Multicast in Libbsd
Cedric Berger
cedric at precidata.com
Fri Jun 19 15:53:00 UTC 2020
On 18.06.20 22:47, Joel Sherrill wrote:
> Hi
> I have an example FACE application I am trying to port to RTEMS. This
> is a multi-question email:
> First, it fails with EADDRNOTAVAIL on this call:
> // Subscribe to multicast group
> struct ip_mreq mreq;
> rc = inet_pton(AF_INET, multicastGroup_m,
> &mreq.imr_multiaddr.s_addr);
> mreq.imr_interface.s_addr = htonl(INADDR_ANY);
> rc = setsockopt(
> new_socket,
> IPPROTO_IP,
> IP_ADD_MEMBERSHIP,
> &mreq,
> sizeof(mreq)
> I assume that is because there is no multicast route. On Linux, you
> have to do an ifconfig and route to have a multicast route, but I
> haven't been able to find a multicast setup example for FreeBSD. The
> Linux commands are:
> ifconfig lo multicast
> route add -net 224.0.0.0 netmask 240.0.0.0 dev lo
This:
https://gist.github.com/hostilefork/f7cae3dc33e7416f2dd25a402857b6c6
Compiles and run without any special configuration on FreeBSD 12.1
The handbook claims that "Multicast applications do not require any
special configuration in order to run on FreeBSD"
https://www.freebsd.org/doc/handbook/network-routing.html
Following is the routing table on a FreeBSD jail with no special 224
route needed.
Cédric
# netstat -nr
Routing tables
Internet:
Destination Gateway Flags Netif Expire
default 172.18.12.1 UGS epair25b
127.0.0.1 link#1 UH lo0
172.18.12.0/24 link#3 U epair25b
172.18.12.25 link#3 UHS lo0
Internet6:
::/96 ::1 UGRS lo0
::1 link#1 UH lo0
::ffff:0.0.0.0/96 ::1 UGRS lo0
fe80::/10 ::1 UGRS lo0
fe80::%lo0/64 link#1 U lo0
fe80::1%lo0 link#1 UHS lo0
ff02::/16 ::1 UGRS lo0
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200619/5c08bc6f/attachment.html>
