interface %s service %s parent %s", intf->ifname, n1, n2);
+ IOObjectGetClass(parent, n2);
+ LogSPS("ActivateLocalProxy: Interface %s service %s parent %s", intf->ifname, n1, n2);
- if (!ref || parent == IO_OBJECT_NULL) LogSPS("ActivateLocalProxy: No mDNS_IOREG_KEY for interface %s/%s/%s", intf->ifname, n1, n2);
+ if (CFGetTypeID(ref) != CFStringGetTypeID() || !CFEqual(ref, CFSTR(mDNS_IOREG_VALUE)))
+ LogMsg("ActivateLocalProxy: mDNS_IOREG_KEY for interface %s/%s/%s value %s != %s",
+ intf->ifname, n1, n2, CFStringGetCStringPtr(ref, mDNSNULL), mDNS_IOREG_VALUE);
+ else if (!UseInternalSleepProxy)
+ LogSPS("ActivateLocalProxy: Not using internal (NIC) sleep proxy for interface %s", intf->ifname);
else
- if (CFGetTypeID(ref) != CFStringGetTypeID() || !CFEqual(ref, CFSTR(mDNS_IOREG_VALUE)))
- LogMsg("ActivateLocalProxy: mDNS_IOREG_KEY for interface %s/%s/%s value %s != %s",
- intf->ifname, n1, n2, CFStringGetCStringPtr(ref, mDNSNULL), mDNS_IOREG_VALUE);
- else if (!UseInternalSleepProxy)
- LogSPS("ActivateLocalProxy: Not using internal (NIC) sleep proxy for interface %s", intf->ifname);
+ io_connect_t conObj;
+ kr = IOServiceOpen(parent, mach_task_self(), mDNS_USER_CLIENT_CREATE_TYPE, &conObj);
+ if (kr != KERN_SUCCESS) LogMsg("ActivateLocalProxy: IOServiceOpen for %s/%s/%s failed %d", intf->ifname, n1, n2, kr);
else
- io_connect_t conObj;
- kr = IOServiceOpen(parent, mach_task_self(), mDNS_USER_CLIENT_CREATE_TYPE, &conObj);
- if (kr != KERN_SUCCESS) LogMsg("ActivateLocalProxy: IOServiceOpen for %s/%s/%s failed %d", intf->ifname, n1, n2, kr);
- else
+ mDNSOffloadCmd cmd;
+ mDNSPlatformMemZero(&cmd, sizeof(cmd)); // When compiling 32-bit, make sure top 32 bits of 64-bit pointers get initialized to zero
+ cmd.command = cmd_mDNSOffloadRR;
+ cmd.numUDPPorts = TCPKAOnly ? 0 : GetPortArray(mDNSTransport_UDP, mDNSNULL);
+ cmd.numTCPPorts = TCPKAOnly ? 0 : GetPortArray(mDNSTransport_TCP, mDNSNULL);
+ cmd.numRRRecords = CountProxyRecords(&cmd.rrBufferSize, TCPKAOnly, supportsTCPKA);
+ cmd.compression = sizeof(DNSMessageHeader);
+ DNSMessage *msg = (DNSMessage *)mallocL("mDNSOffloadCmd msg", sizeof(DNSMessageHeader) + cmd.rrBufferSize);
+ cmd.rrRecords.ptr = cmd.numRRRecords ? mallocL("mDNSOffloadCmd rrRecords", cmd.numRRRecords * sizeof(FatPtr)) : NULL;
+ cmd.udpPorts.ptr = cmd.numUDPPorts ? mallocL("mDNSOffloadCmd udpPorts" , cmd.numUDPPorts * sizeof(mDNSIPPort)) : NULL;
+ cmd.tcpPorts.ptr = cmd.numTCPPorts ? mallocL("mDNSOffloadCmd tcpPorts" , cmd.numTCPPorts * sizeof(mDNSIPPort)) : NULL;
+ LogSPS("ActivateLocalProxy: msg %p %u RR %p %u, UDP %p %u, TCP %p %u",
+ msg, cmd.rrBufferSize,
+ cmd.rrRecords.ptr, cmd.numRRRecords,
+ cmd.udpPorts.ptr, cmd.numUDPPorts,
+ cmd.tcpPorts.ptr, cmd.numTCPPorts);
+ if (msg && cmd.rrRecords.ptr)
- mDNSOffloadCmd cmd;
- mDNSPlatformMemZero(&cmd, sizeof(cmd)); // When compiling 32-bit, make sure top 32 bits of 64-bit pointers get initialized to zero
- cmd.command = cmd_mDNSOffloadRR;
- cmd.numUDPPorts = GetPortArray(mDNSTransport_UDP, mDNSNULL, TCPKAOnly, supportsTCPKA);
- cmd.numTCPPorts = GetPortArray(mDNSTransport_TCP, mDNSNULL, TCPKAOnly, supportsTCPKA);
- cmd.numRRRecords = CountProxyRecords(&cmd.rrBufferSize, intf, TCPKAOnly, supportsTCPKA);
- cmd.compression = sizeof(DNSMessageHeader);
- DNSMessage *msg = (DNSMessage *)mallocL("mDNSOffloadCmd msg", sizeof(DNSMessageHeader) + cmd.rrBufferSize);
- cmd.rrRecords.ptr = cmd.numRRRecords ? mallocL("mDNSOffloadCmd rrRecords", cmd.numRRRecords * sizeof(FatPtr)) : NULL;
- cmd.udpPorts.ptr = cmd.numUDPPorts ? mallocL("mDNSOffloadCmd udpPorts" , cmd.numUDPPorts * sizeof(mDNSIPPort)) : NULL;
