Multicast in Libbsd
Fri Jun 19 21:12:47 UTC 2020
This turned out to be a trivial problem but hard to figure out. :(
The code has a POSIX_Init which initializes the stack and then calls the
application's main() which spawns a number of threads which start using the
stack. I disabled the POSIX_Init from calling main(), added mcast-listener
and mcast-writer (standard net code I had) as shell programs, and then
telnet'ed into the target. I could telnet in twice and run a listener in
one session and a writer in another. This proved that multicast was working
and made me wonder if there was a race condition on stack initialization
since it takes a little while to login twice and run two programs.
I put a sleep(10) before calling main() and the program came up. Based on
its output, it got through initialization but then faulted. I tracked that
down to RTEMS implementation of posix_devctl() being correct and the
adapter being used on Linux was incorrect.
*** Is there a reliable way to know the stack is settled out before the
application can run?
*** I still have to get the multicast out of qemu but that's another issue.
Thanks for the suggestions everyone.
--joel
On Fri, Jun 19, 2020 at 2:35 PM Heinz Junkes <junkes at fhi-berlin.mpg.de>
wrote:
> I can agree with Cedric.
> I use rtems5 with rtems-libbsd. I initialize the network interfaces of my
> target via dhcpcd
> and the interfaces are automatically multicast capable.
> This works without creating a route:
>  if (setsockopt(conf->udp, IPPROTO_IP, IP_ADD_MEMBERSHIP,
>                         (char *) &mreq, sizeof(mreq))!=0) {
>                         struct sockaddr_in temp;
>                         char name[40];
> Heinz
> > On 19. Jun 2020, at 17:53, Cedric Berger <cedric at precidata.com> wrote:
> > On 18.06.20 22:47, Joel Sherrill wrote:
> >> Hi
> >> I have an example FACE application I am trying to port to RTEMS.  This
> is a multi-question email:
> >> First, it fails with EADDRNOTAVAIL on this call:
> >>          // Subscribe to multicast group
> >>           struct ip_mreq mreq;
> >>           rc = inet_pton(AF_INET, multicastGroup_m,
> &mreq.imr_multiaddr.s_addr);
> >>           mreq.imr_interface.s_addr = htonl(INADDR_ANY);
> >>           rc = setsockopt(
> >>             new_socket,
> >>             IPPROTO_IP,
> >>             IP_ADD_MEMBERSHIP,
> >>             &mreq,
> >>             sizeof(mreq)
> >> I assume that is because there is no multicast route. On Linux, you
> have to do an ifconfig and route to have a multicast route, but I haven't
> been able to find a multicast setup example for FreeBSD. The Linux commands
> are:
> >>     ifconfig lo multicast
> >>     route add -net 224.0.0.0 netmask 240.0.0.0 dev lo
> > This:
> > https://gist.github.com/hostilefork/f7cae3dc33e7416f2dd25a402857b6c6
> > Compiles and run without any special configuration on FreeBSD 12.1
> > The handbook claims that "Multicast applications do not require any
> special configuration in order to run on FreeBSD"
> > https://www.freebsd.org/doc/handbook/network-routing.html
> > Following is the routing table on a FreeBSD jail with no special 224
> route needed.
> > Cédric
> > # netstat -nr
> > Routing tables
> > Internet:
> > Destination        Gateway            Flags     Netif Expire
> > default            172.18.12.1        UGS    epair25b
> > 127.0.0.1          link#1             UH          lo0
> > 172.18.12.0/24     link#3             U      epair25b
> > 172.18.12.25       link#3             UHS         lo0
> > Internet6:
>  Netif Expire
> > ::/96                             ::1                           UGRS
>     lo0
> > ::1                               link#1                        UH
>     lo0
> > ::ffff:0.0.0.0/96                 ::1                           UGRS
>     lo0
> > fe80::/10                         ::1                           UGRS
>     lo0
> > fe80::%lo0/64                     link#1                        U
>    lo0
> > fe80::1%lo0                       link#1                        UHS
>    lo0
> > ff02::/16                         ::1                           UGRS
>     lo0
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200619/9318884d/attachment.html>
