rtems_interrupt_catch()
Wed Jun 24 23:36:12 UTC 2020
On 24/6/20 2:40 am, Sebastian Huber wrote:
> Hello,
> I noticed that the rtems_interrupt_catch() directive is only declared
> and implemented if CPU_SIMPLE_VECTORED_INTERRUPTS == TRUE:
> #if (CPU_SIMPLE_VECTORED_INTERRUPTS == FALSE)
> typedef ISR_Handler_entry rtems_isr_entry;
> #else
>   *  @brief Interrupt handler type.
>   *  @see rtems_interrupt_catch()
> typedef rtems_isr ( *rtems_isr_entry )(
>                   rtems_vector_number
>   * @brief RTEMS Interrupt Catch
>   * This directive installs @a new_isr_handler as the RTEMS interrupt
> service
>   * routine for the interrupt vector with number @a vector. The previous
> RTEMS
>   * interrupt service routine is returned in @a old_isr_handler.
>   * @param[in] new_isr_handler is the address of interrupt service routine
>   * @param[in] vector is the interrupt vector number
>   * @param[in] old_isr_handler address at which to store previous ISR
> address
>   * @retval RTEMS_SUCCESSFUL and *old_isr_handler filled with previous ISR
>   *         address
> rtems_status_code rtems_interrupt_catch(
>    rtems_isr_entry      new_isr_handler,
>    rtems_vector_number  vector,
>    rtems_isr_entry     *old_isr_handler
> #endif
> This is not mentioned in the documentation:
> https://docs.rtems.org/branches/master/c-user/interrupt_manager.html#interrupt-catch-establish-an-isr
> Should we provide this function also if CPU_SIMPLE_VECTORED_INTERRUPTS
> == FALSE and for example just return RTEMS_NOT_IMPLEMENTED?
Which archs define CPU_SIMPLE_VECTORED_INTERRUPTS as false?
