[PATCH] smpstrongapa01: Improve readability
Gedare Bloom
gedare at rtems.org
Mon Jun 22 16:13:44 UTC 2020
On Sun, Jun 21, 2020 at 11:10 AM Richi Dubey <richidubey at gmail.com> wrote:
> testsuites/smptests/smpstrongapa01/init.c | 60 ++++++++++++++---------
> 1 file changed, 38 insertions(+), 22 deletions(-)
> diff --git a/testsuites/smptests/smpstrongapa01/init.c b/testsuites/smptests/smpstrongapa01/init.c
> index bf8bc05231..ab6b0fe328 100644
> --- a/testsuites/smptests/smpstrongapa01/init.c
> +++ b/testsuites/smptests/smpstrongapa01/init.c
> @@ -16,7 +16,7 @@
> #include "config.h"
> #endif
> -#include "tmacros.h"
> +#include <tmacros.h>
> #include <rtems.h>
> @@ -30,9 +30,22 @@ const char rtems_test_name[] = "SMPSTRONGAPA 1";
> #define ALL ((UINT32_C(1) << CPU_COUNT) - 1)
> -#define IDLE UINT8_C(255)
> +typedef enum {
> + T0,
> + T1,
> + T2,
> + T3,
> + T4,
> + T5,
> + T6,
> + T7
> + T8,
> + T9,
> + T10,
> + T11,
> + IDLE
> +} task_index;
> -#define NAME rtems_build_name('S', 'A', 'P', 'A')
> typedef struct {
> enum {
> @@ -43,7 +56,7 @@ typedef struct {
> KIND_UNBLOCK
> } kind;
> - size_t index;
> + task_index index;
> struct {
> rtems_task_priority priority;
> @@ -102,17 +115,17 @@ typedef struct {
> static const test_action test_actions[] = {
> RESET,
> - UNBLOCK( 0, 0, IDLE, IDLE, IDLE),
> - UNBLOCK( 1, 0, 1, IDLE, IDLE),
> - UNBLOCK( 2, 0, 1, 2, IDLE),
> - UNBLOCK( 3, 0, 1, 2, 3),
> - UNBLOCK( 5, 0, 1, 2, 3),
> - SET_PRIORITY( 3, P(4), 0, 1, 2, 3),
> - SET_PRIORITY( 5, P(3), 0, 1, 2, 5),
> - BLOCK( 5, 0, 1, 2, 3),
> - SET_AFFINITY( 5, ALL, 0, 1, 2, 3),
> + UNBLOCK( T0, T0, IDLE, IDLE, IDLE),
> + UNBLOCK( T1, T0, T1, IDLE, IDLE),
> + UNBLOCK( T2, T0, T1, T2, IDLE),
> + UNBLOCK( T3, T0, T1, T2, T3),
> + UNBLOCK( T5, T0, T1, T2, T3),
> + SET_PRIORITY( T3, P(4), T0, T1, T2, T3),
> + SET_PRIORITY( T5, P(3), T0, T1, T2, T5),
> + BLOCK( T5, T0, T1, T2, T3),
> + SET_AFFINITY( T5, ALL, T0, T1, T2, T3),
> RESET,
> RESET
> @@ -130,7 +143,7 @@ static void set_affinity(rtems_id id, uint32_t cpu_set_32)
> rtems_status_code sc;
> cpu_set_t cpu_set;
> - size_t i;
> + task_index i;
> CPU_ZERO(&cpu_set);
> @@ -147,7 +160,7 @@ static void set_affinity(rtems_id id, uint32_t cpu_set_32)
> static void reset(test_context *ctx)
> - size_t i;
> + task_index i;
> for (i = CPU_COUNT; i < TASK_COUNT; ++i) {
Is it guaranteed that TASK_COUNT is less than the max task_index?
Sometimes you need to be careful about using enum types in comparisons
against non-enum (integer) types.
> set_priority(ctx->task_ids[i], P(i));
> @@ -179,10 +192,10 @@ static void reset(test_context *ctx)
> static void check_cpu_allocations(test_context *ctx, const test_action *action)
> - size_t i;
> + task_index i;
> for (i = 0; i < CPU_COUNT; ++i) {
> - size_t e;
> + task_index e;
> const Per_CPU_Control *c;
> const Thread_Control *h;
> @@ -206,7 +219,7 @@ static void timer(rtems_id id, void *arg)
> test_context *ctx;
> - size_t i;
> + task_index i;
> ctx = arg;
> i = ctx->action_index;
> @@ -271,7 +284,7 @@ static void test(void)
> test_context *ctx;
> - size_t i;
> + task_index i;
> ctx = &test_instance;
> @@ -279,7 +292,7 @@ static void test(void)
> for (i = 0; i < TASK_COUNT; ++i) {
> sc = rtems_task_create(
> - NAME,
> + rtems_build_name(' ', ' ', 'T', '0' + i),
> P(i),
> RTEMS_MINIMUM_STACK_SIZE,
> RTEMS_DEFAULT_MODES,
> @@ -292,7 +305,10 @@ static void test(void)
> rtems_test_assert(sc == RTEMS_SUCCESSFUL);
> - sc = rtems_timer_create(NAME, &ctx->timer_id);
> + sc = rtems_timer_create(
> + rtems_build_name('S', 'A', 'P', 'A'),
> + &ctx->timer_id
> sc = rtems_timer_fire_after(ctx->timer_id, 1, timer, ctx);
> 2.17.1
> devel mailing list
> devel at rtems.org
