Command line for Qemu and libbsd for pc386
Gabriel.Moyano at dlr.de
Thu Jun 25 06:12:31 UTC 2020
Hi Joel,
Before running qemu, some qtabs should be created. How to do that it is described on file libbsd.txt (line 333). Then I usually run qemu as follows:
qemu-system-i386 -append --console=/dev/com1 -no-reboot -serial stdio -monitor none -nographic -netdev tap,ifname=qtap1,script=no,downscript=no,id=n1 –device e1000,netdev=n1,mac=52:55:00:d1:55:01 -kernel path/to/exe/file
Please note that if you are running two instances, the second one should have different MAC address and ifname, e.g. mac=52:55:00:d1:55:02 and ifname=qtab2
If hope this helps.
Cheers,
Gabriel
From: devel [mailto:devel-bounces at rtems.org] On Behalf Of Joel Sherrill
Sent: Mittwoch, 24. Juni 2020 19:23
To: rtems-devel at rtems.org
Subject: Command line for Qemu and libbsd for pc386
Hi
Does someone have a qemu command line handy for running libbsd network applications on Qemu?
I have lots of notes and old examples but can't seem to trip the right combination today.
Thanks.
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200625/113c010e/attachment.html>