- cmd.tcpPorts.ptr = cmd.numTCPPorts ? mallocL("mDNSOffloadCmd tcpPorts" , cmd.numTCPPorts * sizeof(mDNSIPPort)) : NULL;
- LogSPS("ActivateLocalProxy: msg %p %d RR %p %d, UDP %p %d, TCP %p %d",
- msg, cmd.rrBufferSize,
- cmd.rrRecords.ptr, cmd.numRRRecords,
- cmd.udpPorts.ptr, cmd.numUDPPorts,
- cmd.tcpPorts.ptr, cmd.numTCPPorts);
- if (msg && cmd.rrRecords.ptr) GetProxyRecords(msg, &cmd.rrBufferSize, cmd.rrRecords.ptr, TCPKAOnly, supportsTCPKA);
- if (cmd.udpPorts.ptr) cmd.numUDPPorts = GetPortArray(mDNSTransport_UDP, cmd.udpPorts.ptr, TCPKAOnly, supportsTCPKA);
- if (cmd.tcpPorts.ptr) cmd.numTCPPorts = GetPortArray(mDNSTransport_TCP, cmd.tcpPorts.ptr, TCPKAOnly, supportsTCPKA);
- char outputData[2];
- size_t outputDataSize = sizeof(outputData);
- kr = IOConnectCallStructMethod(conObj, 0, &cmd, sizeof(cmd), outputData, &outputDataSize);
- LogSPS("ActivateLocalProxy: IOConnectCallStructMethod for %s/%s/%s %d", intf->ifname, n1, n2, kr);
- if (kr == KERN_SUCCESS) result = mStatus_NoError;
- if (cmd.tcpPorts.ptr) freeL("mDNSOffloadCmd udpPorts", cmd.tcpPorts.ptr);
- if (cmd.udpPorts.ptr) freeL("mDNSOffloadCmd tcpPorts", cmd.udpPorts.ptr);
- if (cmd.rrRecords.ptr) freeL("mDNSOffloadCmd rrRecords", cmd.rrRecords.ptr);
- if (msg) freeL("mDNSOffloadCmd msg", msg);
- IOServiceClose(conObj);
+ GetProxyRecords(msg, &cmd.rrBufferSize, cmd.rrRecords.ptr, &cmd.numRRRecords, intf, TCPKAOnly, supportsTCPKA);
+ if (cmd.udpPorts.ptr) cmd.numUDPPorts = TCPKAOnly ? 0 : GetPortArray(mDNSTransport_UDP, cmd.udpPorts.ptr);
+ if (cmd.tcpPorts.ptr) cmd.numTCPPorts = TCPKAOnly ? 0 : GetPortArray(mDNSTransport_TCP, cmd.tcpPorts.ptr);
+ char outputData[2];
+ size_t outputDataSize = sizeof(outputData);
+ kr = IOConnectCallStructMethod(conObj, 0, &cmd, sizeof(cmd), outputData, &outputDataSize);
+ LogSPS("ActivateLocalProxy: IOConnectCallStructMethod for %s/%s/%s %d", intf->ifname, n1, n2, kr);
+ if (kr == KERN_SUCCESS) result = mStatus_NoError;
+ if (cmd.tcpPorts.ptr) freeL("mDNSOffloadCmd udpPorts", cmd.tcpPorts.ptr);
+ if (cmd.udpPorts.ptr) freeL("mDNSOffloadCmd tcpPorts", cmd.udpPorts.ptr);
+ if (cmd.rrRecords.ptr) freeL("mDNSOffloadCmd rrRecords", cmd.rrRecords.ptr);
+ if (msg) freeL("mDNSOffloadCmd msg", msg);
+ IOServiceClose(conObj);
- CFRelease(ref);
- if (parent != IO_OBJECT_NULL) IOObjectRelease(parent);
+ CFRelease(ref);
+ IOObjectRelease(parent);
- if (service != IO_OBJECT_NULL) IOObjectRelease(service);
- *keepaliveOnly = TCPKAOnly;
+ *keepaliveOnly = (TCPKAOnly && supportsTCPKA) ? mDNStrue : mDNSfalse;
return result;
diff --git a/mDNSResponder/mDNSMacOSX/mDNSMacOSX.h b/mDNSResponder/mDNSMacOSX/mDNSMacOSX.h
index 62309595..82de4331 100644
--- a/mDNSResponder/mDNSMacOSX/mDNSMacOSX.h
+++ b/mDNSResponder/mDNSMacOSX/mDNSMacOSX.h
@@ -244,8 +244,6 @@ extern int KQueueSet(int fd, u_short flags, short filter, const KQueueEntry *con
extern void KQueueLock(void);
extern void KQueueUnlock(const char* task);
extern void mDNSPlatformCloseFD(KQueueEntry *kq, int fd);
-extern ssize_t myrecvfrom(const int s, void *const buffer, const size_t max,
- struct sockaddr *const from, size_t *const fromlen, mDNSAddr *dstaddr, char *ifname, mDNSu8 *ttl);
extern mDNSBool DictionaryIsEnabled(CFDictionaryRef dict);
diff --git a/mDNSResponder/mDNSShared/dns_sd.h b/mDNSResponder/mDNSShared/dns_sd.h
index f76fbbdd..5989f17c 100644
--- a/mDNSResponder/mDNSShared/dns_sd.h
+++ b/mDNSResponder/mDNSShared/dns_sd.h
@@ -66,7 +66,7 @@
#ifndef _DNS_SD_H
-#define _DNS_SD_H 8805004
+#define _DNS_SD_H 8806001
#ifdef __cplusplus
extern "C" {
2.26.2
